what is the easiest way to discharge single 18650 Li-ion cells?
9 posts / 0 new
Hot Brass
Last seen: 14 hours 25 min ago
I have a few single near full 18650 Li-ions that I would like to discharge(run down) for storage and be able to monitor the voltage with my DVM,so obviously installing inside the light and turning on won’t work. Can I rig up something using a battery holder and maybe hooking up a bare bulb in between the + and -?. I want to be able to monitor the voltage as it’s running down. Something easier? Thanks,HB
XsearcherVN,Ultrafire HD2010,Uniquefire UF-T20, Maglite 6 D-cell with TerraLUX led kit,Fenix TK-41(sold),Fenix PD12,OLight S-10 L2 Baton,Ultrafire C8,Tiablo A-9 with Collimator and Reflector Head,Maglite AA Mini Mag.,Convoy L6,Lumintop GT Nano,Nealsgadgets unbranded 26650 LEP.
LowLumen
Last seen: 5 hours 33 min ago
A 10 Ohm 10 watt power resistor would drain at about 400mA rate.
V/R=I
4V / 10ohm = .4 Amps.
comfychair
comfychair's picture
Last seen: 6 years 5 months ago
Monitoring the voltage while it's running against a load won't tell you much, you need to know the open circuit resting voltage, so just run them in a light and remove to check the voltage every 10 minutes or so. After 1 or 2 you'll have an idea how long it takes to drop how much voltage, so you won't have to stop to check as often.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 4 months ago
WarHawk-AVG
Hot Brass
Thanks to all who responded! That battery University link is great! HB
hank
hank's picture
Followup question from the Poll (left sidebar) “how do you store your batteries?”
http://budgetlightforum.com/node/54889/results
Which favorably viewed chargers have the “lithium battery storage” function?
When I have cells to store, I’ve been running cells down, then charging them at the 3.2v/LiFePO3 setting (Xtar VP2 charger) and figuring that’s about right for storage voltage.
But it gets tedious that way.
flydiver
Last seen: 1 day 13 hours ago
3.2v is on the low side if shooting for50%.
I don’t know of anything but hobby chargers that have storage function. It would be great if one did.
To Air is Human, to Respire….Divine.
RobertB
RobertB's picture
Last seen: 1 day 17 hours ago
Seems like it would be a simple addition to have a “storage” function on something like an opus charger, that would discharge or charge to 3.6v.
