It will be 2s 26650, emitters will be (3p-4p), same setup as my previous mod. Iâm in the process of fabricating and ordering parts for this new high output thrower. :laughing:
So true. The search feature is a good resource but the best index is the active members who remember whatâs been done and where to find it or are willing to look.
A bit more work on a triple C8 using a kd 40mm reflector. I used the led centering discs to locate the stars in a pour of JB weld on a ziplock bag(doesnât stick) then made up a thin brass buss bar. Then cut the ends off a perfectly good battery tube and sanded them down just past the tube stops.
I hope so. :laughing: If you look at the middle pic you can see a step in the ID of the left hand tube end. Itâs there so that the tube can slip past the pill at the driver. Both ends get reamed to that larger ID to fit the brass sleeve that joins the two pieces electrically. Clearing the pill in this instance can be accomplished by backing the pill up into the head ~1mm(the copper spacer has a hollow partially filled by a 1/4â thick aluminum slug) or by the simple expedient of shortening the tube threads by the amount needed. I have a brass pill for this light as well that will get loaded as well so I havenât decided which way to go or whether another option exists.
Hi everybody!
Iâve been lurking here for a while and I thought what best first post than one showing my modded lights
So here they are:
On the top is a thrunite th20 which I emitter swapped to a sw57k 219b.
Left is a zebralight sc600fd, with a minus green filter on the lens to correct the greenish tint ( not cool having to do this on a $100 light :person_facepalming: , but on the other hand I love everything else about it ).
Right is a jaxman m8 with a shaved dome sw40k 219b and the convoy biscotti driver.
Here are some beamshots ( 5000k wb, from top to bottom: th20, sc600, m8 )
Now these may be some fairly simple mods, but I have a feeling I will be doing increasingly complicated stuff as I fall deeper into the rabbit hole
Iâve been considering this myself. With a Lee eighth minus green my sample of SC600Fd would become pretty much perfect on H-modes. Would eat about 10% of output though and isnât quite enough to correct the lower modes which are greener.
I did an emitter and driver swap on an Ultrafire MCU-C88 that I had lying around. Replaced the original XR-E and 3 mode driver with an XM-L2 U4 and a 1.9 amp QLITE Rev.A driver.
Using lithium primary AA cells and an integrating sphere at work, it measured 123 lumens out the front with the original setup and 535 lumens after the swap.
Iâm rather pleased with the upgraded performance.
I upgraded my motherâs SRK. It was completely stock, one of the first batch of SRKs available in black, and IIRC it did 2500 lumens in a cool white tint. I gave it a 32x7135 driver with the Ferrero Rocher ramping UI, which should increase output a bit and lets it ramp to any of 64 levels from moon to about 3000 lumens.
Itâs pretty close to what the BLF Q8 was originally intended to be.
I think itâs funny that she calls it âthe small lightâ, given that a SRK is one of my biggest lights. But then, âthe big lightâ is a Fenix TK75, so I guess thatâs fair. Iâll have to borrow the TK75 sometime to upgrade it too. It could really use a set of XP-L HI emitters.
Your mum is a lucky girl TK. I cant imagine my mum with a light like that. Sheâd probably have a heart attack.
The Ferrero Rocher firmware you used. Did it need modifying to work on the 32 x 7135 driver?
