I think I figured out the color shift I got. I pulled out my super thin stack of copper shims and tightened the star directly to the flashlight head. Now it seems to be working like I expect it to.
BTW, I added orange leds to the switch this time around just to be different. They are not as bright as the whites, but still okay.
“IF” it’s a N4 it will handle it, I have seen N2’s turn BLUE at 11.8-12+ amps! I have built many N4’s in that range that are still kicking 2 years going, a better re-flow, board, better thermal contact and grease, you will be OK!
Like Dale says, the devil is in the details!!
I test them outside the light on a sink both LED and driver and weed out the weak! It also gives me an Idea of what I should have when I fully assemble the light. If I don’t get close to what I tested, then I start to look for what could be the problem, usually a bad ground contact.
I think I’ll keep them for now and just run it at 90% or so. Once the batteries run down a little the heat will not be such an issue. Maybe later I’ll switch them to 22 ga or so.
It’s an N4 1A that I just bought from MTN.
I’d love to get a P2 if they weren’t so hard to get and expensive.
Jason or KB, any idea what kind of numbers the L6’s are reaching with your 12-13 amp setups? SMO or OP reflectors?
Very interesting, and Jason thanks for the video!
I stopped chasing throw, but with my old driver with R082 resistor pruducing 5.7 amps (due to the KeepPower 5200 protected batteries), a cut down SMO reflector and sliced dome I went from a stock 481 meters to 678 meters. That’s 58kcd to 115kcd or about double the lux.
With just a swap to Liitokalas the amp draw went from 5.7 amps to 7 amps. That’s a nice boost.
Now I’ve got 12.6 amps so I’m sure the throw distance is much further now.
I put a new xhp70 in with the dome still on because I like the extra brightness even though it creates a bigger hotspot and I loose some throw distance. Maybe one of these days I’ll swap the sliced dome xhp70 in there just to see what the throw distance is. Maybe it will hit 800 meters?
I’ve also got a xhp50.2 that I can slice the dome off and swap to my KeepPower batteries to reduce the current draw. That might still draw too many amps, though. If I can keep it to around 9 amps I’m sure it would throw really well.
But like I said, I not too interested in max throw anymore.
I topped up my Liitokalas and did another amp draw test. It’s funny that the amps increase over the first 10 to 15 seconds then start to drop back down a little then kinda level out. I think a good 30 sec amp draw is right at 12.0 amps. I’m calling that official.
It weird how I got a little higher when the batts were at 4.1 volt, but I didn’t wait more than 10 seconds or so. So maybe it would have dropped down to 12 amps if I had ran it a full 30 seconds.
I’m doing a few basic mods of the two L6’s I own and logging the results, at various levels. For me, 8 amps, with the factory driver, and Liitokalas is about maxed out. I am now considering other options. This is why I’m asking about yours and Kawi’s results. Any lumen measurements?
When I built my triple XHP50.2 I stole the UCLp lens out of my L6. So my L6 now has the glass lens that came in the S70. (I know, right? ) I’m only seeing 7072.5 lumens out the front now. Need to get another UCLp lens from Chris…
Edit: Some clarification… When Chris ships the UCLp lens it has a blue plastic covering on both sides for protection. When I pull a glass lens from a light and install the UCLp I usually put the blue plastic on the old lens and mark on the plastic what light the lens came out of and the date. Well, when I stole the UCLp for my own custom build and tried to re-use the original glass lens the blue plastic pulled off AR coating in patches, ruining the lens. Hence, the S70 lens in the L6.
Hey TA, look… Jason got the square ATTiny85’s as well. lol
I was trying to use a regular resistor at the switch for these SMD LED’s, the little metal end cap pulls off easily, breaking the connection every time I try to put the light back together. So I need to source one of those inline components like Jason used, the blue with rings on it for ID?
Edit: Or I can spend a bit more time and JB Weld it sealed so there’s no pull on the wire. I have a new tube of Water Weld that’ll set up in minutes, should I go that route. Was using a 22K, might go with a 24K and use the JB Weld…
That’s close to my maxed out factory driver (using a wire across the sense resistors). I got 7.7 amps, also with Liitokalas. That’s all most folks need.
I don’t have a light box to measure lumens so I can’t help you there.
I think a FET driver is the only way to go brighter. I haven’t put it through the paces yet. After a typical 40 hour work week I’ll check the batteries. I’m usually at 3.6 to 3.8 volts. I think the FET drivers start out bright then get noticably dimmer as the voltage drops. Constant current drivers tend to be more consistent with output as the voltage drops. I’ll have to wait and see how this FET driver acts.
The other reason you might want to swap drivers is for the ramping firmware. I have to admit, it’s pretty sweet. Plus I can finally program out the blinky modes as well. One click on and one click off with the side switch is what I always wanted with this light. Plus I have the lighted side switch to help me find the button. Just perfect!
You’d better contact Lexel quick if you want one of these drivers as he’s about to start making the next, and maybe last, batch.
MTN Electronics also has a FET driver, but it doesn’t have ramping, just brightness modes.
A 3rd option would be like DB’s driver. A FET that he flashed with TK’s ramping firmware.
What I should have done was solder the led power wire to the driver and the switch and put the resistor in the middle of the wire and cover with heatshrink. It’s kind of difficult getting the switch in the hole with a big resister soldered to it.
The resistor is your basic “through the hole” type component that was used before smd. The color banding tells you the value. It’s easier to use a multimeter, though. They are way tougher than smd resistors.
I got 2 big variety packs of them at Radio Shack, which was closing down. They were liquidating parts. The carbor film resistors were all gone, but they had these metal film style left. Normally $10 a box, I got them for $1 each.
I could send you some 5k and 10k ohm ones if you want.
Thanks for the info. I used 20 ga silicon fm driver to xhp-70 on mine. My cheap meter says not to run load more 10-15 seconds, so I’ve been only doing about 5 seconds.
If your using a multimeter your never gonna get accurate results. Clamp meters are the way to go. Most folks on this forum use the Uni-T UT210E. There were some coupon codes for it at Banggood for $28, but I think they expired. I ended up buying mine on Amazon for $38. It’s a great ammeter, but so so voltmeter. It’s got the features I need like auto turn off so I don’t run down the battery. I hate that!
This time I covered the resistor in heatshrink for safety reasons. On the 3rd one I build I’ll put the resistor floating in the middle of the wire for durability reasons. I broke the connection between the resistor and the switch getting the first driver out to put the TA driver in. Gotta revise the design.
Couldn’t we just take power off the #8 leg of the MCU for >5.5V as controlled by the Zener or LDO? Then it wouldn’t take as high a resistor value because the voltage would be closer to the SMD LED requirement. Am I thinking right? I know the MCU has a 5.5V max, so…
Thanks Jason, I think I’ll just use an old pcb and carve a block out of it with 2 pads on it for my resistor to solder to, then I can put it inline on the positive lead and the metal caps on the resistor won’t be holding the wire, the board will. That should work.
