Testing a Cree XHP50.2 J4 3A led
What would a change to a 50.2 from a 50 in a standard light like EA81 do? If anything.
One of my build plans was to take a single 26650 light (ultrafire F13) and run a pair of 26350 batteries from Banggood along with a direct drive 22mm driver from Mountain Electronics then put in the xhp50.2 that I tried out in my Convoy L6.
Now I know that will pull way too many amps. I can’t switch to amp limited batteries as they don’t exist. I don’t know of any non direct drive drivers that will work. Do you guys know of any?
I guess I’m gonna have to shelve the 50.2 and buy a new xhp70 to run in it. Does that sound right?
One thing to keep in mind with the 26350 cells is they can’t handle much more than 7A. See discharge curves at the bottom of the banggood listing. Banggood says they are out of stock, by the way.
These 26350 cells with an XHP50 V1 resulted in about 7A on a full charge. Using an emitter with a lower Vf would, in my opinion, probably be asking a bit too much of these cells.
They are in stock at FastTech.
I was thinking they would do way more than 7 amp, but I was thinking wrong. My memory is not always so good. :person_facepalming:
I would like to limit the current to 4 or 5 amps which I think would be great in a small light. I just don’t know how to do it. :weary:
Update, I was looking around at MTN and saw they had a linear driver for 6 volt use. This is a 7135 based driver.
Can someone give a summary of how the new low voltage emitters will respond to different driver types?
I think there is going to be a lot of confusion over this.
Direct drive = We know that they will draw way more amps than the regular xhp50 and xhp70. Not good at all unless you can limit the amps by using certain batteries or some other means.
Boost and Buck = It should draw the same currents. We may get improvements in efficiency, right?
Linear = It should draw the same currents. Anything else I’m not sure.
BTW, I tried my L6 with the 50.2 in it with some fully charged protected KeepPower 5200 26650. They are supposed to have a 10 amp limit. I expected them to trip the circuitry on turbo, but they didnt. Maybe they limit it to 10 amps?
Compared to fully charged Liitokala it’s not quite as bright and it’s not heating up as quick. In fact, the KP are getting a lot less current in all modes. Even slightly less current than the xhp70 with the KP batteries. Pretty interesting.
I can only compare amp draws as I don’t have a clamp meter to get exact numbers. I know where I can borrow one if anyone is interested. Idk, maybe I’m boring you guys. Lol
That 22mm driver will work, you can simply not use the highest mode until the battery voltage drops or have RMM set the max pwm in turbo to say ~200 to limit current. It depends on how much self control you have.
So I was thinking about these new generation LEDs with FET drivers. If the MCU is monitoring cell voltage with an ADC for LVP, would it be possible to reprogram the MCU to use the value it reads to limit the PWM until cell voltage falls?
Ex. If it sees the cell voltage is at 8V, only command a maximum of 75% PWM or something, then when the cells are down at 7V let it get to 90%, etc.
If that does work it should let us take advantage of the efficiency increase of the new emitters as well, which linear does not.
I was able to borrow a clamp meter to measure amps on my L6 with 50.2. I used a 10ga wire (too big?) on the tail end.
With the Liitokalas 8.9 amp.
With the KeepPowers 6.7 amp.
So no giant 12 amp loads, but that is a big difference just between batteries.
Compared to my xhp70 with same driver (rough estimates until I put the xhp70 back in)
Liitokala 8.0 amp
KeepPowers 6.4 amp
Hey Jason,
I am planning on making a very similar build, with a mt-12 body (similar to F-13), a mt-g2, and a pair of 26350 batteries.
I’m planning on using this driver:
http://kaidomain.com/p/S025265.New-FX6-22mm-6V-8_4V-5A-2-Groups-of-3-to-5-Mode-Driver-Circuit-Board-for-Cree-XHP50-XHP70-MT-G2
Well that’s if it ever gets here, kaidoman took 21 days to ship it out.
Supposedly the driver is regulated with a high of 4500ma, I’ll see how it performs if it ever gets here.
In theory it should provide a nice regulated output for the new low vf emitters.
Thanks, I’ll make a note of it. Richard at MTN has me covered, though. This one.
6 amps is no slouch and I can remove 7135 chips if I want to bring it down some for better battery life and less heat build up. The best thing is I can have Guppydrv with off time memory and it’s user setable turbo timer. :+1:
Anyone have an idea?
Some speculation... They are binned the same, so same amps = same lumens. For the lumens output issue, depends on the driver, whether it's more amps limited or total power (watts) limited. The lower voltage of the 50.2 could be a good thing (more lumens output) or potentially bad thing - might have to burn off more voltage, so more heat. For the beam/tint, of course depends on what you are going from/to. The 50.2's don't have the same tendency to black hole the hot spot, but they do tend to yellow around the hot spot. Generally these new design LED's don't throw as well as the old ones - I know the XPL2's don't throw as well as the XPL's running at the same amps.
I'm not familiar with the EA81 or it's driver, so again, can't get specific.Those that know details on buck and boost drivers and worked with the 50.2 could probably answer better than me. Few trade-offs.
Yes, this is possible and something I have been wanting to get worked into Bistro from awhile now.
Although at this point I think we might end up skipping that rather crude method and going to something better unless someone gets it implemented before we make the move to the newer MCU’s.
I just finished up a build this past weekend; an XHP50.2 J4 3A 5000k in a single 26650 tube, using a H1-A booster driver all from KD. It has a much nicer hotspot with no X in it vs the original 50; the corona tint shift is still there like the XPL2s I’ve built, but doesn’t seem as pronounced. Compared to an L2 with a MT-G2 direct driven I built, the max on this 50.2 light boosted to 6v seems around 2500 lumens, or about 50% power on my MT-G2 L2. I don’t have a light meter to check the lumens or candela though.
as texas Ace said the max. Setting of the driver can be limited in the firmware
instead DD a 80% or so cycle as max. setting can be set in the firmware on your TA driver
Can an expert do this please?
Thanks
Low Vf on a DD driver with FET
higher current might blow the LED because it can get too much
on a linear driver like 7135
more heat on the driver less on the LED
on a Buck/Boost driver
less power consumption of the lioght, more runtime, less heat
I got some LiitoKala 26650’s in yesterday and charged a pair up, tested them against the Basen’s in my DBC-05 Triple 50.2. The new cell gave more amperage at the tail end but less actual lumens. Weird when I see that. “Only” 10,833 lumens pulling 22.44A on the LiitoKala’s.
TomE is being an outstanding guy and sending me his pair of Sanyo NCR20700A to test in this light against the other contenders. It’ll be interesting to see how they compare…
Lexel, is the below correct?
This can be controlled through carefully battery selection or programming the driver to run at a lower duty cycle on the highest level.
Emitter will see same amp draw as a non-low Vf emitter.
You get the same amp draw to the emitter, just with better efficiency.
