xp-g2 is a led i really like , especially for pocket rocket mods .
Today i had my modded ut02 (dded xp-g2 , 300kcd) with me , every single time it amazes me
Unforunately took a sh**ty pic :
This is the cheapest way that I know of to get some good lumens out of these cheap SRK's The copper disks I use come from "Metals Direct". I then work them down to the right size with an angle grinder and a file, finish them off by using a disc sander, working my way down to fine grit. I use a good thermal epoxy to bond the two together. Do this first and then you can drill out holes right where the holes are on the original MCPC.
You can then piggy back a BLF driver with a low resistance FET. If you want to go whole hog you can mount noctigons but I find that as long as you are not using super high amp batteries this works fairly well. Because I build my own drivers and the copper is fairly cheap it's just about a $6 mod. This light I did a little more and added three High CRI neutral XM-L2's to the mix. I found them too dark to use on their own but when mixed with cool white emitters, they are really nice. Someone had them on sale a while back and I bought a bunch of them. So altogether this was about a $14 mod for me and it's now hitting about 4,000 lumens OTF and the tint and beam are superb. Ramping driver and although it does have parasitic drain it locks out easy enough. (Need to start doing Tom's driver instead). I won the light on evil bay for $11. So it's a total of $25. Not bad for such a nice finished product.
Did you preserve the on board charging?
Modded a Skyray King with 3x Nichia 144 90CRI. Kaidomain DTP-Boards. I used Terminal-Pad for + and scratched the - Pad a little bigger. Battery+ is now on the Flashlight-Body.
3x 4,2A AMC-Driver.
Used tripple Optik from DX: http://www.dx.com/p/48-16mm-3-led-reflector-for-cree-emitters-glass-like-plastic-1916
I got round about 4300 Lumen.
I have to add some AMCs, 2 per Emitter/Driver.
And I have to mod the Battery tube to 6V. Now I have used my Tube from my 3x XHP50 SRK.
Sounds really nice.
I have old maglite magcharger. I tried to disassemble it and then I managed and yet I had no clue how to modd this light so I give up. That is something completely different to modd than classic lights.
my friends,i cant remember,but i think,somebody put xhp50 into convoy s2? sadly search doesnt help.anyone rember where is the project?? thanks
Should be a very simple mod. Zener mod the driver and swap emitter. The orange peel reflector should give a nice smooth flood.
okok but probably on two 18350 right-not one 18650
My first attempt at de-doming
Did it on X6 BLF edition with XM-L2 by lifting LED of aluminium heatink, then I turned on flashlight for 10s to heat up LED and peeled off dome with some toothpick :sunglasses:
It went easier than I thought. Unfortunately NW became warm tint
UTorch UT02 Mod. My very last old school XP-G2 De-Domed nice Neutral Tint, 30mm T/A Lexel built Narsil driver Powered by Sanyo 20700A or IJoy 20700 cell made in Japan? Both batteries drive it hard and I have seen 6.45amps at the hit.
Changed out the e-switch button, heavy copper braid rear spring bypass, 2mm thick copper ring driver retainer, cleared the ano off the driver pocket shelf. 6.32amps at the tail cap both Sanyo’s and IJoys read real close to the same.
Really like the Narsil ramping in bigger XHP70 lights, but it works out well in this torch too!
6.32 amps on xp-g2 ??
Never seen one over 5.2-5.4 amps
Despite the change in tint, are you happy with the throw now?
Kawiboy is translated as WOT.
(That’s Wide Open Throttle for those that don’t recognize the term.)
Yep old school XP-G2 got them back in the day at IO during my TK61 XP-G2 Mods. UT02 board after re-flow hooked directly to a 3 year old Red Efest 26500 test battery on the rock. (sink) Flux smoke 6.12amps at 30seconds. De-domed it, in the light, upside down sitting on a thimble of Imron thinner.
Those 20700’s kick it up a notch! Just over 7+ amps in my XP-LHI V3 lights too! :+1:
Awesome kwb !
Would love to have older xp-g2
The local police were kind enough to remind me last night that I had a headlight and license plate light out on my old 1999 Mazda 626. So, for various boring reasons, I couldn’t just replace the bulbs over the license plate, so I got the LED replacement, and just soldered it in where the old fixture used to be.
Before (attempting to install the LED bulb with the old fixture):
Almost done:
After I finished soldering, and “potted” it (with hot glue), it worked. Since I also replaced the headlights, hopefully I won’t get another visit from the po-po tomorrow night. Assuming it is still working then
I modded a Olight SR90 intimidator today.
I bought the light as a host. I have no idea what happened to it but the insides were a scrambled up mess of shredded wires. The battery pack was still solid but I wanted to turn it into something I could use standard 18650’s in. Surprisingly easy mod actually.
I started by ripping the battery pack apart. Inside were 6 samsung 2600mAh pink batteries. Some of my favorites actually. They were still all holding a charge and after testing were still right at 2600mAh, so that was a nice bonus. On the negative end of the pack there is a board that connects to the tailcap electronics. I took that board our, scratched the traces clean for spots to solder three springs onto. There was a spot where the negative wire was soldered. On that spot I soldered a piece of silver braid and folded it around and soldered it to the back side of the board. I then sanded off a spot on the inside of the battery carrier to match that silver braid. Very tight fit so it was perfect. I cut a piece of thick paper to cover the electronics between the board and the electronics. Now I had my bottom set up pretty much like a SRK.
I stacked my six batteries inside and tested to make sure that each of them was making the proper connections. I then cut three pieces of dowel that would slide in-between the batteries and up against the inside of the battery carrier. Once I knew that they were all going to fit and work correctly I took them out one at a time and applied JB-weld in a line on the dowels that would epoxy the dowels to the side of the battery carrier. I then used a small dowel to jam down the center really tight. This held the dowels in place while the epoxy dried. It worked perfectly. I now have a SRK type battery carrier for 6x18650.
For the positive end I used a old SRK driver, wiped clean of parts as a contact board. About an 8th of an inch needed to be filed off the sides to make it fit and I needed to solder a strand of copper wire around the edge for the negative to make contact.
From that contact board I hung a BLF FET driver and used it to power a de-Domed XHP-50.
The side switch fit a horn switch and threaded in perfectly with it’s own nut behind it and it didn’t need to be modified at all.
So now I have a OLIGHT SR-90 Intimidator that runs on standard 18650’s using a DD FET driver (Ramping IU) running a de-domed XHP-50.
To say it’s a super thrower is a bit of an understatement. It easily lights up trees at a kilometer away.
