My first mods! An experience, for sure!
38 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 12 min 5 sec ago
So…I wasn’t sure if I would post about my first 2 mods here, as they are so insignificant compared to others made by the BLF members.
But then I decided I’d do it, as I’m “proud” of what I’ve done for the first time, and maybe other members can also benefit from what I’ve done and learned! Wink
Also, I’d like to say that now I understand what DB Custom said on my first post on BLF:
Hide your billfold, cut up your credit cards… you’re a perfect candidate for full blown flashaholism and will soon need dedicated flashlight cabinets. […] Have fun! Modding is next…Thumbs Up
Towards the mods! :ARROW-RIGHT:
1st:
Brand/model: Brennenstuhl 140 Lux Primera (24€)
Specs: 3xAAA flashlight / 3 Modes (High-Low-Strobe) / +-150 lumen / Cree XR-E Q5 – 6500K / Tail switch
Main goals:
1) replace the LED/emitter;
2) replace the driver;
3) convert it into a 18650 flashlight;
4) turn it into a more floody light.
These were the main mods I “wanted/needed” to perform because : LED stopped working, I didn’t like the UI, I wanted it to be more powerful and I wanted to stop working AAA batteries, I wanted to give it a floody aspect.
What have I done?
I measured the light over and over again to perceive what I should buy (LED, driver, reflector) and I searched for them in some online shops (AliExpress, Gearbest, Banggood, Kaidomain, Fasttech, Mouser) to get what I needed.
This is what I ended up buying (non-affiliate links):
- Reflector : https://tinyurl.com/yb9n9xbw
- Gasket : https://tinyurl.com/y9plk62c
- LED : (16mm plate, XML2 U2-1A) https://tinyurl.com/y8q8kpgo
- Driver : (Biscotti, 8*7135) https://tinyurl.com/y7ty8q6z
- Clear Lens : https://tinyurl.com/y8w6uaqf
I received the materials and everything fit perfectly! So I started the next phase!
To make the flashlight accommodate an 18650 battery, I had to drill and sand and file the pill, as the battery didn’t fit well.
However, the inner space was not enough yet , so I had to change something in the switch . I had to remove a piece of rubber “inside” the tailcap and I had to remove a plastic ring between the tailcap and the switch itself ! Then, the final setting was complete.
Concerning the driver, I did the normal soldering process to connect the driver and the plate.
I had some trouble with the thermal paste so it became a bit messy! Newbie here ! Eheheh Big Smile
I had a new aluminum reflector (Orange Peel) to use instead of the original plastic reflector (Smooth).
I wanted to use it, but during the process I realized that it was making a short-circuit !
The contact between the pill and the reflector was provoking a short, so I had two options: not use the aluminum reflector, or use it wrapped in electric tape. I opted not to use the new one, and I incorporated the original that is in normal conditions !
I replaced a plastic lens for a clear glass lens (I guess I couldn’t find an AR coated with the needed dimensions).
Conclusions so far :
I use it the biscotti in a 3 or 5 mode configuration (from ultralow/low to high, no strobes), and I guess that it doesn’t get too hot because of the pill configuration, as it absorbs well the heat!
It doesn’t have a floody beam as I wished but I’m happy with this beam, as in a wide range it has some throw and some flood, especially in night environments.
The flashlight body is very strong so this may be a night carry light for longer runtimes.
Despite the mods, it still works with the 3xAAA, but I have to put a small magnet in the bottom of the battery tray.
What I’ve learned ?
Sanding, drilling, filing aluminum without the proper tools may be a tough task! I took hours and hours to make the mod in the pill because I didn’t have more powerful drilling tool.
Also, the contact between the pill and the aluminum reflector could have caused a battery overheat and explosion! So, no more of these experiences!
