XXX-Man
(XXX-Man)
June 8, 2017, 10:20pm
198
Thank you so much!
I’m using driver from Kaidomain, but it’s almost the same as original, only different firmware.
http://www.kaidomain.com/p/S025253.CF-FX-30-30mm-5_5V-9V-5-Mode-Driver-Circuit-Board-with-Electronic-Switch-for-Cree-XM-L-XHP50-XHP70-MTG2
Also did resistor mod, added R100 resistor.
Got to order 70.2 then
It should be great in L6 with SMO reflector I have
JasonWW
(JasonWW)
June 8, 2017, 10:39pm
199
Did you get the driver that has the 3 modes plus standby?
JasonWW
(JasonWW)
June 9, 2017, 2:22am
201
solRNY:
djozz:
Yes you can!
can you dedome it too?
I don’t know about removing the dome, but you can easily slice it off.
djburkes
(djburkes)
June 9, 2017, 3:29am
202
Digikey has the XHP70.2 in stock now.
JasonWW
(JasonWW)
June 9, 2017, 3:57am
203
Has anyone sliced the dome off one of these yet?
I’m curious if the color gets warmer, how much output you lose and if it still has the yellow corona.
Enderman
(Enderman)
June 9, 2017, 4:24am
204
So far everyone that’s shaved the dome on one of these ‘new phosphor’ emitters has gotten reduced intensity and lumen output.
I think ONE person managed to dedome one? Can’t remember for sure.
Jerommel
(Jerommel)
June 12, 2017, 9:46am
206
AlexGT
(AlexGT)
June 12, 2017, 11:35am
207
How hard are they to reflow? Would the P2 bin 1A be big improvement to a stock Acebeam K60?
Speed4goal
(Speed4goal)
June 12, 2017, 12:30pm
208
Member MEM was able to truly dedome the xpg3 and other new emitters. But it was his trade secret and he’s been absent from here for 8-9 months.
With driver mod, there should be a similar improvement as on the MT07: Haikelite MT07 mods. - #18 by Tom_E
XXX-Man
(XXX-Man)
June 12, 2017, 5:03pm
210
Jerommel
(Jerommel)
June 12, 2017, 5:57pm
211
DTP by the looks of it.
You can see the round cornered rectangular thermal slug stick through the dielectric layer.
JaredM
(JaredM)
June 12, 2017, 6:42pm
212
Can anyone report out on how the 70.2 performs in the SMO L6 reflector? Any donut hole? Lux?
Thanks.
XXX-Man
(XXX-Man)
June 12, 2017, 7:39pm
213
Thank you Jerommel, I see it now (when I know what to look for) :+1:
JasonWW
(JasonWW)
June 13, 2017, 12:59am
215
I had a donut hole with the 50.2. It’s not so much the gaps between the dies that make the hole, it’s the emitter size. You can mostly make it hard to see if you adjust the reflector depth. It’s not too noticable in outdoor use, unless you shine it on a building side.
You can also try and offset the emitter slightly to get the hotspot smoother.
I think the closer dies on the new emitters make the dark center, less dark compared to the older emitters. I have pictures if you want.
I’m assuming the xhp70.2 will be the same as the 50.2. Less noticable donut hole, but still there.
Tom_E
(Tom E)
June 13, 2017, 1:02am
216
I posted that a ways back - black hole appears only if within 1 foot from a wall, further than 1 foot - no hole.
JasonWW
(JasonWW)
June 13, 2017, 1:07am
217
I’ve got pictures and video of the donut hole shaped hotspot from the 50.2 in my L6 with SMO reflector if you want me to upload them.
