Introducing Ceilingbounce - flashlight testing and runtime graphs for Android
Nice! I just ordered a Pixel Google phone, so could try this out in a few weeks. Android is mostly all new to me though.
Well, I certainly wasn’t going to write Java when not forced and/or paid a lot.
While it’s fundamentally a pretty simple app that doesn’t require much in the way of fancy language features, it has been really nice to have watchers, futures and promise/deliver. And the REPL, of course. I don’t know how people get anything done in environments where they can’t interact with their running code in real time.
Cool idea. Any plans for an iPhone variant?
Try developing/testing flashlight drivers. Take your best shot, take apart your light, rig up the clip/USB dongle, dnld, assemble the light, test -- over and over again . You do get better and better at getting it right the first time.
Any plans to put this on the Google Play store? I’m not sure if this would incur any cost to you.
I’ve side-loaded stuff on Android before but for some reason, the app that I normally use to load APKs isn’t recognizing the file at all. I copied the APK into 3 different directories on my phone and it’s not recognizing the APK automatically or even if I manually navigate to the folder. I’m using “APK Installer” by “Mobile Manager” (this same app has been used before to side-load other stuff).
Maybe I’ll just try another side loader.
This is on a Samsung S7 Edge.
Okay, I just tried a different loader and it worked fine. Odd.
Already answered in the readme bout iOS. Simple answer is no, iOS and the store have too many restrictions.
It’s not simply that there are too many restrictions. It’s that use of the API required to access the ambient light sensor is specifically restricted from being used in any app sold or given away in the app store (and there are no sane options for end-users to sideload). If you look at cross-platform general sensor-monitoring apps like Physics Toolbox, you’ll see they don’t support the light sensor on iOS while they do on Android.
As for the Play store, yes, I do plan to put it there eventually. It costs $25 to do so.
Well, just thought 1 restriction is one too many, that's why I included a link to your readme.
There are luxmeter apps on the App Store such as this one: https://itunes.apple.com/us/app/galactica-luxmeter/id666846635?mt=8
But maybe they have a different low level method? I see references stating they use the camera.
There are some iOS apps that try to detect light levels using the camera. As far as I can tell, that method would only be accurate with really low-level control over the camera that isn’t available on iOS. So, yes, one restriction is too many when it’s the core functionality of the app that’s restricted.
Updated:
  • The sample rate is decreased to one sample per 10 seconds after 100 minutes to stay responsive in tests lasting many hours.
  • The PNG image of the graph doesn’t start writing until the background rendering is complete, because concurrency is hard.
  • The output graph is scaled appropriately regardless of the user panning or scaling the live graph.
  • A number pad is used instead of a generic keyboard for the calibration fields.
bump!
(so I can find it faster on the new phone and check it out for some Q8 runtime graphs
thanks for making it Zak!
Hi Zak,
Been tinkering a bit with your app in my rooted good ol' Moto G 2013. Nice it is despite its simplicity, though I have to remember avoiding my usual screen auto-rotate setting because the app resets if the screen rotates, ?
I'm trying to get some valid throw values for a Sofirn C8T, the thing does up to 6+A at the tailcap, but I guess I need to make some more table room, it's a small spot at just 0.75m. Already got 102.4Kcd.
0K, here's the main question I came here for, ¿do you think a PWM detector functionality could be implemented in the app? I believe this can be possible by polling the light sensor at two non-multiple useful frequencies with custom selectable polling frequency up to whatever limit please (this is just in case we start polling at exactly the PWM frequency LoL!), looking up for noticeable variations in the measurements over a very brief lapse. Any non-PWM beam values would be nearly identical, and it would just take a second of polling or much less. Graph time of up to half or 1s would be plenty, I believe.
Cheers ^:)
The maximum sample rate of the sensor on my Nexus 5 seems to be 0.2 seconds. That’s not a viable way to detect PWM.
What could work is to use the camera. At a high shutter speed with the electronic rolling shutters used in most smartphones, ripple and PWM look something like this. That kind of pattern should be detectable with an algorithm and it may even be possible to estimate frequency.
Sound like the flicker tester app from visosystems.
Link: http://www.visosystems.com/products/flicker-tester/
It says it’s for both android and iPhone but I can only make it to work on iPhones. On android I only get the “not enough light” message.
I have sent them a mail but got a message back that he won’t be at the office until sometime in December.
Would be great if you could figure out how they do for the iPhone app and try to replicate it to your app on android.
Saw that post of yours yesterday, EagleShield. That is the reason I asked Zak, I thought it would be a nice addition to his application.
The Viso Systems Flicker Tester application is also not working on my Android, guess they definitively have bugs to sort out in it.
Cheers
P.S.: C8T runtime graph coming in.
Thanks for the app. Just installed it on my Nexus 5X.
My biggest challenge is finding some known/verified lumen outputs for the flashlights that I own so that I can calibrate it. Is there a database of such info somewhere? I’ve been searching through various reviews on BLF and not getting what I need. Some of the common lights I own:
Convoy S2+ 4x7135 3B XML2
Convoy S2+ 8x7135 3A XPL HI
DQG Tiny 4th NW
Jetbeam Jet-1 MK
https://www.dial.de/en/blog/article/luxmeter-app-versus-measuring-deviceare-smartphones-suitable-for-measuring-illuminance/
Seems the situation is pretty bleak. Even if you calibrate you can have factors of 3 errors across the dynamic range. And if you think establishing detailed calibration curves for various devices will help, nope.. they found no consistency across identical devices. I'd strongly suspect there are wild variations depending on the color distribution of the source too. Seems like these smartphone meters are kind of toys.
Oh didn't notice the OP is the writer. Ok great, maybe you can dispute that then?
I can’t dispute it. I have two smartphones and no real calibrated light sources. I have a couple lights that maukka also has, and maukka has a real integrating sphere.
I do note in the readme that “lux” readings from the phone’s light sensor are absolutely not lux. It is necessary to calibrate using lights with known lumen and candela values. No attempt is made to calibrate the raw sensor “lux” value to real lux, but I may add the ability. As the article notes, there’s no difference from one app to another in terms of the reported lux value; we all just report what the sensor says.
I wish the testers you linked had tried multiple samples of the same Android device like they did for iPhones. As the article notes, iPhone apps are using the camera rather than the light sensor because some jerk at Apple decided apps can’t use the light sensor. There’s bound to be some variation in that approach.
Somewhat problematic is that the test shows a non-linear ratio of lux to sensor values in all the devices tested. With most devices, it’s not huge, but the Samsung S5 at 500 lux is an exception. Everyone needs to test their own device with different lights on different modes for which there’s reasonably reliable data in order to have a reasonable calibration. If it jumps around as much as the S5, it may be impossible to calibrate accurately.
