True. Ceiling bounce with them is a dream, especially in 7A tint. I have an M1 in that and love it to death – when I’m in bed, I set it to 0.1% or 1% depending on what I want to do, tailstand it on the nightstand then put a Thrunite T10 diffuser on top of the lens. Best lamp ever.
Well, I have a Haikelite MT02 that measures around 60k cd, but it’s just too heavy to carry around on my long nightly walks. It’s a good exercise though.
Yes sir. I’ve got an OTR M3 clipped to my cap visor, and this one’s pretty floody. I just need something throwy and not too heavy in my jacket pocket to occasionally light up something further in the distance, which is what I’m using the VG-10 for, currently.
Hello long time to read the thread returned to ask something if someone has the answer. Is that pouch good for the flashlight? http://www.military1st.eu/ma48-008-condor-flashlight-pouch-multicam.html
as i can read the dimension of the flashlight is:
Diameter of head : 44.5mm
Length : 143mm
Diameter of body : 25.6mm
and the pouch Dimensions: 5.3”x2”x0.8” (13.5x5x2cm)
Thank you in advance.
I have the second one and has a very cheap feeling, i have the first one for convoy s2 it’s very good quality and sturdy built. thank you for the info.
Anyone here done some mod with this C8?
I put XHP50 with Noctigon, but the result, got some ring spot in the center.
Put the reflector several times, thinking it might loose, but seems not.
Any suggestion?
It is not a bug. It is a feature of XHP leds with SMO reflectors. The cross in the led make the dark center of the hot spot. Try orange peel reflector or replace the XHP50 to XHP50.2
Based on this thread I bought one of these lights. I got it from Fasttech last May. The driver has stopped functioning properly. It is stuck in moonlight mode. It will not enter the programing mode. Fasttech will replace the light but I have to ship it back to them which costs as much if not more than the light. I like the light a lot and use it constantly every day. Where can I get a new, correctly programed driver to replace the old one? Thanks for any help on this.
I also tried a “larger” emitter in mine, a Nichia 144A in my case, but the beam isn’t very good for me either. Pretty bad “egg yolk” effect. My hope is that raising the emitter up higher into the reflector will help but I haven’t had a chance to try and accomplish that.
There’s a Khatod optic, I believe, that works great over a XHP-70, it’s got a large “cup” in the top surface and vertical lines inside the TIR. This tames the donut hole pretty well, I have one in an X6 with extension tube and it makes some 5441 lumens at 10.4A from a pair of the older Samsung 20R 18650’s. Granted, it’s a 35mm optic and the C8 accommodates larger than that, but it’ll work with the lens in place, especially if using one of the holders.
Plain ol’ XM-L, but I had just the opposite in an F13. The come-with spacer was in there, it had a decent hotspot but a little fuzzy, so to try “tightening it up”, I tried pulling the spacer and using a thin PETE insulator instead, to let the LED farther up into the reflector.
Big mistake. Ringy, and the worst fried-egg beam I’ve ever seen.
Swap the come-with spacer again, and it’s back to normal, pretty smooth beam.
Take a stiff spongy material that’s not conductive, make a “washer” out of it, and put that between the reflector and LED. Turn it on (hopefully not hot enough to melt the stuff) and watch the beam as you screw down the reflector. The tighter you screw it down, the more the “sponge-washer” will compress, and the farther into the reflector the LED will go. Loosen it, and hopefully the sponge will press the reflector back out.
This way you can adjust the focus to whatever you’d want, and know that it is possible to get that focus. Then, shave down a real spacer/washer to the appropriate thickness.
Beats repeated swapping of spacers/washers/whatever, trying to remember what was better or worse.
Been there, done that, F13 is spaced nicely as standard. Countersunk top of spacer thinking it was blocking a little of the side throw, which it slightly was, but not worth the effort.
