I’m not sure which lathes but some use a thread to screw the chuck backplate onto the spindle. Using the lathe in reverse could possibly unscrew the spindle/backplate.
My sieg is a one piece design (spindle/backplate) so no issues with either direction.
MRsDNF which carbide parting tool do you use? I saw one of the cheaper ones and the carbide tip kept falling out.
[quote=pinkpanda3310]
I would think any lathe with a reverse switch as standard equipment would be fine,
good point for older equipment though
I was warned of this by several friends when I got my start. Not a ‘solution’ per se, but they all said that when running in reverse, keep the cross-slide and all hard parts clear with the tool and holder extended, so that if something goes wrong the tool/holder will swing clear or break instead of breaking the main parts of the machine. Made sense to me when explained thiscway but I never had that happen.
I wouldn’t be too worried about DNF, he can make his machines sing.
I learned on the interweb that some machinists are fine with it but others are not. Hence when something goes wrong it’s a major issue causing fear in machinists everywhere I think it’s a bit like the exploding batteries to flashlights - it doesn’t happen often but everyone hears about it when it does happen.
Lol, “brave”….??? All I did was nick the corners. Nothing detrimental.
Do I like the qctp? Yes. I did have to turn down and thread the end of the hold down bolt as it was too large for the compound slide. Luckily I have a lathe for that :innocent: The one major gripe would be the kit I bought had a limited number of tool holders and to buy more individually is a lot more pricey.
Tool holders I have - 4x standard 1x boring bar holder 1x knurler (which holds a tool on the backside) 1x parting tool holder plus the original tool holder that came on the lathe. Since I part off with the lathe in reverse I don’t use the quick change parting tool holder, I use the original tool holder for that. Still now and then I’m changing bits in the holders but for changing between commonly used bits it’s great.
I guess a pic could’ve explained that in less words but I’m on the phone.
And just because I’m looking for something doesn’t mean I always find it :laughing: :person_facepalming:
yes might shove a xml and blf driver in it.
more of a test run to see how it would go
see how many cree rings it has.
might try polishing some more with dremmel
