Thanks Agro, I’ve been waiting for this thread! Just ordered the green one with XPL Hi NW yesterday, so I’ve got something to play with until the D4 is back in stock.
The list of recommended batteries seems a direct copy and paste from the D4 which has a much higher output (almost three times) which is why I asked.
In terms of power this is true. The reason you have the same recommended batteries is because the D1 and D4 are both FET driven. This means that you get maximum output with batteries that have least voltage sag, so batteries that are (most) high drain. So with both the D1 and D4 you have maximum output with cells like the VTC6 and 30Q, and you have less output with something like a NCR18650GA (but more runtime on lower output due to higher capacity).
So will getting a battery that goes above 10A really matter for this particular light? Doesn’t this light top out around 6A?
Absolutely. Check out HKJ’s comparator here: http://lygte-info.dk/review/batteries2012/Common18650comparator.php
Punch in Sony VTC6 and Sanyo NCR18650GA. Then mark 5 or 7 amps. You then see that the VTC6 has a higher voltage (less sag) than with the GA. The led is sensitive to minor differences in voltage, so with the VTC6 you get a higher output.
So this means that even if you have less than 10A current, there is still a difference in output depending on cell.
So I should just get the efest 18650 (max discharge of 35A) which would provide highest output and be done with it!
Approximately how much less runtime than the Sanyo 3500mah battery?
hIKARInoob wrote:
treoneo wrote:
Ohhh thanks for the explanation.
Efest does not manufacture cells, they just put a wrapping on them. Efest often (always?) puts higher current ratings than that of the original manufacturer, so I don’t like Efest. You also pay more just for the Efest branding. Regarding runtime, I don’t know the capacity of the Efest you mentioned, but it’s perhaps 3000 mAh? In that case you get about 10% more runtime with GA.
Yes, I accidentally ordered the efest for my MF-01, before I read HKJ’s review. Good to know though that the VTC6 are recommended for this light – that was another accidental purchase I made, thinking they were the button top version. Now I’ll be able to put them to a good use, and have some spares!
It’s a great light, and you can’t go wrong with any of the cells discussed. Just don’t put UltraFire or protected NCR18650B in it or something like that. Cheers man!
Who’s going to be the first to swap a dedomed SST40 in there? Should do 60+ kcd….
Is that better? L2 top left.D4 top right,D1 bottom left.It’s my first time trying images on here.
Nice pics JHW
Will throw a couple in as well
D4 xp-g2 4000k
D1 xpl HI 5000k
Not had change to get any decent pics, need to get out rain/time permitting where i can stretch its legs(so to speak)
If i could i would!! Sounds a beast, however i do like the 5000k HI as is, so i would need another
Sorry no beamshots yet, maybe I will make some later tonight if I can find time
Few random pics
Predator V’s D1…………….D1 wins!
Ok I’ll bite, kinda bummed i didnt get to start the D1 thread
Some random shots from tonight with iPhone 7. As we all know, its brighter in person.
D1
UT02
D1
UT02
D1
UT02
Slow is smooth, smooth is fast.
and some beauty shots
Great pics
Can anyone with the D1 and D4 to compare-
Which has the lowest moonlight level ??
Old Mate
Will this need a high drain battery?
Hard for me to compare, the D1 obviously has a tight hot spot still, lot more intense than the D4’s large hot spot. Both have different beam types.
Yes, the performance will be better when the voltage gets lower through use. You will get less sag for example if at 3.6v and hit the 100% outptut.
I use 30Q in my D1. Ideally any cell of 10a and over would work well . Not tested the amps, i might have read around 6a but not sure.
Finally a thread for the D1!
Whats the throw and lumens on the D1?
I love the D4 but I use it mostly as an extra light, srt-9 as primary. Thinking about getting the D1.
I got 6.03 amps on a 4.18v vtc6.
Thanks for the info
Big throw, little throw
Just ordered one from Mountain Electronics in green along with the 18350 short tube. They should have them in by the end of the month.
Boycott Nike
Sony VTC5A will probably give you the highest output (check it out in HKJ’s comparator), but you sacrifice a bit of runtime.
“My collection”: https://budgetlightforum.com/comment/700139#comment-700139
Thanks for the info!