Here you have some pics Big Smile
FL
ORIGINALS vs MODDED
Beamshot
Original – High
Modded Low-High
LED
Pill and driver
Reflector
(OP, not used)
(Original & final reflector)
TailSwitch
(Final, without the plastic ring)
_________
2nd mod
Brand/model: Ante (12€; included cheap 18650 battery and charger, bought in a local chinese store)
Specs: 18650 battery / 3 Modes (High-Low-Strobe) / -150 lumen / +Emitter: ??? / Side switch / In-built charger (not USB)
Main goals:
3) replace the pill;
4) turn it into a side and tail switch;
5) replace the reflector.
My reasons to mod: again, I didn’t like the UI ; I wanted “more light” coming out of the flashlight; and I wanted to transform it in a double switch flashlight !
After measuring everything thoroughly I ordered the materials. This is what I bought:
- Reflector : https://tinyurl.com/y96g8aht
- LED : (20mm plate, XML2 U2-1A) https://tinyurl.com/y8q8kpgo
- Pill : https://tinyurl.com/ycg5gwkq
The things I’ve done with the flashlight and the materials
1 – I opened a hole in the tail of the flashlight to fit the rubber tailcap. Inside there was enough space for the switch;
2 – I re-used an older flashlight’s switch (which I will replace for a new one already ordered)
3 – I filed the top ring of the pill so that it could fit the flashlight body
4 – I filed and sanded the top of the aluminum reflector (more OP than SMO) so that it could fit the head of the light without damaging the plate or the LED. I damaged it a little bit but it doesn’t interfere with the output beam.
The other work was more or less the same: soldering the driver to the plate, and soldering the border of the drive to the pill.
I had some struggle here because my soldering iron was not so good. I had to buy another one that delivered more heat so the solder could melt perfectly and evenly.
I also had some trouble with the thermal paste.
Actually, although I report this mod in second place, It was my first one! So…It was messy as hell for me! Ehehe Facepalm Big Smile
I also replaced the plastic lens for a clear glass lens.
Conclusions so far:
I use it the biscotti in 3 or 5 mode configuration (from ultralow/low to high, no strobes), and it also doesn’t get too hot because of the pill configuration, as it absorbs well the heat!
The “double switches” work this way: the SIDE switch is the main. If it is OFF, the tailswitch won’t work.
However, if the tailswitch is also OFF, the side switch will not work.
So, if I want the light “ready to go”, I have to let one of them ON. I guess that this has some parasitic drain, but I won’t mind with that as this is a home flashlight and it was mainly my first modding project.
Also, there is some kind of problem with the switches. I guess the tailswitch is not good enough and doesn’t make perfect contact with the battery. It flickers often and when used on High, the light dims fastly, about 5 seconds after putting it on high. I will replace the switch and maybe I can solve this.
If the switch is not the problem…well, I may have damaged something during the soldering process due to the heat!
The in-built charger will not be used as the flashlight’s working mode has changed. I put a bit of hot glue in the hole to seal it.
What I’ve learned?
Drilling aluminium was really tough to make that hole for the tailcap, but it was worth it. My father gave me some help with that, so here he is with a gigantic drill!
Also, soldering without a good iron, is not good. The solder solidifies too fast and it takes a lot of time to make it right!
I like the final result, and although it has lots of flaws.
But this was my first mod, and I’m proud of it!
You get some pics here!
FL (original and new pieces)
FL (Pieces modded)
Beamshots (HIGH)
Original
Modded
Side Switch from above
Pill / LED / Driver (original)
Pill / LED / Driver (new)
Reflectors (Original – New)
Tailswitch (Original)
Tailswitch (Moded)
Thanks for reading and hope this helps!
I wanna thank to those who contributed in this thread when I asked for help about the drivers for these mods! Thanks!
Best regards! Thumbs Up
Edited by: MascaratumB on 07/31/2017 - 22:30
CRX
CRX's picture
Last seen: 5 months 4 days ago
Cool, we all start somewhere Thumbs Up
I remember reading posts a few years ago about emitter swaps and thinking “I’ll never bother with that” then same again with DTP MCPBS and drivers.
Now I make my own lights from anything I get my hands on Big Smile Keep it up.
I always put a ring or two of kapton tape on the bottom of the reflector to stop shorts and check for jaggy bits.
Various sized hole punches and razor blades are good for making discs.
