I think I will hold off on the S1 at the moment. USD200 for a light with PWM is no-go for me, I'm afraid. If they remove, I might think twice. And like you said, the TK70 is just an awesome light!
Where do they get the 2800 lumen figure from?
If you are reading 6.2 amps, thats 2.1 amps per emitter which is what? 600ish lumens each?
The TK70 does 3 amps per emitter which is more like 850 lumens per emitter.
Joe,
(1) The TK70 does not do 3 amps per emitter. As far as my knowledge goes only forummers claimed that. It's probably pretty close, and anyway it's not worth to get into a debate with the other folks regarding this. I dwell more on measuring with the lux meter.
(2) This is U2, if you use the xls LED calculator and key in 320lm @ 700mA, you'd get 816 emitter lumens for 2.1A. You get 899 lumens for 2.8A drive for a T6.
https://budgetlightforum.com/t/-/2525 <<- calculator
(3) Just measured again by cleaning the MKNE IMR cell's surface and pressing harder, actually i was able to get 6.5A-6.6A peak. Unfortunately it's not really easy to measure.
(4) Important thing is, if you look above, TK70 reflected bounce is ~ 220 lux. Xtar S1 is ~ 210 with 3 x 18650. I was able to get this ~ 210 with the MKNE IMR as well with the tailcap screwed on. That is what is important and is accurate. The current reading is for reference only.
Yeah, the final measurements for output are what really matters, everything else is really just working back from that!
Remember that a good high capacity IMR 26650 even under load would be well over the forward voltage of the XM-L LEDs (maybe 3.9v under load fully charged with the XM-L vf of around 3.3v @2.3-2.5 amps) with the full calculation you get:
6.6 x 3.9 = 25.74
/100 x 90 (assume 90% efficient circuit) = 23.166
/3 (3 XM-Ls) = 7.722
/3.3 (each 3.3v vf) = 2.34 amps to each emitter.
According to the spreadsheet that means nearly 900 lumens for each U2, which would make almost the claimed amount at the emitter(s ).
hehe.... Redforest UK's calculations are deep....i understand part of it only at first glance.
Anyway Xtar S1 is 475Hz PWM for my copy (see if production copies are different), that's not too bad and very usable. Just received my 5 x XM-L Trustfire TR-J12, it's 124Hz. Now that's bad!
It's got very poor regulation compare to the Nitecore and Olight triple XML lights.
is this the most expensive DD light?
how2,
It's not DD aka Direct Drive. I think Selfbuilt chose the wrong word. If you apply his definition of DD, then each and every Ultrafire, Trustfire, Uniquefire is DD.
I measured only 6 amps plus at the tail. It should be approx 15A (good cells) at the tail if it were to be DD. heh.... Also with Direct Drive, it would never be able to do > 30 mins run, let alone 76 mins till the knee drops.
Selfbuilt has provided lots of data in CPF, hence i don't feel like it's nice to mess up his review thread just due to a bit of "semantics".
It certainly is not boosted as the current falls as it's discharged, because the 3 cells are in parallel. TM11 managed to pull it off though. Not the same experience as those with cells in series like TK70, TR-J12, Uniquefire 3900 and the likes.
You might wanna check out his graphs. 400 -> 300 in 60 mins. Drop of 25%. Can you see a difference between 75% and 100%, yes you can....try a thrower light that has 40k lux and 30k lux at a distant target. But in real life usage without A/B, no way.
TM11
XTAR S1
Seems unregulated compared to the other lights.
It is not regulated in a straight line, definitely. So it is not 100% perfect, that i'd agree. In fact many 2 x 18650 lights like Fandyfire STL-V6 has a flatter line regulation. A lot of 1 x 18650 lights like even the Jetbeam RRT-2 XM-L cannot maintain a flat line regulation till the end like the multi-cell lights. All 1 x 18650 light sucks? I just want to put some perspective into things. Maybe i may seem to be defending the light because I got a "review copy", but allow me to present my case.
This so-called lack of regulation is the least of my worries. Though the nearly 500Hz PWM is unobtrusive and very usable, it is still mildly visible and i guess to the purist flashaholics that is "not nearly enough" because Olight/Fenix/Jetbeam/Nitecore can do it anyway (which is true). The PWM needs to be pushed up to at least 1kHz....heck while they are at it just push it up to 5kHz (and be done with it) if they can't drive it by varying the current like the Sunwaymans. :D
This is the difference in throw output at a distant object, the difference is ~ 33.3%.
60k cd
90k cd
As long as we are talking about higher draw lights like in the 2.5A range (corresponding lumens in the > 600L range), it proves to be very difficult to do with single cell. Take for example, a Lumintop TD15X. Check out the 1 x 18650 curve. (this is Selfbuilt's work)
And this is the Thrunite TN12 and gang
2100 how much did you pay for this light?
They are trying to sell this light for $175.
usd175 is delivered i guess, direct from XTAR. I am not supposed to say, but of course it's easy to guess that i paid a slightly lower price (and taking a caculated risk as well as being an early adopter or rather tester!). I don't even have lanyard or O-rings!
The other dealers have not really got stock yet, i have asked.
It's better to get the Olight and Nitecore or Finex as they all seem to be better regulated.
2100 does the lens have a reflective coating?
The Xtar has a very inefficent driver as you can see from selfbuilt graphs.
The Xtar produces more light for the first 16mins, then the SR92 whops it's butt from then on.
Run time for Xtar on Max 1hour and 26mins
Run time for SR92 on 1hour 51mins
2100 why can you not say how much you paid for it?
Many reviewer get there lights for Free and they state this, some just say evaluation copy or review copy.
I'm a straight talker as most of you lot know. I said the Dry was ugly. I have no problems when people review lights that they get for free, I will always take the reviews with a pinch of salt.
What I do not like is when people are not clear whether they got it free or not.
Come on 2100 be a man and tell us.
Your challenge of 2100 is unnecessary and unwarranted.
He has contributed real data to this site, not just a bunch of "that torch sux" comments.
Agreed.
I think it's safe to assume he paid for it and wasn't given a free sample by Xtar.
I thought the SR92 battery pack contained 6x 18650 cells, this only uses 3 so it's hardly a fair comparison. I do agree however that the lack of regulation is not ideal and is a deal breaker for me, along with the PWM. Not that I need any more lights at the moment or in fact ever.. (I'm sure this won't stop me in the future though!)
A little known fact is that PWM actually uses current, (not only as it involves bursting the LED at a higher current and so doesn't take advantage of higher efficiency at lower current inputs) but each switch from on/off of the LED uses a tiny amount of electricity, this means that lower freq PWM is actually higher efficiency then high frequency, and is why zebralight originally used it in L2 mode of the H51 etc as it was more efficient to use low freq PWM than current control as the current to the LED would have been below optimal efficiency level. I'm not sure if this consideration comes into question when manufacturers are deciding what frequency to set PWM but it's an interesting fact.
I for one think it's one hell of a light. I even told Rick that last week on the phone. But I also can now say they won't be selling very many to US buyers for $175 shipped to the US. For that kind of money, I can buy a brand new Fenix TK70 for $164 shipped to my door.
