I actually found the UI diagram really unclear. What’s a dotted line? What’s a solid line? The only thing that was clear is the long-press that says “long press” next to it.
I’m sure there are several people here who would be willing to consult on and beta test new light ideas just for a couple free samples. I’m one of them. The low efficiency of the driver, battery crushing problem and ridiculously bad UI could all have been easily avoided.
Group2:Low,Med2,High1,High2 (with memory function,duble click the button,short press<0.5s)*
Double click and short press seems to change the mode groups, but not sure what the short press does, as I thought it would toggle memory but it doesnt. Then I thought it would be a way to change mode groups, but it doesnt…
Clearly is not how i would describe the way the UI is ‘explained’… and it is not quite consistent with the one we got.
Even the printed version that came with the light with additional instructions (if you have a microscope to read them) is not all that clear. I somehow managed to switch mode group by accidentally double clicking (how stupid is that?) and i had no clue as how to switch back… until i figured “configuration” must gave something to do with it… which seems obvious now. :person_facepalming:
I’m still not sure how i find myself in disco hell once in a while after turbo… This light seems to have a life of itself, unless the cumulative effects of face-blasting-with-turbo has already dented my cognition. :smiling_imp:
Could you really predict the actual fiasco just by looking at that diagram? I don’t think so. It could have worked if they did it right. And i guess that’s what we where all assuming they would do considering previous Astrolux lights. The problem is the translation from a physical tail switch to a side eswitch which is a first for them i believe.
Fully agree with you about the double click to change mode is really stupid.
By looking at the diagram before I ordered the light. I could see that you could only turn off the light from turbo only. And you stuck with the stupid disco if you long press into turbo.
Kinda makes me more stupid knowing this and still getting the light :person_facepalming: Guess I couldn’t help myself at the $25 price
Has anyone tried to replace the firmware? There are several options available with e-switch support. Apart from the battery issue this would make the light much more useful.
Easiest option would of course be to use the E14 II firmware. The hardware design seems similar enough for this to work. Maybe we could give it a try?
The UI is SLOW and could use some improvement, but it’s no real showstopper for me (the UNsafe lockout sequence does scare me a bit though). The USB cover is a joke, falls out all the time. But the S42 does produce a lot of wonderful neutral high CRI light, unfortunately not for long since it gets HOT fast.
With the new battery tube and new USB cover BangGood/Astrolux could have a winner on their hands. Especially if they let ToyKeeper improve the UI. A better driver with temperature controlled stepdown would also be nice.
that’s the same problem everyone has…the tailcap is not screwed down all the way to make the connection to the body. If you have a 18650 tube, give it a try. if not, just wait for the new tube.
Got my S42 the other day. An cannibalized A6 battery tube made the light work with a flat top unprotected 30Q cell. Don’t have any little cells so didn’t even need to try this. Wow, the UI truly is abominable. Dotted or solid lines on a diagram. It doesn’t matter. Major fail in my opinion. Glad the tail twist out works. Sorry Dragon Breath!
So, why do we even have to beg for replacement parts, proper length battery tube and functional USB cover, when BG knows exactly who they sent these to? Totally stupid. And did I mention that the UI is abominable? Yes I did already, sorry. Martin, you got your points. Help us out!
