Packaging and Contents
The VG10S arrived in a standard cardboard box like most Thorfire lights. One difference I noticed from prior Thorfire lights was that the box was taped shut with the label. This is a good improvement because it prevents the box from coming open during shipping. The light is protected in a bubble-wrap sleeve and there is foam padding on the bottom of the box. Accessories included clip (pre-installed), 2 spare O-rings and manual. The packaging is more than sufficient in addition to the mailer packaging. There is no significant risk of damage or scuffing to the light during delivery using this packaging, especially now that the boxes are taped shut.
1 x Flashlight
1 x Clip (Pre-Installed)
2 x Spare O-ring
1 x Manual
Fit and Finish
The VG10S has smooth black low-gloss anodizing with some oblong indentations designed into the body and tail. The anodizing was applied well and my copy did not have any notable defects in the finish. The anodizing is also applied to both the head and tail threads.
Size-wise, the VG10S is a compromise between a tube light and a larger C8-sized light. The VG10S will fit fine in larger pockets (like a jacket or cargo shorts) although some may find it a little too wide or too heavy for true EDC use if they are used to using tube lights or smaller. The VG10S has more mass and more cooling fins so it will run cooler than a traditional tube light.
The finish looks good although I would have preferred the knurling that Thorfire uses in most of their other lights (like the TK15 and TK15S). Style-wise, I liked the design of the bezel on the VG10S and it also makes it so that you can tell if the light is turned on when standing on its head.
Due to the design, there is minimal roll-resistance unless the clip is attached.
Tail Standing.
Nicely styled bezel. It also makes it so that you can tell if the light is turned on when standing on its head.
Reverse-clicky tail switch.
The threads were cut perfectly square.
Anodizing on both the head and tail threads. Springs on both ends.
Accessories
No lanyard or case/holster included. The included clip is great although I would have also liked a lanyard. I also would have preferred "deep carry" clips (or both clips).
User Interface and Modes
The light uses the tail-switch to control on/off and modes. There is mode memory - the light will activate on the last used brightness.
Operation:
- To turn the light ON, press switch fully.
- To advance modes, half-press switch (Moon -> L -> M -> H)
- To turn the light OFF, press switch fully.
Strobe (Hidden via Double-Click):
- To turn STROBE ON, double-click (when on).
- To turn STROBE OFF, half-press switch (will return to previous mode).
Comment:
* I like that Moon is not hidden.
* I wish that double-click did not turn on strobe because it is possible to activate strobe on accident if you are trying to change modes quickly. I think it would be better/safer to hide strobe modes with a long press.
* It would be even better if the flashlight was programmable so that you could disable options like strobe, moon mode or mode memory. It would also be nice to be able to program the mode order (High to Low vs Low to High).
Output, Runtime and Power
Measurements were done using a freshly charged EVVA protected Panasonic NCR18650B in a quasi-integrating sphere. Battery was measured at 4.17V and measurements are taken within 1 hour of charge.
At maximum output, I estimate output is above spec at around 1200+ lumens at 30 seconds. Medium was around 400 lumens. Low was around 90 lumens. Moon was around 0.4 lumens.
Comment: I would have preferred Moon to be slightly higher - at least 2-4 lumens. The difference in lumens between Moon and Low is pretty large - 50:1 by spec and 227:1 by my measurements.
45 Minute Run
This light has a timed ramp-down which begins at 5 minutes and slowly ramps-down the power throughout the following 15 minutes. This is a unique ramp-down behavior which I haven't previously seen in a Thorfire light. I decided to overlay the behavior against the TK15 and TK15S for comparison.
Comments:
* The ramp-down is gradual and subtle enough to not really be noticeable in real-world use. This provides a good balance of output while protecting a user from running the light at maximum output continuously.
* The light is not really warm by the time it settles on Medium power.
Throwy Balanced General Purpose. The VG10S uses a domed Cree XP-L2 (most likely the V6 3D shared with the Q8) in a polished reflector. The beam is throwy but still very balanced for general purpose use with a hotspot which transitions smoothly and gradually throughout the beam. The hotspot is not heavily defined. The outer beam has defined edges. This light works very well for people seeking a more balanced beam. This light works great for general purpose use both indoors and outdoors.
Beamshots, Color Temperature and Tint
The VG10S has a very nice warm neutral white of 4500K. When white-balanced in Adobe Lightroom against "Daylight 5500K", the beamshots appear warm. The light appears slightly warm white in practice. This is a very good choice of default color temperature and I'm really happy to see a manufacturer using this color temperature for a light.
Like other lights which use the XP-L2 V6 3D, the hotspot is the warmest part of the light and the light becomes slightly cooler towards the edges. However, this is not visible in pictures and even in real life except when aimed at a white wall where the contrast in color temperature can be seen.
Battery Support and Fitment
The VG10S is powered by 1x18650 lithium-ion (INR, IMR, ICR, etc.)
Protected Batteries Fit. The EVVA Protected Panasonic NCR18650B fits length-wise at 69.5mm and width-wise at 18.67mm. This flashlight actually accommodated protected batteries better than most of my lights. Even though the battery sticks out with the cap off, there was no sensation that the springs were over-tightened at all. The dual springs are very tolerant.
Button vs Flat-Top: My batteries were button-top. Flat-top batteries should also fit due to the dual battery springs (the positive & negative contacts are both springs).
Lock-Out
You can physically lock-out the light by loosening the tail (or head) one-half turn to break the circuit.
If there is a possibility of accidental activation, you should lock-out the light.
Size Reference
Flashlight pictured next to a 18650, TK15, TK15S and C8 for size reference.
Next to TK15 and TK15S.
Summary and Conclusion
The VG10S is a very good, well-built 1x18650 light which performs above spec at 1100+ lumens on High. Size-wise, the VG10S is a compromise between a tube light and a larger C8-sized light. The VG10S will fit fine in larger pockets (like a jacket or cargo shorts) although some may find it a little too wide or too heavy for true EDC use if they are used to using tube lights or smaller. The VG10S has more mass and more cooling fins so it will run cooler than a traditional tube light. So, unlike most tube lights, this light can handle full power better although it does get warm in High mode. The Medium mode at ~400 lumens can easily sustain longer runtimes with this design and is only mildly warm. For people who mainly use Low or Moon, this light will provide great run times. I like that Moon is not hidden and part of the normal mode rotation although it is dimmer than my preference (I prefer a Moon to be around 2-4 lumens).
The beam profile is somewhat throwy yet very balanced and is well-suited for general usage. The color temperature of 4500K is perfect and I wish that more manufacturers made lights like this (I do not like cool white LEDs).
