Few random pics
Predator V’s D1…………….D1 wins!
Thanks Agro, I’ve been waiting for this thread! Just ordered the green one with XPL Hi NW yesterday, so I’ve got something to play with until the D4 is back in stock.
Ok I’ll bite, kinda bummed i didnt get to start the D1 thread
Some random shots from tonight with iPhone 7. As we all know, its brighter in person.
D1
UT02
D1
UT02
D1
UT02
and some beauty shots
Great pics :sunglasses:
Can anyone with the D1 and D4 to compare-
Which has the lowest moonlight level ??
Will this need a high drain battery?
Hard for me to compare, the D1 obviously has a tight hot spot still, lot more intense than the D4’s large hot spot. Both have different beam types.
Yes, the performance will be better when the voltage gets lower through use. You will get less sag for example if at 3.6v and hit the 100% outptut.
I use 30Q in my D1. Ideally any cell of 10a and over would work well . Not tested the amps, i might have read around 6a but not sure.
Finally a thread for the D1!
Whats the throw and lumens on the D1?
I love the D4 but I use it mostly as an extra light, srt-9 as primary. Thinking about getting the D1.
I got 6.03 amps on a 4.18v vtc6.
Thanks for the info
Big throw, little throw
Just ordered one from Mountain Electronics in green along with the 18350 short tube. They should have them in by the end of the month.
The list of recommended batteries seems a direct copy and paste from the D4 which has a much higher output (almost three times) which is why I asked.
In terms of power this is true. The reason you have the same recommended batteries is because the D1 and D4 are both FET driven. This means that you get maximum output with batteries that have least voltage sag, so batteries that are (most) high drain. So with both the D1 and D4 you have maximum output with cells like the VTC6 and 30Q, and you have less output with something like a NCR18650GA (but more runtime on lower output due to higher capacity).
Ohhh thanks for the explanation.
So will getting a battery that goes above 10A really matter for this particular light? Doesn’t this light top out around 6A?
treoneo:The list of recommended batteries seems a direct copy and paste from the D4 which has a much higher output (almost three times) which is why I asked.
Absolutely. Check out HKJ’s comparator here: Battery test-review 18650 comparator
Punch in Sony VTC6 and Sanyo NCR18650GA. Then mark 5 or 7 amps. You then see that the VTC6 has a higher voltage (less sag) than with the GA. The led is sensitive to minor differences in voltage, so with the VTC6 you get a higher output.
So this means that even if you have less than 10A current, there is still a difference in output depending on cell.
So I should just get the efest 18650 (max discharge of 35A) which would provide highest output and be done with it!
Approximately how much less runtime than the Sanyo 3500mah battery?
treoneo:Ohhh thanks for the explanation.
Sony VTC5A will probably give you the highest output (check it out in HKJ’s comparator), but you sacrifice a bit of runtime.
