I recieved my order from LEDDNA yesterday and this morning i did my second mod on my S2, i changed out the reflector for a 10 degree TIR opticâŠâŠ what a difference. At first i took it out of the cell holder and used it, but the beam looked a bit lopsided. I couldent to get the led to center up, so i took it all back apart and Dremeled the TIR holder down to fit in and set it back in, and that fixed the problem. I have to say i really like TIR optics now, so i will have to buy another S2 and set it up with a 60 degree optic.
Well done, Steel! Every time I see a tterev colour light build I admire the work that is in it.
Today I tried to love the Eagle Eye X7 and failed at it.
First I checked what the XHP50.2 looked through the X7 reflector, got it almost right by sanding the base of the reflector a bit and push it tight against the ledboard without centerpiece. It was ok, but then I reassembled the light with the original XM-L2 and that beam was so nice and smooth in comparison that I decided that it was not meant for the XHP50.2 after all.
So I modded it with a 90CRI T3 7A4 XM-L2 (from Kaidomain, this emitter is highly under-appreciated, if you are into warm light: this is a gem, both tint and colour rendering are wonderful, get them while they last!!). I used the original driver but soldered two R100âs on top of the two existing R140âs for a bit more current. Bypassed both springs and used a dark green tailcap for extra flair. The output on high is 940 lumen now (in that great tint!), must be about 4 amps. Mid is 340lm, low is 10lm. The extra resistors messed up the modes a bit, it is now low-med-high-high, with memory, the two highâs are both 940lm. Double-click for strobe. I can not find any visible PWM.
So now I have made the X7 into something I really should like, rock-solid light, great beam, great tint, great output, and I still donât like it, the design just puts me off
So if anyone is interested, I will sell it for the cost of the parts plus shipping, so parts is about $20, plus $7.20 for Netherlands or $10.30 for EU. (~$20 for the rest of the world but I guess that is not an option for anyone)
Btw, the battery tube is narrow, my Keeppower 4200mAh IMR fits but the 5000mAh Liitokala does not fit.
S41S with XP-L HI V3 3C and 17DDm/bistro. Bypassed tail springâŠ.arctic silver thermo paste.
Measured 13.8a at the tail. This thing gets hot in 10 seconds! Even with the optics, it gained some throw with the new emitters.
This was my first reflow ever and itâs easier than I thought. I heated up the mcpcb with my soldering iron and the reflow took less than 2 minutes.
Nice! Do you find the optics reach all the way to the emitters on yours?
The opticsâ touching the top of the emitters, I did confirm when i put them in. I have the updated head if that matters.
Just commenting to say there some really nice mods going on here.
dual switch
Fantastic mods!
Today I swapped the led in my new Jetbeam E10R.
The hard part was getting the bezel off, it was glued tight and needed a lot of bravery and near-demolishing of the flashlight. I got it off by 1) clamping the flashlight in a vice (the flat bits on the head were clamped in), 2) heating up the bezel fast and very hot with a small blowr torch with hot flame (more moderate heating with a small flame did not work), 3)after heating up wrapping the very hot bezel very fast and tight in a strip of inner tire and applying lots of force by hand. As you can see in the picture, the centering piece is partly melted, and cracked (but still very functional luckily).
It now has a Nichia 219B V1 sw45 R9080. Lost lots of light: currently on a 14500 high=350lm med=30lm low=2.5lm. This light has a great mode spacing IMO! The beam profile with this led is still very good and the tint, well⊠:heart_eyes:
Btw, the AR lens is slightly brown-ish and the tint looses (estimated by eye) a few hundred Kelvin because of that. Eventually I will try to find a non-coated 15mm lens for it
Always good to win the fight
What always helps winning the fight is starting it by telling the light that you are prepared to kill it if needed :rage:
Yes I have used such words often :laughing:
The hard part is having to back your words and provide the nessasary discipline. I have found the lights donât respond either way so I stopped with the threats. Iâve saved a couple lights this way.
