Tom,
I’m not exactly sure what type plastic the housings are made from but you might look into Weld-On plastic adhesives for repair. If the plastic breaks that easily I doubt it’s ABS, maybe Polypropylene.
I use Weld-On for a lot of plastic repairs and they are usually as strong (or stronger) than the original part.
SkyRC (IMO), has very poor engineering and design. As mentioned above, the mistakes they make are simply inexcusable.
They may have good EE designs, but the physical designs of their PC boards and housings is poor to awful. (again, imo)
It’s THE reason I have not purchased an MC3000. Well, that and lack of after sale support…and a shopping list of user suggested improvements that members here have pointed out need to be made……and have not yet.
It’s also the reason I continue to pursue using a Data Logger with my B6 mini and Accucell.
Not sure if the Xtar Dragon has this capability (exporting Data).
Probably has to do with something getting lost in the translation and they thought English speaking people would like getting a lot of “Bang” for the Buck”?
I used an epoxy glue to re-attach the broken stem from shipping. I'm trying to assemble it, but it's a freak'n nightmare - no instructions, the 4 sliders to get into position is totally, insanely nuts!
It's sitting there on my bench in pieces, and I don't have faith the stem will hold up when all back together. Been way too bizy to spend that kind of time this needs. Hope to get back to it soon.
Any chance you could post a photo of your repair and the innards you’re trying to reassemble before closing it up?
I think many others have had (or will eventually have) this same problem.
True, but the WP2 cost 5 times less than a MC3000. BTW, I’ve owned 10 Xtar’s including 2 of the first gen WP2’s and never had problems with any of them. I’ve since given my WP2’s away to friends and they’re still working 5 years later.
Here's the replacement case that had a stem snapped off, and with the stem repaired with a supposed good epoxy glue:
Here's the mess:
I looked it over again and can't begin to understand how it's possible to work in this space and get everything aligned up perfectly. Nothing fits snugly.
They glued the connectors with really tough stuff so can't work on it in pieces. I got all the buttons, display and boards moved over ok, I'm just stuck on aligning/assembling the sliders.
K, think (thought) I found a way to assemble it. For the 6 screws securing down the back cover, I had only 5. For some reason couldn't get them to tighten the case completely - just a hiar worth of looseness. Tried it anyway - oh boy... One of those long slots popped out, angled now in the case - of course I tried this with a cell and power, so.... The charger reset, and then noticed the distinct smell of burning electronics. Turned it off. I straightened out the slot, and this time held the case tightly together and the screw actually tightened it all up. So it's working - but on only 2 slots - the 3rd and 4th. 1st and 2nd are dead - don't recognize a battery, so sure something critical went up in smoke for those 2 slots. So I'm worse then when I started - I had only one dead slot, now I got 2 dead ones.
Now that I know how to assemble it, might have to take a looksy to see if I can see what burnt, and if it's replaceable. Or buy a new one? Really wanted to charge 4 cells at a time with this - got lots of SRK style lights now...
I also had trouble putting the MC3000 together after fixing a broken post. In the process the whole thing stopped working when one of the rails slipped and probably shorted something. Just like you couldn’t close the case all the way. Got an error message about the ADC after getting it sorted.
There’s isn’t anything similar on the market so just bought a third one. At least now both of them have the new case with better posts.
Here is the list that members came up with………The thread died so I didn’t see where these were resolved. Maybe in another thread?
It is required to remember the program numbers or press a key, on the initial screen there is no hint on how the selected program works.
Default time on LiIon is 3 hours, this is to short.
When terminating on time or capacity, no capacity information is saved.
Break_in shows charged capacity, not discharge capacity.
Backlight always requires a keypress to turn on, putting a battery into the charger will not turn the light on
Factory calibration do not match specifications.
The PC software requires a high screen resolution
NiMH charge curves looks messy on PC, an option to hiding measuring pauses would be nice.
PC software saves csv files at wrong location.
It is not possible to copy programming from one charger to another, people with more than one charger (That will be me) must enter each program on each charger!
The Bluetooth software is not stable and do not work on all phones.
Strange coding on the usb output, why not use a chip to automatic get the best coding?
Tom,
Thanks for the photos. A picture is worth 1000 words and now I see exactly what you’re up against.
Maybe they’ve since corrected all the issues with the MC3000. I don’t know. I wonder if there’s a photo here somewhere of the new post design.
I sorely miss “Made In America”. If a charger that offered those same features and was made in the USA….heck I’d spend twice as much because I know the warranty would be honored and that means the quality would be better to begin with. The actual price we pay for “cheap” Chinese goods is expensive.
So you’re going to possibly just buy another as a fix…maybe a fix……maybe another lemon?
Unfortunately, to get those expensive “cheap” goods, we’ve abandoned our ability to make much of anything domestically and every component would have to come from guess where? Ultimately expensive, “cheap” Chinese goods are an opiate on which the world is addicted…to it’s own demise.
How do you know the new ones have better posts? Did you take it apart or can you see them without disassembly?
Is there a photo of the new posts on the forum somewhere?
ok. It’s hard to figure out the timeline of some of the fixes and I didn’t see it in the list.
That’s good to know. But wait….in the posts above, TomE just this week says he received a replacement cover for one that had broken pins and it ALSO has the same issue?
Maybe the post were stronger, but still broken due to shipping? This is confusing. :person_facepalming:
So I wonder if ALL the discovered bugs and problems have been resolved now or if there are any new ones that have not yet.
