Must subscribe not sure when I am going to read all this
I like the nice graphical UI diagrams created by toykeeper.
Would like to know if there is some free software which helps to create them.
I tend to forget how to operate my own UIs after a while not using it.
TK uses Inkscape and it’s free
google for tutorials
Wikipedia about Inkscape
Thanks!
I know inkscape, used it a couple of years ago. I hoped there is a even easier and faster software for this purpose.
You can use of course MS Word, but it’s not easier, more fiddly and you want a vector image as output.
The last two versions of Inkscape got better.
In Inkscape
- create a grid by help lines. Drag them out of the rulers
- place boxes and shapes
- place connection lines, change end to arrow
- place some text boxes
- save your pic as SVG, export as jpg, png, …
ToyKeeper
As a K9 SAR handler/trainer I’m always looking for the next advancement in searchlights. Right now I’m loving my new D4 and can’t wait to get hold of my D1. The ramping is so user friendly, but as a search light they have a long way before they catch up in the throw department. What I need is a way to use this type of feature in a light like my Olight M3XS-UT or better yet, a right angle type light (high lumen high throw) which would be more hands free.
What are my chances?
I’m not the tech person to do the job, this seems a little over my head. Do you think these things are or will be in the pipeline any time soon? Any suggestions?
You want a search light with ramping? Have you heard of the BLF GT?
If you hurry, you can still get one.
For headlamps, Tom E has modded a few with Narsil. Perhaps you could too?
Or there’s the Nitecore HC90.
ToyKeeper
Thanks for the reply.
I think the giga thrower’s is way too big/heavy. :weary:
As for the Nitecore HC90, I’d be better off with my D4 on the bill of my hat… more than 4X brighter. I need a right angle light with that kind of brightness with the e-switch on the top. Something like the XTAR Warboy H3 (it has the switch on the top) only with ramping, and the brightness of my D4.
Could the Warboy be modded?
Almost anything can be modded… it’s just a matter of how much effort it requires.
For example, the Coke can light:
I can’t really recommend using 4000 lumens on one’s forehead though, at least not for more than short amounts of time. The output is mostly limited by heat and thermal properties, and increasing that generally requires adding a lot of mass. So, for anything small enough to be used as a forehead light, the performance at ~1000 lm or less is generally going to be a lot more important than how bright its turbo/burst mode is.
If a headlamp isn’t reaching far enough, it’s generally more practical to change it to a throwier beam pattern than to double or triple the lumens. Switching from XM-L2 to XP-G2 will generally reduce the lumens but increase the throw, which makes it appear brighter.
ToyKeeper
I guess I’m not making my point clear (my fault :nerd_face: ). I’m talking about 2 different lights. First, a thrower (like my Olight M3XS-UT) with ramping. Or an EDC similar to the D4, only more tactical.
I’m not suggesting it either. But as an EDC, a 4000 lumen right angle light with an e-switch on the top of the light would be much easier to manipulate under stress in a tactical situation.
The D1 and D1S are compact throwers with ramping. The D1S isn’t out yet, but it should be soon. It is estimated at about 120 kcd though, not 250 kcd like the M3XS-UT. So, it should get about 700m throw instead of 1000m. Or the D1 gets about 425 m.
ToyKeeper
Wow, D1S 700 meters? It was going to be my next purchase anyway. That’s more than I expected, (right up there with my old M31 Triton).
My D1 arrived yesterday and I played around a little with it this morning. I wasn’t expecting that much (over 400 m?) either, I was thinking maybe 200 m. I’ll have to give it a better workout tonight.
Thanks!
I finally put a development branch up with the current FSM code:
I still have some things to do before making a “1.0” release and merging it into trunk, but it’s already at a pretty usable state.
Things which still need to be done:
- Finish more example UIs.
- Add a half-sleep mode for things like a locator flash or alarm clock mode.
- Add a waking idle mode for lower power use at moon/low levels.
- Add support for voltage-divider style measurements on pin 7.
- Add indicator LED support.
- Add an option to use short-click/long-click/hold instead of just click/hold, because it’s needed for compatibility with UIs from fonarevka.
- Test thermal regulation on a wider range of hardware, to ensure it “just works” on hosts of many different sizes and power levels.
- Better documentation.
