Aaah, you mean metal spillings, shadockan? None. :-)
I have a couple of LiitoKalas from a dismantled, work in progress powerbank, but it doesn't looks very fine on these as they only have a “dismantled” wire solder. ;-)
I have to solderblob a TrustFire IMR14500 (red-gold) for a friend soon, and he already has one of those done plus an NCR18650B. I'll recall for a nice picture of this to be shot.
Just tested between my blue and black LiitoKala 26650’s in a modified Convoy L6 (FET driver, XHP-70.2)….
Blue showed me 16.48A and did 9,108 in the light box
Black showed me 18.16A and did 9,280.5 in the light box.
192 lumens more at the sacrifice of 1.68A more draw, seems odd, but I’ve seen it where it flips, the one that has highest current doesn’t necessarily produce the most lumens.
shadockan, I never said I was into assembling packs profesionally. Doing it with this solder and technique can be relatively fast, yet I believe this is more adequate for custom builds and high current, as I can use and solder very big wires with ease.
I’ll just stick with the LiitoKala’s then… much cheaper & real good.
I tried my best to send you some of those connectors so you would have them when you needed them. :person_facepalming:
But no ship to address was I given.
Good day BLFers. Currently I have 2 26650 protected cells for my stock L6. I need 2 more. Can I use non protected 26650 cells? The black Liitokala seems good price, but not protected. Will my stock L6 circuitry can function as protector? Noob question. Thanks :innocent:
