ALIVE: Astrolux S42 groupbuy: US$ 25.95
I asked about it in my reply, they sent me a 15% coupon code.
…only applicable to a selection of lights….
Hmm…
A nice gesture that they know is no better than the typical.
Yeah, i edited my post…
Im pretty p!$$3d with BG and astrolux right now. got $65 in lights sitting unused, and most members here just say suck it up. Memory isnt listed in the A01 so NMM should be acceptable for a $20 AAA twisty light that originally had no memory. They are/will eventually send a new battery tube and USB cover, so $#!tty UI should be acceptable.
Bunch of sheep following the wolves.
Just got an email from bg. 2 unknown items just shipped.
I think its the tube and cover.
Did your “order” also show a cost of $1 for each item? I’m assuming the random order that’s now in my account (with no description of the items, mind you) is probably the USB cover and tube.
Yup, thats what the invoice showed.
The same here…
same for me
and for me
If you don’t like it, file a Paypal dispute and get your money back. It’s a light that was rushed, not well-thought out and many people (myself included) thought it would be a success, especially for the money. Mine wasn’t. Mine came with the front cap loose and when I tightened it, I heard a crack. It broke the carcio lens and dedomed the leds. I got a refund and will probably not buy an Astrolux again. Too many other good lights out there.
I think once you accept the replacement parts as a solution you can not file a PP dispute anymore…
yeah, it’s a bit like sheep following the wolves maybe…
Weird though, i’m still looking forward to a sweet GB deal for the S42S…
I got the 16% off astrolux coupon as well, and my $2 ‘order’ shipped today. My S42 works functions turns on and does not damage cells with the 18650 tube. My A6 will take the stock 18350 tube so I guess that’s good.
I’m hoping one of the BLF brain trust either figures out how to reflash the existing driver or builds a driver that will accept Narsil or Biscotti.
Stockholm syndrome?
( Stockholm syndrome - Wikipedia )
Thx for info about the light. BG said they replace tube so waiting until i recieve that.
Hope it all will work out well in the end. But less output than S41 ?.
LOL :smiley:
well, I am waiting for my 2buck chuck replacement parts to arrive
albeit with much less enthusiasm than I had for the original light
I have my Skilhunt H03 tailcap on mine right now and it’s working reliably
butt will not burn my fingers nor singe my mustache when held in my teeth
not exactly what I was expecting from the hype
think I’ll pass on this brand until they prove what they claim
…either way, it’s a host including LEDs on PCB as far as i’m concerned…
Good news is you can put in any driver when you solder an adaptor ring on it (when it’s less than 21 mm diameter),
because there’s enough room to put a reverse clicky in there, as a side switch.
And i ordered a micro USB rechargeable 18650 to use the charging PCB in stead of the stock PCB.
I already took out the switch boot and its bronze colored bezel and put a plastic boot instead, which doesn’t stick out, it is flush with the body.
I’ll put up some picks soon, when the card reading issues of my camera are solved… :person_facepalming:
So far from reading this is my conclusion
S41 is brighter then s42 ?
S41 tint is better for the same emitter type(XPG vs XPG / Nichia vs Nicha)?
btw. The new revision is now live on banggood, for GB price i will order one. UI is still a problem but i am buying this and put a 18650 tube from S41. Life too short to run 16350 :laughing:
