18650 area lamp from 3aaa cheapie aka "polishing a turd"
36 posts / 0 new
snakebite
snakebite's picture
Last seen: 2 months 4 weeks ago
these are just long enough with the board moved forward to use 18650.
its a mix of the cheap whites it came with and warm whites.
sanded the front of the tube for good contact and a rough surface for ca glue.sanded the pill bottle for a close press fit.
the 4 i replaced with warm whites got their – leads folded over the board edge and trimmed flush with the top.this takes up the extra diameter and makes the contact.
pressed in level,thin coat of ca on bottle mouth,and press it in.
jb weld 5 minute aplied to outer edge of board on the inside for added strength and some heat conduction.
the phillips thing is a t5 fluorescent tube sleeve.that makes the spacer for the battery.
next one gets a copper disk with a chinese “poor mans nichia high cri neutral“luxeon clone led!
Edited by: snakebite on 01/10/2015 - 17:15
Fritz t. Cat
Fritz t. Cat's picture
Last seen: 3 years 8 months ago
Nice mod. I used to have one of those things in my car, until I saw a cell phone put out more light. Depending on the efficiency of the LEDs, it may be a very nice area light. Very compact and light weight.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
snakebite
snakebite's picture
well i wasnt satisfied with the light produced vs power consumption.
800 ma and it was anemic.
so i punched it apart again.cleaned out the jbweld and found that with a bit of grinding with a dremel i could make a us quarter a press fit!
yes my new ready made copper(mostly) slug costs 25 cents.
ground a flat on washingtons face and reflow soldered a “nature white” 3w luxeon clone in the center.
drilled a hole for the + at the edge and glued a circle of plastic cut from a old dish smartcard.used a contact from a hf magnet light.
pressed it in to about 3/16ths deep and a thin bead of jb inside.after it set i did the same topside and pressed in my pillbottle.
went from meh to very nice at about 1a on a hot 18650 settling to about 850ma.gets nice and warm but not hot.
looks like the free hf 9led will work for this too.
the ebay 3w nature white is surprisingly good!
now i want some in warm and cool.
snakebite
snakebite's picture
well v1.1 is the black hf free 9 led .
had to grind the quarter a bit.
this time i sprayed the bottle with matte clear.
less loss than sanding.a flattop unprotected 18650 just fits with the quarter in 3/16” deep.
plenty to seat bottle at the same time as i jbweld top edge.does double duty.
DBSAR
DBSAR's picture
Last seen: 3 days 8 hours ago
I made a few of these last summer for hanging around our campsites, in tents, etc. from the cheap $2 lights. The three, 3-AAA ones on the left have a single warm white LED & resistor, these will run for 10 + hours on even cheap 15-cent Zinc batteries, ( or 25 + hours on rechargables) the smaller three lights on the right have the same LED and a resistor added to their boost drivers, and get 8 hours run time on a single basic AA Alkaline battery.
snakebite
snakebite's picture
cool!
i doubted i was the first to do this.
i recognise the caps on the right as nozzle protectors for drink bottles.
but what are the rounded ones?
going to make some resistored units for long run too.whats nice is i have some 3 aaa holders with the long snout that will fit.
so if i run out of 18650’s i can fall back to 3 aaa.
DBSAR
DBSAR's picture
snakebite wrote:
cool! i doubted i was the first to do this. i recognize the caps on the right as nozzle protectors for drink bottles. but what are the rounded ones? going to make some resistored units for long run too.whats nice is i have some 3 aaa holders with the long snout that will fit. so if i run out of 18650’s i can fall back to 3 aaa.
the ones on the right are definitely water bottle caps. Smile the left ones were some random small round spheres i found and cut in two, then frosted them with fine sand paper.
snakebite
snakebite's picture
well the perfect diffusers were right under my nose!
i noticed some “paint pots” on the upstairs bench.
these are just short pill bottles ganged on a tree.only issues are i dont know where they came from.they are marked $1.99
and its hard to clean off the remains of the tree after cutting them loose.
its nothing horrible to look at.at 3/4” tall they do the job well and are compact.perfect fit to the i.d of the tube and the jbweld holds them fine.
i rough up the i.d and o.d where it seats to ensure a good grip.
warning!
k2 tffc has too low vf to dd.
hits over 2a!
