You are not right.
BLF-A6 / A17DD-L FET+1: does not work properly with lighted switch
This drivers were first that were made to work with lightened switch. For others like kdlight this is just hardware bug.
Well, the two BLF-A6 drivers (7/4 modes - NOT Bistro UI !) I have (one from BLF A6 and one from Astrolux S1) do not work properly with the lighted switch.
Precisely, I then get sort of “next mode memory”, meaning the driver is in the next mode after each off/on cycle, regardless how long I wait.
If there is any cure to this, would be appreciated !
However, the (similar) drivers with the Bistro UI work flawless !
Have you considered a Reylight Pineapple or Ti LAN? Install 1 trit in the tail switch and it is lighted and takes no power! The low is second to none, I have 4 and they are consistent and very reliable.
@mattlward: thanks for the hint, the Reylight Pineapple looks great and with the trit that would be a stylish option !!
@Lexel: yes, seen your thread, guess I need some of your drivers … Just coudn’t decide yet, which config.
[quote]
color every black flashlight with heat to a golden color[/Quote] …oops, as electrical engineer I wasn’t aware of that !!! Need to look into this …
The first post has all the info you need if you don’t want to read through all of them. You may need to experiment with different values for your bleeder resistor, but in the end it’s worth it.