- Hopefully make the fourth PWM channel less funky. It works, but not quite as well as the first three.
After “1.0”, it should probably also add support for newer MCUs, buck/boost drivers, more than one e-switch, and power-disconnect switches.
Oh, um, I also settled on a name for the “unnamed” UI. It’s called Andúril, because it’s inspired by Narsil. Narsil was the sword of Elendil and Isildur, which defeated Sauron. Andúril is Aragorn’s sword, the flame of the west, the blade Narsil reforged. Granted, it didn’t defeat Sauron — it only scared some ghosts. But still. I thought it would be appropriate, and Tom seemed okay with the idea, so that’s what it’s called now.
I don’t understand most of the things spoken in this thread, I confess, but I do appreciate your work and efforts - TK - along with the one of other members! Thanks for making better UIs and for putting your imagination “at the service of the Light”!!! :+1:
Now, following your last post, I just wanna suggest that the first BLF light with the “Andúril” UI be named “Mithril”, being a “impenetrable” maybe “bullet proof” flashlight!! A flashlight for knights that can be kings of the Light! Just saying
This forum is getting better and better (and I’m just a noob here) due to people that are working and investing time, money, intelligence and other resources to make things (lights, components, UIs, drivers….) that somewhere in time seemed impossible and that now are just cool and feasible realities!
I’ll keep on reading, and trying to learn a bit from this work!
Keep it up :+1:
Mithril o_O
well, the FW3A colour is silver. That would fit.
The accent in Andúril is bad for searching. I think a simple u would be better.
Hum, don’t know if the FW3A creators/developers team would agree/appreciate that but…why not?
Sharp inside with Anduril firmware, armored and blasted outside with a silver “shining” look as Mithril, aiming to protect us from darkness
If it wasn’t a long name, “Light of Earendil” would also be appropriate :sunglasses:
(well, just hope these names wouldn’t raise Copyright or whatever issues)
I checked first. Part of why I waited was to make sure people didn’t mind.
I’d like to flash Andúril to one of my Q8s.
I successfully reflashed my D4 with the v2 firmware, but I’m still a total n00b with the process.
I’m still confused about the fuse values. Are these dependent on the hardware, firmware, or both?
How do I know what to use for the Q8 and Andúril? Do I simply reuse the values that come with the Q8’s stock NarsilM 1.0 firmware?
Also, when I attempt to build a HEX file with Amtel Studio 7, I get two errors:
recipe for target ’main.o’ failedspaghetti-monster.h: No such file or directory
I’ve downloaded spaghetti-monster.h, but I’m unsure of where to place it for ’#include “spaghetti-monster.h”’ to see it.
EDIT: I’m making progress! I now understand I need to place all of the .h and .c files in the project directory for the #include commands.
EDIT 2: I got a successful build! The ’Hey, you need to define ATTINY.’ error made me lol.
Please forgive my ignorance, I’m in waaaaay over my head here!
Ohh, I was talking about the “Mithril” name for the FW3A, not about the firmware
Independently of the name of the flashlight, I’m sure I’ll love that firmware on it!!! All my lights have “conventional” clicky modes, so a ramping mode, also with clicks, and extras like those you’re inserting on it, will be awesome!!
Once again, thanks for the efforts on these masterpieces :+1:
goshdogit, it’s intended to be built with the bin/build-85.sh script and flashed with the bin/flash-85.sh script. These are written for unix-like systems though, so it’ll require adaptation to build in Windows.
It’s also a good idea to grab the entire repository to retain its directory structure, so all the files will be there. This is easy with bzr installed, or not so easy otherwise. Perhaps I should get in the habit of doing .zip releases of the entire repository, since that’s easier in Windows.
FWIW, this is what I’d normally do:
- bzr branch lp:~toykeeper/flashlight-firmware/fsm
- cd fsm/ToyKeeper/spaghetti-monster/anduril
- …/…/…/bin/build-85.sh anduril
- …/…/…/bin/flash-85.sh anduril.hex
The build uses fsm~~.c and fsm-.h in addition to the files in the subdir for the current UI… and some of the tk~~*.h files in the parent directory. Basically, it relies on having parent directories in the include path with the “-I… -I…/… -I…/…/…” options in the build script.