.47 1/2w tames them.
3w luxeon clone ok dd..
“nature white” seems the brightest with k2 tffc 180 lumen@700ma very close.
DBSAR
DBSAR's picture
snakebite wrote:
well the perfect diffusers were right under my nose! i noticed some “paint pots” on the upstairs bench. these are just short pill bottles ganged on a tree.only issues are i dont know where they came from.they are marked $1.99 and its hard to clean off the remains of the tree after cutting them loose. its nothing horrible to look at.at 3/4” tall they do the job well and are compact.perfect fit to the i.d of the tube and the jbweld holds them fine. i rough up the i.d and o.d where it seats to ensure a good grip. warning! k2 tffc has too low vf to dd. hits over 2a! .47 1/2w tames them. 3w luxeon clone ok dd.. “nature white” seems the brightest with k2 tffc 180 lumen@700ma very close.
looking froward to see new photos. Smile
Pulsar13
Pulsar13's picture
Last seen: 1 week 6 days ago
I used some old frosted plastic bulb on a $3 Ultrafire S5, something like DBSAR’s half dome but I used the whole globe. Fits like a glove, no tape/adhesive needed.
I can’t remember which one exactly but pretty sure the LED bulb was one of the $0.01 promotion offer or something. This is why I try not to miss those Smile
snakebite
snakebite's picture
!2015-01-08_18-16-52_990!
!2015-01-22_17-28-11_263!
!2015-01-22_17-27-47_482!
Gunga
Gunga's picture
Last seen: 3 hours 39 min ago
Very nice turds!
snakebite
snakebite's picture
those last pics are of the 3rd rebuild of the prototype where it gets a diffuser upgrade.
DBSAR
DBSAR's picture
I just finished building a dozen more of these using various diffusers and $2 flashlights.
snakebite
snakebite's picture
did up 10 more here.
most expensive part being the quarter as a heatsink.
harbor freight freebies.
leds were free as i ordered neutral white chinese 3w leds for a job and got cool white.seller sent the right ones and told me to keep these.
and the batteries are free laptop pulls.
all my neighbors each have 1 or more.
we get lots of power failures due to storms.
one of these held to the ceiling from its lanyard with a tack or pushpin does a lot!
DBSAR
DBSAR's picture
snakebite wrote:
did up 10 more here. most expensive part being the quarter as a heatsink. harbor freight freebies. leds were free as i ordered neutral white chinese 3w leds for a job and got cool white.seller sent the right ones and told me to keep these. and the batteries are free laptop pulls. all my neighbors each have 1 or more. we get lots of power failures due to storms. one of these held to the ceiling from its lanyard with a tack or pushpin does a lot!
Nice. I found some other interesting LED cheapies at the local dollar-store that was shaped like an Incandescent light bulb with a hanging lanyard. I modified them with a better W/W LED and a resistor and they work great on 3-AAA cells for 14 hours.
Jubeldum
Jubeldum's picture
Last seen: 6 years 5 months ago
Gunga wrote:
Very nice turds!
Yes they are. Someday alkaline batteries will go the way of the buggy whip so these mods wont have to be done.
snakebite
snakebite's picture
nice thing about these is they can still be used with 3aaa if you have the holder with the extended + contact.
but even the best aaa are pathetic in these so 18650 all the way!
snakebite
snakebite's picture
big lots had a 10 pack of assorted camo patterns for 4.99 on sale.
grabbed the last 3 they had.they work fine in these mods.check local stores.beats playing games to exploit the hf coupons….
