Trustfire TR-J12 measurements (5 x XM-L)
Well i'd say don't mess up the expensive AWs with this. The Trustfire Flames 2400 protected work fine (remember to do voltage tests, they will tell you if both are matched), just buy 8 of them from dinodirect and use that $5 off from $30 purchase coupon. :)
And Senybor 2800s? I probably cant use the AW as they are 2900s and have no positive nipple.
Damn glad to see the J12 get the 2100 treatment. Fantastic work and now you can trust me when I give you lux readings. LOL I honestly though the J12 might edge out the DRY, but that's OK. Its a testament to how well put-together the DRY is.
I get the almost the same currents with the KKs as you are with 18650s. 3A still isn't that much of a challenge for good 18650s. Keep in mind that since it is wired in parallel, the fewer the cells, the closer the battery voltage is to the Vf of the LEDs and that results in the driver working more efficiently. That explains the better performance on 2 cells and a good reason to have four cells (2 for backup) and throw out the extender. :) All of my lux testing has been done with 3 cells, so I think I may try 2 x A123 cells. :)
Thanks for measuring the PWM too. I knew it was low. I'm generally not bothered by it, but I think I've found my threshold.
Yeah man, for lights of this nature, I think there is no need for long distances to measure. 8 metres is plenty.
Update for benckie
I even got a customer service email to ask if the order is correct and everything is working in order. Great!
Hi 2100,
Is the Tr-J12 a flooder or thrower??
Hi Hugob,
The TR-J12 has a somewhat floody beam with its pretty big hotspot, but in that bit hotspot there is a lot of light hence it also throws pretty ok. For example, if you compare this to the Fenix TK35, this one would have a slightly brighter hotspot of about 20% more intensity.
Thanks 2100, cannot wait I also order one from Manafont, hope so see it around 20 - 25 January...
I also got mine from the same seller. Left a positive feedback on that page to. Mine doesn't have a plastic cover or a brass piece on the driver, though. Didn't matter for me so its as good as 2100s. I measured something like 2.2A with 3x18650 at 4.1V. Not bad I guess. Definitely brighter than my 3xXML I got recently. Tailstands perfectly. It will be a great ceiling bounce worklight for my dark, confined parking space.
I think you need some good batteries for this light.
If I am understanding this correctly, if 4A is going to the LED's, then each LED is only seeing 800mA for about 300 lumen each. All together the torch is putting out about 1500 lumen and that seems to match the numbers you are coming up with in your tests. This light is remarkably underdriven.
How much room is in the pill for a different driver? If you could put a 10A SST90 driver in it running the LEDs in parallel you could easily have it pumping out over 3000 lumen OTF. Of course I would only run such a beast on 3*26650 cells.
I guess it is more like 4.1 cell voltage x 3 cells x 2.2 amperes x .90 efficiency / 5 LEDs / 3.4 Vf = 1.42 A per led in my measurement. Makes over 500 lumens per emitter easily.
Guys, just got mine. First comments:
The bad ones, Silly PWM,silly disco modes, i don't like the button in the back, wish it was on the side. no UCL, can't find either one!
The good ones, excellent quality for the money and for a trustfire, too many battery configs available, good heatsink design,excellent square threads, generally nice design.
As for performance, see everything else and last one the trustfire:
OTF lumen, white empty room, 30sec measurements:
Itp xp-g S2 eos A3: 67 lumen
Fenix LD15: 96 lumen
Zebralight H51: 155 lumen
Olight i1 eos(cr123): 242 lumen
Nitecore ife2: 256 lumen
Jetbeam BC20(17670): 266 lumen
Zebralight SC60: 288 lumen
Armytek Predator: 343 lumen
Olight Baton S35: 382 lumen
Defier XT: 500 lumen
Defier X3: 600 lumen
Thrunite Catapult V2 XM-L: 740 lumen
Eagletac M3C4: 780 lumen
Fenix TK60: 790 lumen
Fenix TK35: 860 lumen
Trustfire 3*T6: 1470 lumen
Skyray 3*T6: 1610 lumen
Fenix TK70: 2290 lumen
Trustfire TR-J12: 2386 lumen! WTF?????? (was a bit more and dropped@30sec!)
My new lumen leader! I posted the others for comparison, to show how other flashlights perform in the same test method. Trustfire tested on 3 AW 2900, 2,17amp draw. Are you kidding me? I will redo and redo the test to be sure, but this is sick, what can i do more?
The flashlight starts@1sec@ 2430 lumen and gradually falls. Middle level is 1460 lumen and the lowest 310.
Well to be honest i don’t know why am i getting so high measurements. I don’t know if there is anything wrong, but the readings on it are really really high. 2386 OTF means 477 per emitter, which is really high for about 1,5amp@emitter, Armytek predator gives 1,5amp to the emitter,with UCL and with a good xm-l U2 i got ~473 lumen OTF.
Almost all of the other measurements i have posted, agree with what others have posted too, except very few. What if i had a UCL? i would be over 2500 OTF??? THis is sick!!!
(The UCL from M3x does not fit, needs 1mm less.)
Something more, my sample came from Kaidomain.
Well maybe we can do a group buy of UCL lenses (kinda like what mitro wanted to do) :D
And i hope all production models are the same cause im getting mine from MF.
Good idea!!!! I will talk to flashlightlens! The same lens would fit the Fandyfire STL V2 thrower, the M3X copy. Should i open an interest thread?
Depending on price, I would be interested! and Im sure 2100 will be to
Sent them an email regarding quantity they need and price they offer.
IMO TR-J12 lens looks like coated glass lens (compared with my flashlights e.g.M2XC4 ), It’s clearly than stock lens from many flashlights
From MF : Lens: Vacuum Plated Coated Glass Lens <<< ???
Good point: How can we tell UCL from other lenses? Any ideas?