I usually follow through being a man of my word, lost one or two thay way.
I warned themâŠ
Speak softly and carry a big hammer. I donât threaten, I act. Then I start over. Being a carpenter my aim is better than average but they donât know that. I think itâs more humane they donât know whatâs coming. :innocent:
More like a hack than a mod. And another case of polishing a turd from me, LoL.
This is the pill of one of those el cheapo Ultrafire zoomies. Originally itâs hollow, with just a tiny ledge for the star to sit on. So I filed a 5 cent coin and drilled two holes in it.
Before the hack, at 3 amps, in my usual ceiling test I got about a 4-5% drop in luminosity after 30 secs, and 10% after 5 minutes. According to Creeâs data thatâs about 47ÂșC after 30 secs and 70ÂșC after 5 mins.
With the hack in place I measured a 6% drop in the output, give or take, after 5 minutes. Thatâs supposed to be about 55ÂșC, so a whooping 15ÂșC of improvement there
All in all:
Before: 47ÂșC after 30 secs, 70ÂșC after 5 mins
After: 39ÂșC after 30 secs, 55ÂșC after 5 mins
Today three of my lights that where using 105C/D drivers with that crappy stock firmware got a new life.
Convoy C8 with dedomed xp-g2 led running on 12 7135 chips
Convoy S2+ with Nichia 219C led running on 8 7135 chips
UF SK98 with dedomed xp-g2 led running on 6 7135 chips
I flashed their drivers with biscotti firmware. It was first time i did something like this so i may say that i leveled up my skills. Following some instructions that i found here on this forum made this much easier than expected, 10/10
Here is one picture of my setup
Nice job BobbyMK. FW editing and flashing was sort of a leap for me, but as you said it really wasnât too hard with the documentation on the forum. It really opens up a new area of customization.
A few odds and sods. Successfully rolled and brazed .25mm sheet brass into an 18650 tube for woodifying the thinner 18650 host tubes that are only ~20mm OD at the o-ring lands(S2+, X6, E2L, etc). Also a few coats of epoxy on a mahogany tube and filled a custom copper C8 spacer with an aluminum slug tapped so it can be screwed to the stock pill(old style).
Today, I finally did a mod where I could use a Khatod quad optic, which is quite a bit taller than the Carclo.
Astrolux K01.
Removed the reflector and single MCPCB (which, oddly, was a 16mm DTP copper, even though the cavity can take a 20mm) and measured it against the T-pad/Khatod and found I would need about a 5mm spacer. I had an S2+ copper spacer from Mtn, but it was closer to 10mm. I managed to grind and file it down to an appropriate thickness.it slid in nice and snug with a little Antec 7 diamond thermal compound⊠I had to grind the bottom half of the legs on the optic to match the MCPCB, which didnât leave much material, but enough, to fit in to the pill.
For now, I just reused the stock driver and wires.
I am extremely pleased with the result! The only T-pad I had already populated had some XP-G3 S5 3A. These optics are, as I had hoped, way more narrow than a 10507 Carclo. It is almost as narrow as the stock reflector, but has 4 LEDâs feeding the spot!
I canât wait to check it out in the dark!
Iâll probably swap the driver out eventually for something with active thermal management and do a spring bypass in the tail, but Iâm real happy with the way it turned out!
A teaser for a scratch-build Iâm planning. It will be a 7x C8 reflector light with dedomed XPL emitters. 125mm diameter head. 2s 26650; the same electrical setup as my 7xXPL convoy L2. The drawing is actual size, with a convoy C8 for scale.
A drawing of the head, with my 7xXPL L2 for scale.
Should do around 9000 lumens OTF and 800+ Kcd. Made from âoff the shelfâ aluminum plate and tubing.
That will be one heck of a flashlight EasyB! Looking forward to it.
Thats scary EasyB. :+1:
