The honest answer is that I have not (yet) used filters on Nichia LED’s because the offset from the BBL has been acceptable as is (offset lower than 0.003 - that is slight green/yellow. Green for CCT’s higher than 5000K and yellow for CCT’s 4000K and lower).
Today I made a test with some lights with Nichia 219C 4003 from clemence and Nichia 219C 4005 from Wfans and from KD. To make it easier to judge, I converted color coordinates (xc,yc) to CCT (in Kelvin) and offset from the BBL in units of 0.001, like this:
Color point example: 4250/3 (CCT / tint offset).
As 3 is positive the tint is to the green side. If negative to the magenta side.
This means that the color is 4250K and lies in the (shortest) distance from the BBL of 0.003.
0.001 is considered the smallest offset a human can see by comparing. 0.005 is easy to see and is approx. the amount that one layer of filter 279 changes the tint offset. A side effect of 279 is that it also draws the color some 100-200K towards warmer.
I do not have the Nichia 219B 9080 to compare with (yet), but here are results for 219C 4000:
(sorry, I have trouble with the Table editor, hope it is readable anyway).
table(table#posts).
|before | with filter | LED | vendor|
3959/1
3823/-3
4003
clemence
3961/3
3823/-2
4003
clemence
4033/1
3863/-4
4003
clemence
4322/-3
4223/-8
4005
Wfans
4066/-3
3894/-8
4005
KD
The LED’s from clemence has a rather yellow hotspot that looks much better with the filter. The spill becomes somewhat magenta, like from a 219A 4500. Interesting is that the LED’s 4005 from Wfans and KD does not need a filter.
But that could just be one lucky batch.
Here is how one layer of filter 279 worked for some other lights I put them in.
table(table#posts).
|before|with filter|LED|filter|
|4531/10|4381/4|xml T6|279|
|5673/15|6006/12|xml T6|279|
|5506/16|5686/12|xml T6|279|
|4007/8|3894/5|xml2 T5|279|
|4791/5|4584/1|xpl hi 3a|279|
|4552/10|4406/8|xpg R4|279|
Using other filters, 206 orange and 278 plus 1/8 green:
table(table#posts).
|before | with filter | LED | filters|
10088/5
6498/8
chineese
206
9850/-13
6614/-7
xpg2
206+278
11950/-13
6235/-4
chineese
206+278
No need to toss all the bad LED’s when a filter can do the job.
I’m sorry for not providing pictures, but it needs a better camera than mine and I doubt that the small differences involved can be seen on a picture anyway.
Regarding the concern about the filters being exposed to high temperatures, consider that they were developed for stage floodlights. What I found negative though, is do not rub them with water or spirits, the color will wash off.
Have fun and good filter hunting.
The change in color temp is very interesting. High temp gets higher and low temp gets lower?
The leds I have are 219c from clemence and yes they are yellow to me. I am very intrigued now. I don’t mind a bit of cct shift or the loss in output. The 219b has a lower output anyway. I was going to sell them off and wait for some 219b but I just might give this 279 filter a try and stick with the yellowish 229c.
Just a note to readers: when I say yellowish, I mean compared to other earlier nichias. When comparing to a cree led the 219c actually seems less yellow. I don’t want to give the wrong impression of the 219c.
Another thing about filters is, they are usually designed for ‘white’ light as input, or at least broad spectrum.
But LEDs don’t make white that way, they make BLUE, a very limited wavelength, then that goes through something that absorbs the blue and emits a YELLOW, again a narrow band of ‘colors’.
So if you are trying to make it come out green or red, it will be very inefficient.
notice the 86.5% transmission rate, that means the filter will reduce the brightness by 13.5%
for example a 300 lumen level without the filter, would become a 260 lumen output when filtered through minus 1/8 green
I agree the 219c tends to be more yellow/green (varies by CCT) than the 219b
the 2 photos I reposted above, do NOT have the filter installed
the photo of the Manker Lad 219c is a 4000k led, and the 219b Worm next to it uses a 4500k LED
in the 4 beam photo I reposted (not mine), the third from the left, with the green tint, is what a 5000k 219c looks like. The 5000k 219c is more green than the 4000k 219c, but both are more Yellow than a Nichia 219b that has pink or magenta tint (not all N219b are pink btw)
note Im quoting indigo, you can contact him directly by following the link I posted,
in that thread he posted this picture, below, of a 5000k N219c after adding the minus 1/8 (far right), and compares it to an N219b 4000k, unfiltered (far left)
click the pic to go to that post for more info
Ya, sorry. I just started being lazy and dropped the 4500k 9080 from the 219b. Most of that emitter do have a hint of magenta/rosy as we say. Though some more than others. Thanks for the photo. I’ll do some more reading in the threads you linked.
Just got a Lee Filter #279 and put it in my Emisar D4 with SST20 4000K 95 CRI.
I do wonder if it is going to overheat and melt into my lens and optic. At peak power, the little 24mm circle of film is absorbing close to 600 lumens of light.
However, the D4 won’t sustain turbo for long, and within 30 seconds, absorption is probably down to 100 lumens or less. Still… it’s an offly tiny bit of plastic to absorb such heat.
Don’t use the lee filter over high powered LEDs unless it’s a zircon filter. I don’t think it will straight up melt, but over time probably fade and maybe bubble.
I’ve had a piece of Lee 249 1/4 minus green between the optic and glass of my 219C D4 since December. I run the light on turbo fairly often. No issues yet.
I have a gigantic sheet of the stuff. Enough for at least a hundred Emisar D4 flashlights. If the filter degrades over time, I’ll just cut another one.
I installed a Lee Zircon 805 Minus Green in front of my Noctigon Meteor M43 5000K 219C and it removed the green tint and made it look almost identical to a 5000K Nichia 219B. I was bothered by the green tint, and the filter now made the light much more pleasant to use.
I’ve even put Zircon Minus Green 802 and 803 in front of my high CRI Zebralights. I enjoy using them so much more now and the loss in output is well worth the trade off.
Where’s the best place to get these minus green filters economically? Would anyone be willing to sell a segment of their sheet? I can’t see using more than like a few inches of the stuff, but everywhere I’ve checked on-line so far you have to buy a huge sheet of it (2 feet long). I checked on those filter swatch books that are offered pretty cheap, but it’s a flat rate of $7.50 for shipping and then I’d be stuck with a bunch of filters I’d never use.
yes it has the minus green, 1/8, 1/4, 1/2, 1
it also has other filters such as bastard amber 162, marlene #506, amber #775, amber #774, that someone I know mentioned using… so I liked that I could compare what they used, to what I like… I prefer 1/4 minus green… the filters are all marked with the light transmission rate, so you can know how much you are giving up in lumens…
and I have played with some green, and red filters too
I even put a green filter into a plastic bottle cap, that fits over my Novatac and HDS, so I can pop it on and off… all good fun… cheaper than a movie
just do it! LOL!
the swatches are 1.5” by about 3” of useable sample, the book is over 2” thick… there is even diffusion film
Make sure that you buy the Zircon filters if there is any chance at all that they become warm during use (usually when the lens/filter is close to the LED => smaller lights). The standard LEE filters lose their function quickly if they become warm.
at the very least, I recommend the swatch book as a way to test the filters, so xevious can experience them, before spending money on the premium Zircon ones, and so he knows which one he needs, or wants
