I highly suggest dedoming and possibly swapping the emitter to a bit warmer and higher CRI one if you decide to get the G20.
The emitter is on a small copper MCPCB. The thermal sensor seems to be attached to the shelf, which explains the ringing in the output when the light adjusts its output. The temperature changes are faster than if it was positioned on the driver for example.
With the change the beam becomes very consistent, the hotspot and spill are almost identical in tint and there’s no artifacts either.
I swapped a CRI80+ 4500 K XHP70 onto mine (Cree part XHP70A-01-0000-0D0HM245G). Here’s the results with the stock LED, the 4500 K LED and lastly the new LED with a sliced dome (I used a razor blade).
I wasn’t happy at all with just the emitter swap, since the huge tint shift (greenish yellow to blue) was still there. Slicing the dome fixed that right up and the beam is now excellent!
Since my original G20 had pretty much identical tint and tint shift to my sample of the Olight R50 Pro Seeker, here’s beamshots from that and the newly modded G20 with a sliced dome using the same camera settings (with a slight desaturation of the R50 image to make it look more realistic).
CRI Data reveals that the new emitter is actually CRI80, but the hotspot was terribly tinted towards yellow/green (duv 0.009). It was also much warmer than specified (4000 K vs. 4500 K), but this seems to be often the case when measured from the hotspot in a flashlight with a reflector.
First, the new emitter with the dome intact.
And with the dome sliced off things look much better. More neutral (duv 0.004). And as expected, a slightly warmer hotspot at 3900 K. CRI dropped by one at that particular position of the beam, no worries, it was back to 80 on the next spot I measured.
Output at 30 sec changed as follows:
Stock: 2200 lumens
4500 K: 1990 lumens
Dedomed: 1760 lumens
A sacrifice I’m more than willing to make for the prettier beam. I didn’t measure lux, but the hotspot was clearly brighter after dedoming the 4500 K LED. Getting more throw wasn’t the goal of this exercise. Now the light quality is actually superb and Klarus should offer it with a dedomed XHP70 (like every other manufacturer). I hoped Cree would also manufacture XHP50/70 with no dome, but I guess flashlight industry isn’t big enough. In my opinion the beam quality always improves after dedoming when using these.
The finished mod.
