I just pulled mine off, and reinstalled it with gentle prodding of a toothpick
Thanks for the tip! Making my S41 into a twisty is awesome!
now THAT is a small pocket rocket!, especially after I cut off that superfluous tripod mount and replace with a magnet.
Danm! Now I want an S42S tail cap for my S41S, just the tail cap!!!
Now with this mod, I can get 2 spare 18350’s in the bottom of the Manker holster!
And with the S41 tail cap on the S42, you can turn it off from any mode.
Sow’s ears are so sweet!
A Short S41 with twisty is one of the reasons I bought the S42.
Has anyone tried to replace the firmware? There are several options available with e-switch support. Apart from the battery issue this would make the light much more useful.
Easiest option would of course be to use the E14 II firmware. The hardware design seems similar enough for this to work. Maybe we could give it a try?
Regards
Christian
If you want a shorter s41, use the tailcap from skilhunt h03.
Thats what i said but thats the only way to fix the ui as some want.
Also a new head? That IS a new light…
Just received mine and I actually happened to have a battery that fits. It’s tight, but the Enercig IMR18350 ( Enercig IMR18350 700mAh - 14A - 18350 & 18500 - Li-ion - Rechargeable batteries | NKON ) does fit, if you screw on the tailcap carefully so the tailspring goes in to the recession it sits in.
The UI is SLOW and could use some improvement, but it’s no real showstopper for me (the UNsafe lockout sequence does scare me a bit though). The USB cover is a joke, falls out all the time. But the S42 does produce a lot of wonderful neutral high CRI light, unfortunately not for long since it gets HOT fast.
With the new battery tube and new USB cover BangGood/Astrolux could have a winner on their hands. Especially if they let ToyKeeper improve the UI. A better driver with temperature controlled stepdown would also be nice.
Just received the S42…DOA
No problem fitting a flat unprotected 18350….just won’t work….disappointed to say the least.
that’s the same problem everyone has…the tailcap is not screwed down all the way to make the connection to the body. If you have a 18650 tube, give it a try. if not, just wait for the new tube.
…or try to wrap a copper wire inside the tail cap. That will allow the tube to connect without screwing it all the way.
thats what i did for testing...
bent a copper wire around a 18650 cell (1 1/2 turns)
one cut to get a split ring
perfect!
but please ONLY use in the tailcap!
Got my S42 the other day. An cannibalized A6 battery tube made the light work with a flat top unprotected 30Q cell. Don’t have any little cells so didn’t even need to try this. Wow, the UI truly is abominable. Dotted or solid lines on a diagram. It doesn’t matter. Major fail in my opinion. Glad the tail twist out works. Sorry Dragon Breath!
So, why do we even have to beg for replacement parts, proper length battery tube and functional USB cover, when BG knows exactly who they sent these to? Totally stupid. And did I mention that the UI is abominable? Yes I did already, sorry. Martin, you got your points. Help us out!
That puzzles me too, doing it this way only means more work in total for BG and less happy customers.
Nothing happy, since apart from everything, it is horrible to use, almost impossible, and heats more than 80 degrees.
betcha it has to do with like the rebate thing
like maybe half just won’t bother…. :weary:
Regards
Christian
+1 is this even possible? Even if it is a very simple limited UI?? Anybody???
Got my S42 the other day. An cannibalized A6 battery tube made the light work with a flat top unprotected 30Q cell. Don’t have any little cells so didn’t even need to try this. Wow, the UI truly is abominable. Dotted or solid lines on a diagram. It doesn’t matter. Major fail in my opinion. Glad the tail twist out works. Sorry Dragon Breath! So, why do we even have to beg for replacement parts, proper length battery tube and functional USB cover, when BG knows exactly who they sent these to? Totally stupid. And did I mention that the UI is abominable? Yes I did already, sorry. Martin, you got your points. Help us out!
i asked bg to “just send the new parts“ but i was told the system does not work that way :(
for the UI we all knew its a new development
and we hoped Astrolux will do a good job
... but....
well, lets say they need at least one more generation ;)
i 100% can understand when one is disappointed - so send it back then!
why be angry and agressive?
some posts might qualify to earn a rude point... :(
if you buy a dacia you hope to get a Renault - but are you mad that you did not get a merc?
Well, the Nichia with CRI 90 are Mercedes parts.
I fear if they do a S42 2Gen, they screw it up again.
I would rather have a S42 BLF-Edition were the UI is good and tested by the forum.
Astrolux / Banggood needs an eSwitch firmware anyway for future lamps. So this could be a starting point like the A6 driver was.
Are the Nichia 219C in the S42 high CRI?
It seems unclear…