DBSAR
DBSAR's picture
snakebite wrote:
big lots had a 10 pack of assorted camo patterns for 4.99 on sale. grabbed the last 3 they had.they work fine in these mods.check local stores.beats playing games to exploit the hf coupons….
Nice find.
snakebite
snakebite's picture
these
you have to seat the quarter at about 1/8” from the front but otherwise they do fine.have to grind/sand the i d at the front as the paint/anodise is there.
power911
power911's picture
Last seen: 4 days 20 hours ago
damn
now I have a project to do
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
snakebite
snakebite's picture
another note.i have some pre tffc k2’s here i have been using.these must have a .47 to 1 ohm resistor in series or they pull way too much and overheat.
the output has minor rings from the smaller point source and the bottom of the bottle.
the chinese clones have a higher vf which eliminates the resistor and the larger area of the phosphor somewhat evens out the beam.
chenko
Last seen: 10 months 6 days ago
Well I would be glad to be able to make turds like those.
snakebite
snakebite's picture
can you easily get a u.s quarter?
or a local coin the same size?
rest of the parts are easy,cheap,and sometimes free.
snakebite
snakebite's picture
these
have a huge die in them.biggest die i have seen in a “3w” led.wider than an xml die.
they work great in the direct drive design here.
nw is ever so slightly yellowish.but brighter than the rest.
DBSAR
DBSAR's picture
snakebite wrote:
these have a huge die in them.biggest die i have seen in a “3w” led.wider than an xml die. they work great in the direct drive design here. nw is ever so slightly yellowish.but brighter than the rest.
those are the same ones i been using in various lantern conversions and small lighting upgrades for awhile. ( they are a clone of the original Luxeon Star design with its own “case” for the LED die.)
( both the 1W & 3W versions) I like the WW versions for lanterns, and some of the NW tint ones are not bad either. they do have a big die, sort of like a small version of a MT-G2 shape in a smaller lower power case) these wor great and easy to use for various Led lighting mods and lantern conversions with the side power connectors and smooth flat bottom heat sink plate. i have driven the 3W with 700ma before using a 2-7135 driver but they have to be direct contacting a good copper heat sink to survive. They are some what tougher than a regular LED as the die is covered with a hard acrylic dome instead of a silicone one like most.
snakebite
snakebite's picture
we had some high wind here that took the power down about 5 hours after dark.
just about everyone in my neighborhood was using these and the hf 27led modded ones.and i got orders for 20 more to fill.
not to mention folks showing me cheap lights and asking if they could be run on those odd batteries?mostly cheap 3aaa lights that infact can.
snakebite
snakebite's picture
well i created a monster.local cops saw these things hanging everywhere around my neighborhood last week during a power failure.
and asked about them.when i told the officer who came to my door that they were literally made of junk he wanted to make some himself.since he vapes and has hf freebies i told him the basics and gave him leds and resistors.i know where he lives and saw his kids hanging them in trees to light the area around the cookout.
and yes he knows about this place too.another down the rabbit hole!
DBSAR
DBSAR's picture
snakebite wrote:
well i created a monster.local cops saw these things hanging everywhere around my neighborhood last week during a power failure. and asked about them.when i told the officer who came to my door that they were literally made of junk he wanted to make some himself.since he vapes and has hf freebies i told him the basics and gave him leds and resistors.i know where he lives and saw his kids hanging them in trees to light the area around the cookout. and yes he knows about this place too.another down the rabbit hole!
cool Smile Since the originals above i have built many more myself, and some new models & styles, including a “penlight” lantern stick from $2 ebay 2-AA lights & 2-AAA lights, and others including as Cr123 model using the closes of Mini-01 light.
snakebite
snakebite's picture
i just made 2 of these for long runtime for my camping trips.
i wound up with xp stars with pads for a 7135.
used Sedstar neutral xpg,drink nozzle cap,and ebl 20650.
dimmer but looooonnng runtime.
better color rendering too.