Take it easy with the thermal paste, just a thin layer on the MCPCB before placing it in the pill with tweezers does.
Lightbringer
Lightbringer's picture
Last seen: 2 min 56 sec ago
Hjeh, I was so happy, finally throwing together a long-overdue D26 drop-in for an L2M host.
Makes me feel like a piker… Big Smile
FPV
FPV's picture
that was a great write-up, thank you for sharing your experiences.
Persechini
Persechini's picture
Last seen: 7 months 5 days ago
Nice mods, nice choice of driver. Question: why not go with the Xp-L HI instead of the Xm-L2?
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
The Miller
The Miller's picture
Nice
Proud with good reason!
FmC
FmC's picture
Last seen: 7 months 3 days ago
Thanks for sharing your first mods!
You learn so much, not only about the workings of the light, but also about your equipment.
Keep em’ coming Smile
Beer Beer
MascaratumB
Hi there!
Wow, thanks for your comments folks!
I know this was a “minor” modification of flashlights, but I guess that’s it, we all start somewhere! This was my start to recycle 2 lights that may come in handy! I won’t let their host become a rot carcass Big Smile
An overall “thank you”, and I’ll answer below individually! Wink
@ Ollie
Yeah, I guess it will get easier from now, and I’m already preparing the new thing to mod Big Smile
@ CRX
Well, a comment from one of the greatest modders/creators in the forum makes me happy!! Your creations are inspiring!!
Thanks for the tip about the kapton tape! I’ll try to get some and to put it.
Meanwhile, I really decided to risk all and I put electrical black tape to insert the new reflector (OP). And I like it better! The “yellowish” crown around the beam center disappeared!
About thermal paste, yeah, I gotta use less, it become really messy Facepalm
On the next mod I will certainly be careful with that Wink
@ Lightbringer
Hum, I thought about buying a “pre-made” drop-in. But, for what I’ve seen, those are bigger and wouldn’t fit this light.
So, to make it work, I had to make my drop-in Big Smile
Also, I wanted something better for the driver and the LED, so I had to do this!
This is different from a Solarforce L2M, because it has the side switch and that changes the process of putting the things into it, namely about dimensions.
I thought about buying a L2M tailswitch to make it more consistent, but I kept on my stubbornness and made the tail switch against the odds. Still have to perfect it, though Glasses
@ FPV
Thanks! I’ll try to share what may bring input to the community Thumbs Up
@ Persechini
My choice for the XML2 U2-1A instead of XPL-HI was due to main reasons:
a) I wanted to have a more floody beam,
b) I’m not familiarized, so far, with that LED output/beam.
The flashlights will be used for close range, mainly, and when used for larger distances, their reflectors can help making it go further.
Also, this was the tint I wanted to make it brighter in outside environment, so I chose this LED beacause of that and also because I have no XPL-HI lights. My first will arrive in some weeks and will be inside a Convoy S2 tan version+.
After that I’ll be able to know how the beam looks like and the output luminosity!
Thanks for asking Thumbs Up
@ The Miller
Well, for someone that about 8/9 months ago was just looking for a good flashlight and never thought of being a flashaholic, to get into modding (even if it is a simple thing) may be a reason to be a bit proud Smile Thanks! Big Smile
@ FmC
You are right! More than the mod, to learn about the tools, the times of construction and what not to do in the process might have been the greatest learnings here.
I spent a bit of money to buy new things (aside from the drivers, leds….) but I’m more confortable now! Wink
In some weeks I’ll have a new one, a bit different from these in some aspects, and I’ll share it with you!
I’ll be recycling a (old) 9 LED flashlight, to make it accomodate a reflector or TIR lens, pill, driver, and eventually and 18350 or 18500 battery! It will be funny Big Smile
Thanks again for reading and your comments!
