So what do you do to get the tail PCB out?
Does it unscrew?
Push out from inside the battery tube?
Shake really hard?
I’m still waiting for mine (package in MI but fedex changed expected delivery from 9/21 to 9/25) but based on the ground contact issue I plan to do what I did with my Chimera - form a piece of 12 awg copper wire into a ring to fit into the space between the threads and driver, pound it with a hammer to thin and widen it, sand the flattened surfaces, and use it as a retainer/contact ring between the driver and battery tube. The end of the tube may require a bit of sanding to position the o-ring correctly and adjust alignment of the flats on the tube with the head as desired but it worked nicely on my Chimera. Good contact all the way around and enough output from the xhp70.2 on the wall 12 ft away in a room lit by a 60w equivalent ceiling light to make me squint when I touch the fwd clickie tailswitch.
Been wanting to get NO-OX-ID but never think bout till I could use it. Buddy uses it in his Auto repair for bad connections. It eats up the green. But he said its pricey.
I did also use an M2.5 tap to clean out the tail holes and get glue and anodize out. I did find the sand powder in the driver screw holes. The 1/8th in drill works well for the driver holes and the screws aren’t bottomed out before tight on that size hole.
Thanks Jtm94, now I recall the user name. Can I have my 45min back?
I’m Not Crazy!
I’m Not Crazy!
I’m Not Crazy!
Really… I’m not.
Unscrew the cap off the back end, 4 Phillips screws and it falls out.
Has anyone with pcb design experience considered designing a replacement switch board? It might be the quickest fix. Option of 2 or 4 emitters would be nice and would help reduce apparent uneven output and allow color blending or additional switch lighting features like battery state indicator with a supporting driver/firmware. I’ll be ordering I ordered a 10 color 200 piece lot of 0603 emitters so I’ll have a few to spare.
I ordered a couple of multi color packs a couple years ago. I've been doing these indicator LED's for years now in flashlights. If you want to independently control multiple LED's, that requires some extra hardware - we are I/O pin limited, each LED would take an I/O pin, unless you can add some sort of multiplexer perhaps.
My tailcap and driver screws were screwed on very tightly.
They came off easily after I touched the heads of the screws for about a minute with the tip of a very hot soldering iron.
I also found stuff on my tailcap screw threads which was removed with a fine wire brush.
Since I do not have a tap I reinserted the screws and removed them.
More stuff came out and was cleaned.
I stuck a piece of tyre inner tube to the base of the light with silicone rubber to protect it when tail standing on rough surfaces. e.g when changing tyres.
I used silicone because the rubber can be removed without damaging the Q8.
Updated the Q8 thread OP with:
TWEAK
On some Q8 lights there can be a sandblasting powder residue under the tailpcb and in the screwholes for the tail pcb mounting screws.
On some Q8 lights there can be some sort of glue residue in the screwholes for the tail pcb mounting screws.
No worries it is not conductive, but that does mean there can be bump in output achieved when removing and cleaning it. The screws are very tight, USE A MATCHING SCREWDRIVER AND RUBBER BAND BETWEEN SCREW AND SCREWDRIVER TO AVOID STRIPPING!
Thorfire will clean better during the rest of the production.
CHECK
Answer. yes some lube is very likely required, please add your favorite flavor. Good point about tube, please use file and/or sandpaper to smoothen things out if too rough for your liking.
Again, some screws are clearly stripped before you even touch them. I've encountered a couple screws stripped in both directions, more stripped only in the CW direction. Overall though, it seems more are good than bad. I have a large sample size (9 pieces) to review.
This is the condition they were in as installed, all 4 on the right, left one is good for reference:
This is the glue remnants:
After cleaned up:
…Even the ‘good’ one on the left looks bad to me… No wonder they get stripped - there does not seem to be much surface area for the screw driver head to act properly?
That’s part of the problem. It looks like a phillips that is a little wallowed out. Reports are that it’s actually a JIS.
I found as well glue on the tail in the threads and one light the surface between PCB and metal the tother a big chunk of glue at the outer tube wall
I scratched the glue off and cut all threads again to get the glue out
now the screws get in without any resistance
my brass rings had also some black stuff on the outer diameter where the batteries make contact
Had some fun again last night. Had to use a rotary cutting wheel to create my own slot for a flat-blade to get it out - wasn't easy. The screws are so low, the board tracing of course gets cut a little but I was pretty careful, just took quite a while. They are gone now - all those are replaced with star drive pan heads now - M3 x 5mm (https://www.boltdepot.com/Metric_machine_screws_Star_drive_pan_head_Stainless_steel_18-8_(A-2)_3mm_x_0.5mm.aspx).
They barely clear the end cap, but I don't care - just want something reliable that works as it should.
It can’t be easy for the poor operators, trying to get the M3 screws started in the too-tight driver PCB hole. Then trying to get them started in the metal body, after they have tapped their way through the PCB, with no hole-clearance for alignment. Add in some sandblasting grit as well …
I can imagine the muttered curses, and time-pressure to meet productivity targets.
Then it seems some torches are having glue added (maybe old habits die hard, some are just doing what they were trained to do on standard mass-produced torches). Did we ask for them not to be glued ?
Perhaps the screws are laptop type with JIS heads but the screwdrivers are not, perhaps some screwdrivers are just worn out (should be regularly inspected and replaced as necessary, not just wait for an operator to ask for a new one) etc. etc.
Maybe final assembly is even sent out to a number of “piecework” operators (used to be common practice in China).
Result: chewed heads.
None of this matters much to me, as long as the threads in the metalwork are good, and I can get the original screws out, without too much bother. Heating screw head with a soldering iron first if glue is suspected is a good tip, particularly if you want to re-use them, and don’t want to risk chewing up a good head yourself. If a screw seems unduly tight I also give the screwdriver a good rap on the handle with a soft hammer first to try to break it free before bearing down and going for it.
Believe it or not, I'm seeing worse things with screws in Haikelites - there I get real stripped body threading.
At least for me a JIS J1 driver worked perfectly, but mine weren’t badly stripped at all to begin with.
Interested in parts for q8,driver and switch… And different bezels? :sunglasses:
I want to show some pictures, i dont understand nothing or not too much about the pcb “problems” but i can do things to fix the little things,clean, or easy tasks i want to learn.
Pictures
Its a vicious circle, once you start stripping heads the screwdriver suffers as well, particularly if it is not a high quality one. Production standard tools are expensive, but worth every penny.
Then there is the job of the buyer, who may have no engineering knowledge whatsoever, or maybe is new, and given this seemingly trivial task whilst the senior buyers focus on the difficult stuff, like electronic components, switch LEDs etc.
Tasked to procure at least 18,000 screws needed for the initial run (2000 plus however many more we don’t know about). Maybe in a desperate last minute rush.
Lowest bidder wins, if e.g. material spec. not fully specified, even if made of cheese.
Had some fun again last night. Had to use a rotary cutting wheel to create my own slot for a flat-blade to get it out - wasn’t easy. The screws are so low, the board tracing of course gets cut a little but I was pretty careful, just took quite a while.
Ever heard of screw grab? I wish I’d learned of it 10 years earlier. It’s usually great for dealing with damaged screws. I read lapping compound works as well, though I’ve never used that myself.
