Ah yeah they’re both very small , you are right D4 looks bigger olon the pics, must be the bulge for the switch. Funny, D4 has side switch and larger max OD, FW3A tail switch so a little longer.
It’s the diameter that makes the bigger difference here. The FW3A is slimmer than the D4 and doesn’t have any bulges. Even the Astrolux S41, which isn’t as bulgy as the D4 is noticeably more bulky to me in the pocket than otherwise-similar lights with straight tubes.
I’m glad to hear there may be a 219C option in the future. I may be an extremist here, but the longer I’m into lights, the less patience I have for low CRI. It takes a lot of lumens to make a significant visual difference, but even a modest difference in CRI is a stark contrast outdoors. I can solder, so I’ll buy these no matter what emitter they come with, but a lot of people can’t. Also, due to this light’s amazing price point, buying new emitters adds about a third to the cost.
Jared, like you I don’t run my lights at max’ lumens all the time either (I suspect very few if any here do), but it’s nice to have the light blast when I want mega light. I guess I don’t understand the concern. If one wants a long runtime and a cooler light we just run it there as you and I already do. It’s like an automobile, my car can go I don’t know how fast because I’ve never driven it that fast, but just because it can go really fast that doesn’t mean I use it at that speed.
Or like alcohol… just because I buy a bottle and have a drink now and then, it doesn’t mean that I drink the entire contents.
I’m trying to understand the complaint, but I simply can’t. I’m not trying to be difficult.
I think the complaint is that both direct and linear drivers (the FW3A driver can operate in either mode, depending on output level) are inefficient on anything but max output. A FET always runs the LED at the maximum current the battery can provide, where it’s well under its peak efficiency. A linear driver burns off the difference between the battery’s voltage and the LED’s forward voltage by turning it into heat, which is an obvious waste. With low-forward-voltage LEDs like the XP-G3 and the latest Nichias, there’s a considerable amount of waste when the battery is fully charged.
A switch-mode driver (buck, boost or buck/boost) can be more efficient, as it can provide exactly the desired current for the selected brightness and transform any extra voltage into current, reducing the load on the battery in the case of a buck driver. These also cost a lot more to produce and take up a lot more space. To get the sort of current possible with a FET driver requires especially large and expensive components. The highest output mass-produced 1x18650 lights with switch-mode drivers (Nitecore TM03, Olight H2R) are barely scraping the low-end of the outputs hobbyists have been getting with FET triples for years.
There’s been some of the same discussion with the Emisar D4. To gain the efficiency requested, it would have to be larger and more expensive with a lower peak output. There’s merit to that (a Wizard Pro with Nichia 144A swap is one of my most used lights), but it would be a completely different light than the designers set out to create.
Yeah the extra space needed for buck/boost and added cost make it hard to use in our BLF specials
Now that the triple channel gives more stable output lower modes it just is logical to use it in a small light like the FW3A
Zebralight manages to get boost drivers into lights this size, but they run at 3A max instead of ~12, have only one emitter and cost $80, not $30. Kaidomain actually did manage to make a cheap boost driver light with pretty high output in a C8 body, but most people don’t find a C8 comfortable to carry in a pocket (and I haven’t seen independent verification of its 2600lm claimed output).
They’re calling it the C8.2. XHP50.2, 3 tint options, 4 modes, bad spacing, bad UI (on-time memory). They should really get help on the firmwares for these things.
I don't mean to sound offensive in my viewpoints. I do agree with what you said about the beam pattern and tint being subjective preferences, unique to each individual. With that I stand fast in my position that XPG3s generate a unsatisfactory beam. But to each their own. -- By the way, me sharing my opinion is not a 'far fetched argument.'
With that out of the way, I'd like to thank everyone involved in the project. Despite me not agreeing 100% with details of the build, I am extremely appreciative of the efforts put forth by the team.
The C8.2s H1-A driver is really good for what it is, but what sucks is they don’t use an attiny chip so you have to swap pins around to flash the firmware. Really looking forward to compact boost drivers that can be used in hot rods.
It’s been said many times by many people that boost drivers just have too many limitations when it comes to high outputs. Pcb traces have to be beefed up significantly and the components just can’t take the high current you have with low voltage. So that day may be many years off if at all.
I think the FW3A is probably a more practical light than the D4. It has a clip, it has more 7135 chips for steady med/high modes, the beam should be rounder/smoother, and the maximum output might be a bit less intense.
I’m not sure the tail switch will be any better or worse — just different. It encourages a reverse grip instead of a forward grip.
Looking at djozz’s XP-G3 measurements, overall output might be pretty close to the D4, despite having 3 emitters instead of 4. It seems that XP-G3 puts out more lumens per amp than 219c, at similar Vf. It’s almost as bright as XP-L HI, but has lower Vf so it can run at higher amps. So I wouldn’t be surprised if the FW3A can hit 4000 lumens. This assumes all other components are as good as the D4 though, which might be difficult.
My main concern is that I haven’t really heard anything good about the XP-G3’s tint consistency. However, it might still be totally fine with a frosted optic like the 10511. I’d recommend this over the 10507 for almost any light, but particularly for one with LEDs which emit different tints at different angles.
If possible, it’d probably be a good idea to offer it in a range of NW tints from 4000K to 5000K, with high CRI for some options. That would cover the majority of people’s preferences. I’m still rather fond of high-CRI 4500K.