Best regards!! Thumbs Up
XXX-Man
XXX-Man's picture
Last seen: 2 days 16 hours ago
Nice work Thumbs Up
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
MascaratumB
Thanks XXX-Man!! Big Smile
DavidEF
DavidEF's picture
Last seen: 1 day 18 hours ago
Wow! I’ve been here a while longer than you, and my mod skills aren’t up to your level! Great job! If -the – ever gets the scratch made contest going this year, you should definitely enter! Party
- The YKK Philosophy
MascaratumB
Thanks for your words DavidEF! Smile
I’m just a beginner on these things! I have a lot to learn from people here before going on a contest (if I’ll ever enter one), but I’ll do my best to do some things Wink
Glad you appreciated it!! Thumbs Up Big Smile
Lightbringer
MascaratumB wrote:
@ Lightbringer Hum, I thought about buying a “pre-made” drop-in. But, for what I’ve seen, those are bigger and wouldn’t fit this light.
Naw, all I meant is that yesterday I was feeling oh-so-productive that a long-overdue drop-in that I wanted for my L2M host, I was finally getting around to, and here you are doing major surgery on a junk-light to make it actually usable.
DavidEF
DavidEF's picture
MascaratumB,
Even beginners are invited and encouraged to enter the contest. The contest is for fun. If you’d like to join, don’t let inexperience keep you from it. I entered last year. I intend to enter again this year. I think you can do better than me. Innocent
Lightbringer
Me, now I take the lazy way out, and just pawn ‘em off on someone who doesn’t know any better. Big Smile
I had enough aggravation with junk-lights, kept thinking of ways to “fix” them, but underneath it all, it’s still a junk-light. Took a while to get it into my head, but now I just get rid of ‘em.
“Man, what crap… Hey, you! Want a flashlight?”
“Sure!”
“Here ya go…”
Problem solved.
MascaratumB
Hey there again Smile
Well, thanks again for your comments! I’m thrilled that these mods may be encouraging!
First I was afraid” to start modding, as I never had soldering experience, nor building electronics experience.
But then I read a lot here on BLF, benefitting from other members’ experience and I started watching some videos about technical aspects. That was what encouraged me to do these first things.
And, of course, the not-so-good quality or usability my lights had! Big Smile
@ Ollie
The process was a bit like that: 2 lights in which I saw some possibilities to become “stronger” lights!
Then, the pieces from other lights I had, and then the new components that would make the difference.
I’m not much creative but I like to “invent” and experiment some things and to take me to another level, fearlessly!!
What could go wrong? Just some “wasted” € and wasted time! Comparing to what I had to win – 2 fully usable flashlights – I gave it a try!
Wish I had a lathe too, it would drain my money and energies, but it would be incredible!
Now I just use some of my old lights and I buy some new to make them better Wink
@ Lightbringer
Sorry, I completely understood it in the wrong way! I thought that you meant that I could have bought a drop-in module for the light as they it is similar to the L2M! My bad Facepalm
Well, this was not a perfect “surgery” and I just hope some “stitches” don’t get loose Big Smile
The Brennenstuhl I moded, despite the common aspect with some other cheap lights, it is a really nice light with very good original components, from the LED to the switch (OMTEN). But I guess that it had the capacity and the body to get something more powerful, and more usable for a daily base. I like better outputs and beams and I don’t like blinkies! That was what took to this “transformation”.
The Ante light…well, the some of the components are a bit junkie, yes. LED, pill, driver, reflector…That would need a major transformation.
And the adding of a tail switch. I guess that when the new switch arrives, I’ll borrow it to my parents, even if it uses a 18650 battery. They have their own lights, but this may work as a backup. There are no major issues when using it, and it may come in handy Wink
BTW, I thought about buying a L2M, but I abandoned the idea some time ago, as most of the drop-ins didn’t suit me. Now…I’m not sure if I won’t give it a try Big Smile
@ DavidEF
Hum, I like non-competitive “contests”!! I guess they become learning opportunities! Thumbs Up
What’s the name of this one you’re mentioning?
Maybe the next mod I have in mind may be a nice one for that Wink
Thanks again folks!! And keep up your good works too Wink
Lightbringer
Nah, no worries.
