FWIW, a lighted tailcap will make a Biscotti driver think every button press is a short press. The only way around that is to add a bleeder resistor on the driver, to allow current to pass while it’s “off” without keeping the MCU powered up.
As for throw, blue light scatters in the atmosphere. The scattering effect is proportional to the color temperature raised to the fourth power, or something like that, so cooler tints waste a lot more of their output creating a visible blue beam… and that obscures whatever the light is pointing at. So for a thrower it’s important not to have a cold tint.
Unless you want the thrower to look like a light saber. In that case, get the coldest tint you can find. It’s great fun.
Burns holes in wood, for one thing. Causes INSTANT blindness even with the briefest reflection. Lights up its path in air just from dust and/or humidity.
Oh, but it’ll light up something miles downstream… or on the moon.
Seriously, that kind of laser is used to etch wood, and isn’t a toy by any means.
Do you mean because warmer tints generally have higher CRI? (Anyone know the CRI of the 7A Convoy XPL-HI LED?)
Or do you mean that it’s because a warmer tint is better to light up the red and browns in a forest situation?
I can’t think of another reason why a warmer tint provides better contrast (other than scattering mentioned already).
The downside of a warm tint is that it usually has lower lumens. (U3 bin vs V2 bin in the Convoy, which I think it about 25% less output?) So, I’m curious to see if that drop in output is balanced by the upsides.
Anyway, it will be fun to try. Got my shipment notification today.
Yes, very true. However, there are times I want the light very close to my line of sight: it’s a great way to spot animals (from eye shine), using low output. Creepy, but effective. Okay, sometimes too creepy.
It depends on the cat. Mine figured out the laser immediately, even as a kitten. So when I would try to get him to chase a laser, he would look at the spot, look at the laser in my hand, then give me a look like “Really? How dumb do you think I am?”
I hope not. There’re too many things already “regulated” by nanny-state governments. And you can find a nice powerful laser-diode in any blu-ray recorder.
I keep telling people who want to ban guns that when Terrorists™ start using bombs or even gasoline (anyone skeptical, look up the Happy Land Disco fire: ~80 lives snuffed out with a few gallons of gasoline) to do their nefarious deeds, they’ll be wishing that they’d go back to using guns. And all it takes is one idiot with keys to a truck to go plow through a crowd…
All that might do is to keep some idiot kid from shining a laser at a passing plane… oh, wait, they do that despite it being a federal crime with some serious jailtime attached.
I mean, c’mon, there’s been talk about banning or at least “regulating” 3D printers because of what someone might create. Or requiring any designs to go through some central clearinghouse for inspection first before allowing the object to be printed. (I can imagine the backlog on that… want to build a bike-light bracket, submit your design now, come back in 2021 when it gets approved.)
Too often “government” is the problem, so let’s not automatically look to it for “solutions”.
Lightbringer, perhaps this one is a “bit” more than 900mW…
As far as the tint questions, remember that in the same power binning a warmer tint makes much less lumens than a cool tint, so it would only be feasible that you would get more reflection from humidity from the brighter light…
As interesting as philosophy of governance is, it’s one of those topics which tends to get out of hand pretty easily.
Instead of responding with data on the effects of various governance strategies (data on this sort of thing tends to be counterproductive when humans are involved), I’m hoping we can stick to less fiery topics… like actually starting fires.
Dale, that is the laser you made for destroying wasp nests from a safe distance, no?
Can anyone tell me how long I can run the C8 at 100% in let’s say 25-30 degrees C ambient temps until the heat buildup is too much. There is a runtime chart floating around which shows a max temp of 66 at about 40 minutes in with an ambient temp of 25(?), is 66 too high?
I can’t say if that’s as hot as one gets, or if those numbers are accurate, but I can say that 66c is not “too high” for the electronics. That heat won’t hurt your light. It may hurt your hand though. How tough are you?
Bottom line — if you can stand to hold it, its not too hot.
