I got 3 of those on the way from KD. Those are pretty nice #'s, specially the lumens for a dedomed LED that throws almost as good as the best dedomed XP-G2's, I think. Didn't know you can get that many amps out of one. Might just put them in a SRK. What do you think of the tint after dedoming, and the beam pattern?
Hhmm, for that price, might order a bunch more.
Ohhh - and these are "only" N4 bins. There's 2 higher bins listed in the specs, but who knows if they will ever happen (N5 and P2).
Upside down on some wires in regular 95 octane petrol. It took 3-4 hours and a bit of picking with a needle and falled down. After that cleaning with alcohol rinse and a needle under magnifying glass.
First attempt at XHP Soup, HOT fluid de-doming (tried 2 different fluids, the second fluid performed better) XHP35’s 50’s and 70’s all meat no veggies!
Brand New $8.00 Garage Sale Crock pot, so far soooooo gooooood!
I made sort of a cooperative multitasking toolkit with event callbacks and a finite state machine, to make it easier to create e-switch light UIs.
It works on tiny45 and tiny85, and it should be reasonably easy to add support for other MCUs later. Most of the hardware details are abstracted out to allow interfaces to be portable across different types of drivers.
I may have also just cloned ZebraLight’s UI in the time between my previous two comments.
I call it DarkHorse.
It doesn’t have memory which lasts across battery changes yet, but that’s next on the list. I just need to make an API for eeprom access…
At some later point I might make an improved version and call it DarkerHorse. But for now the only improvement is replacing “6+ double clicks to configure secondary level” with “click then hold to configure secondary level”. It was a bit ridiculous having to click 16 times to switch between 10 lm and 34 lm.
Waiting for TK to develop the perfect UI, it’ll be called Major Deity, we’ll know it as Perfection 101. She’ll have it read our mind through our retina, a simple stare into the lens and it’ll KNOW what we want from the UI and respond accordingly. Then the switch will be a fingerprint reader in the battery tube, contact with our hand will allow the light to AUTOMATICALLY turn on/off and adjust level according to our thoughts…
I disassembled the groupbuy Thorfire VG10 with multi level MCPCB and decided to use it as a host for a triple Nichia build. I used Carlco 10507 optics and Noctigon triple XP20 MCPCB. The driver will be a BLF A17DD and The tailcap already finished with lighted tailcap board.
Here is the spacer if someone else want to make it. The conical section maybe need to move up a little because on mine I need to correct with a dremel to able to twistthe bezel fully. So on the left the 7,5mm is better at 7,4 and instead of the 10mm make it 10,1mm.