MascaratumB wrote:
Well, this was not a perfect “surgery” and I just hope some “stitches” don’t get loose Big Smile The Brennenstuhl I moded, despite the common aspect with some other cheap lights, it is a really nice light with very good original components, from the LED to the switch (OMTEN). But I guess that it had the capacity and the body to get something more powerful, and more usable for a daily base. I like better outputs and beams and I don’t like blinkies! That was what took to this “transformation”.
Yep, I hear ya.
The crap-C8s I got with the plastic reflectors and the like, I know they’re essentially garbage, but figure that with decent pills from FT, I could load up my own drivers/emitters and have something that I know I ain’t gonna push very hard, so having a solid brick of metal at the head won’t be critical, nor would a cheapcrap switch.
Really nice host, forward-clicky switch, no shroud around the switch, so you can use it as a true tac-light.
I haven’t bought a completed drop-in in æons, and just roll my own with whatever emitter and driver I want. As long as the emitter fits the reflector, I’m set.
MascaratumB
I haven’t bought a completed drop-in in aeons, and just roll my own with whatever emitter and driver I want. As long as the emitter fits the reflector, I’m set.
Hum, yeah, I realized the pill makes a lot of difference, especially to absorb some of the heat!
I bought mine from Kaidomain store in AliExpress, and I hot another 2 on the way!
They also have those to fit the C8s and other that fit drop-in hosts! I didn’t adventured myself on those because its measures are always missing. I guess that it is a flaw from sellers (although we can ask them of course…)!
I saw the L2M host there as well and it really seems a good one! Nice to know that from what you say! I guess some day I’ll give it a try and see how it works Wink
Thanks for the inputs once again!! Thumbs Up
FmC
FmC's picture
DavidEF wrote:
MascaratumB,
Yes, the comp is mainly for fun, & pretty much everyone who completes thier entry wins something.
I entered in the first 3, but was unable to last year. Can’t wait until this year’s!
Check out the first few comp builds here.
Lightbringer
A lot of times when you buy a pre-built drop-in, you have no idea what went into it, or how. Did they use thick-enough wires? Did they use a good thermal goop like AS5? Or is the emitter just press-fit to the pill by the reflector?
Æons ago, when I saw an 5000K XP-L drop-in just came out, and at a non-obscene price, I sprung for it immediately. Nice emitter, but the driver is just a bunch of parallelled chip-resistors, no actual regulation. Wellp, there goes that idea…
Never bothered to replace the driver, and I still have it somewhere, maybe in a ’501 host, forgot.
Point is, had I rolled my own, it would’ve been with my choice of driver, AS5ed nicely to the pill, and I would’ve been happy with it for what it is. I wouldn’t consider it half-good.
Throwing together a drop-in is easy. And quick. And you get to pick’n‘choose everything you want on it, down to the last detail, just like ordering a sandwich from a deli. Big Smile
MascaratumB
@ FmC
Hum, nice!! I guess I’ll have a lot to see from the past years Big Smile
Maybe I can enter too, if it is that way! I guess we “just can’t get enough” of new things to mod and learn from!
I have 3 projects in mind to mod! One I guess its almost done, I just have to fit the pieces when they arrive; a second one will be mostly a LED and driver swap, and a TIR lens replacement; and the third one, somewhere in the middle, will imply a side switch construction to recycle a flashlight’s host! This one may become a bit tricky as I don’t know much about electronics and that stuff, but I’ll try it and maybe I can take it to the contest Wink Thumbs Up
@ Lightbringer
I guess you’re right! Besides the measures, that aspect is pretty important, the components used and what have they done to them.
That’s why I preferred to use things from Convoy and Kaidomain stores instead of buying a stock drop-in! And more than that, I think the “hands-on” approach to the builds are the most exciting things, once you get new skills. You get to know the materials and processes better!
