I’m a bit lost in all that led’s
Can I put this 70.2 in Convoy L6 without modification?
Or if not what should I mod?
Yes you can!
If your using the stock driver this 70.2 would fit just fine.
If your using a FET driver, then it may pull excessive amps.
Thank you so much!
I’m using driver from Kaidomain, but it’s almost the same as original, only different firmware.
http://www.kaidomain.com/p/S025253.CF-FX-30-30mm-5_5V-9V-5-Mode-Driver-Circuit-Board-with-Electronic-Switch-for-Cree-XM-L-XHP50-XHP70-MTG2
Also did resistor mod, added R100 resistor.
Got to order 70.2 then
It should be great in L6 with SMO reflector I have
Did you get the driver that has the 3 modes plus standby?
can you dedome it too?
djozz: XXX-Man:I’m a bit lost in all that led’s
Or if not what should I mod?Yes you can!
I don’t know about removing the dome, but you can easily slice it off.
Digikey has the XHP70.2 in stock now.
Has anyone sliced the dome off one of these yet?
I’m curious if the color gets warmer, how much output you lose and if it still has the yellow corona.
So far everyone that’s shaved the dome on one of these ‘new phosphor’ emitters has gotten reduced intensity and lumen output.
I think ONE person managed to dedome one? Can’t remember for sure.
XXX-Man:Thank you so much!
Also did resistor mod, added R100 resistor.Got to order 70.2 then
It should be great in L6 with SMO reflector I haveDid you get the driver that has the 3 modes plus standby?
Yes, same as you got.
Fasttech has the XHP70.2 P2 1A in stock too for $13.16
https://www.fasttech.com/products/1609/10036285/7908500-cree-xhp70-2-p2-1a-4292lm-6000k-led-emitter
I’ll wait for the 3A tint though.
How hard are they to reflow? Would the P2 bin 1A be big improvement to a stock Acebeam K60?
Member MEM was able to truly dedome the xpg3 and other new emitters. But it was his trade secret and he’s been absent from here for 8-9 months.
With driver mod, there should be a similar improvement as on the MT07: Haikelite MT07 mods. - #18 by Tom_E
https://www.fasttech.com/products/1609/10036285/7908500-cree-xhp70-2-p2-1a-4292lm-6000k-led-emitterI’ll wait for the 3A tint though.
Is that dtp or just copper board?
https://www.fasttech.com/products/1609/10036285/7908401
Jerommel:Fasttech has the XHP70.2 P2 1A in stock too for $13.16
DTP by the looks of it.
You can see the round cornered rectangular thermal slug stick through the dielectric layer.
Can anyone report out on how the 70.2 performs in the SMO L6 reflector? Any donut hole? Lux?
Thanks.
Thank you Jerommel, I see it now (when I know what to look for) :+1:
Thanks.
No donut hole for sure