After the first one (or two, in this case) I just want more. And even if I don’t exclude the idea of buying those pre-built ones, it won’t be as funny as these were Big Smile
MascaratumB
DavidEF wrote:
[…] If -the – ever gets the scratch made contest going this year, you should definitely enter! Party
Only now, after seeing FmC link, I understood that the is the name of the member that promotes the contest Facepalm
I’m so noob Big Smile
I’ll be looking forward to see the news about the contest! Thanks again! Thumbs Up
DavidEF
DavidEF's picture
LOL Thumbs Up
Lightbringer
Ollie wrote:
Google “c8 reflectors” and you’ll find a bunch of them. I got 5 for $5 from Amazon. They were all pretty much identical, and work good, I got them so that I could experiment with reflector depth. No, I don’t have any magical settings.
I saw 3 different kinds from FT, just slight variations of 1mm or less, so got 1 of each. So thinner/thicker stars, O-rings, etc., I’d probably be covered.
Most cases, though, I’m not pushing the critter very hard (colored LEDs, UV, etc.), so I leave the original crapflector in there.
Yokiamy
Yokiamy's picture
Last seen: 1 hour 52 min ago
Nice work! You certainly are hooked up modding!
I did some basic modding, not even your level, so keep up the goood work
Lightbringer
Ollie wrote:
In spite of opinions to the contrary, I think the aluminum reflector transfers some heat. I added some of the silicone “clay” to the space between the reflector and the head, and I think it gets warmer.
Absolutely it does. It’s hindered by any washer/spacer/etc. that keeps the reflector from shorting out the wires to the LED (at the solder-bumps), but it makes some thermal contact and wicks away some heat quite nicely.
“Some” being the operative word. And every little bit helps. Kinda like DTP vs non-DTP
MascaratumB
Yokiamy wrote:
Nice work! You certainly are hooked up modding! I did some basic modding, not even your level, so keep up the goood work
Hi Yokiamy! Thanks for your words!
In my view this was a bit basic too, comparing to what other people do here! But I guess this is a beginning and now I want more Big Smile
Practice makes perfect and I guess the more we do, the more we want to do, the more we do better Wink
@ Ollie and Lightbringer
On the Brennenstuhl I started to use the aluminum reflector I bought, instead of the original plastic reflector! I put some insulation tape to avoid the short circuit (I don’t have kapton tape as CRX suggested)!
The first thing I noted was that there is more heat on the front of the flashlight. The beam pattern is a bit different, but the temperature is certainly higher. I just don’t know if it creates or draws heat from the plate and LED! So far, it is working Big Smile
The Ante, although using the aluminum reflector, it barely makes contact with the plate, so there’s no short circuit possibility and few heat transfer, I guess!
NeutralFan
NeutralFan's picture
Last seen: 16 hours 3 min ago
Good job with your first mods MascartumB! I like how your dad to helped you out. I have found that even though thermal compound can get quite messy, it cleans up very well with isopropyl alcohol and cotton swabs. Thanks for taking the time to post your experience.
I’d rather use my flashlight around the house than turn on the lights.
MascaratumB
Thanks for your words and tips NeutralFan!!
Yeah, I needed my dad’s help as he has the tools and mostly the expertise on using them, and so I invited him to participate in the process! Smile
Hum, I have to search for that “isopropyl alcohol”! Never heard of it Facepalm
But…one (or 2) question(s): does the excessive thermal paste interfere on the connections or the light functionality, or does it endanger the wiring? Or is it more a matter of looking?
I’m sorry but I really don’t know, and as the light has been working fine, I also don’t know if it will provoke any “dangerous” situation for the plate or the LED.
Thanks again Thumbs Up
NeutralFan
I don’t think you should have an issue with the thermal compound causing electrical shorts, if that’s what you are asking. As long as it’s mostly behind the LED and not on the driver, you should be fine. It also depends on the compound you used, some are conductive and others are not.
MascaratumB
Yup, that would be my major concern!
There’s a part of the thermal paste close and on the solder and the plate
The paste specs says “thermally conductive compounds are grease-like silicone materials, heavily filled with heat conductive metal oxides. This combination promotes high thermal conductivity, low bleed and high-temperature stability”.
Maybe I got the wrong compound too, besides the mess I did Big Smile
To clean it perfectly I would have to unsolder the plate and take it out. The pill is very tall, so the wires are almost all stretched, there’s no space to lift up the plate and clean it below and on its sides…
