Thanks for the answers TK.
Iâd like to add that the memorization of turbo when I wanted to return to regular mode only aggravated the problem that I had anyway - that the action that was natural for me did something different from what I wanted.
I trained myself to do it right now, but I strongly feel I would have been happier with MT02 style return from turbo.
Iâve been using AndĂșril on a BLF Q8 and an Emisar D1 for a few days now.
In short, I love AndĂșril and I want it on all of my lights! :heart_eyes:
I have some ideas for changes and additional features. I know nothing about programming or the time, effort, and space these features may require, so Iâm not gonna hold back.
My favorite features
moonlight mode during lockout
adjustable momentary output
momentary disabled only by power cycling
double click from turbo returns to previous output level
memory for previously used strobe mode
adjustable brightness for bike flasher
âLightning Stormâ mode
Ramping
option to disable click & hold for ramping down? (ramp changes directions like Narsil)
option to disable blink at max regulated output?
Good Night mode
option to adjust starting output level?
option to adjust time until power off?
Possible bug
dimming bike flasher to minimum enables an unbelievably low steady output
Iâm not sure what TempCheck is telling me. On a Q8:
room temperature light - 8 long blinks
after 15 sec turbo - 1 long blink, 1 short blink
after 30 sec turbo - 1 long blink, 2 long blinks
after 1.5 min turbo - 1 long blink, 7 long blinks
after 3 min turbo - 1 long blink, 9 long blinks
More blinkies, please! I realize these are silly and may take up valuable space. If not implemented officially, I may need to learn some C.
party strobe with random brightness / speed changes
defective lightbulb mode
candle mode
other fun blinky modes TK is holding out on :partying_face:
How about a âMuggle Mode?â Iâd like to hand the light to someone and say âClick to turn it on and off. Hold the button to adjust the brightness.â
Part of the fun of owning awesome flashlights is sharing them, especially with muggles. Iâve discovered that many of them, even after training, will randomly mash buttons and enter config mode within seconds of holding the light. Some have been known to turn the light off and forget where they put it. An optional beacon mode at âpower offâ would help shorten hide-n-seek times.
Some ideas for âMuggle Modeâ
uses preset, adjustable ceiling level
disables true turbo
option to disable double-click shortcut, or become shortcut to ceiling
memory works the same as usual
disables click & hold to ramp down, holding the button allows ramping both up & down (like Narsil)
disables advanced features and config modes
disables blinks at max regulated output and at ceiling
option to disable power off, instead entering a beacon mode
If I knew anything about programming, my list of suggestions would probably be much shorter.
AndĂșril is my new favorite UI, and I would happily use it as-is until TKâs next âgreatest UI ever.â
Reversing â perhaps a compile-time option. After using reversing for a few years and non-reversing for a month or two, Iâve found I like non-reversing better. But it would be a good option at build time.
Blink at max â also a compile-time option. I already added one for blink at moon and blink at channel boundaries, so this fits right in.
Maybe, if thereâs room.
Already fixed. This happened because it picks the burst ramp level by multiplying the steady ramp level by 2. At the very bottom of the ramp, though, levels 1 and 2 are actually the same thing, so the burst didnât change the brightness at all. Easily fixed by using a floor level of 2 instead of 1.
I also increased the bike flasher ceiling so it can run brighter than before.
It should blink out the MCU temperature in C. So, it thinks your room temperature is 8 C, and after 3 minutes on turbo it got up to 19 C. The attiny85 sensor isnât calibrated though, so this value can be off by quite a bit. Mostly itâs useful as a way to find out what the MCU sees, which can help with setting a temperature limit. But on a Q8, itâll take quite a while to get hot enough for thermal regulation to activate.
If thereâs room. Perhaps on an inconvenient click sequence, like 8 clicks from off?
Itâs something I want to try, at least. Not sure if itâll be in a build for production purposes.
Youâre very welcome! Thank you for the excellent UIs!
I think I prefer non-reversing too. If itâs a compile-time option, would it be universal or could reversing be enabled independently for muggle mode?
I meant, âcould the blink at channel boundaries be removed?â Compile-time option is fine. I think Iâd prefer no blinks at moon, turbo, or boundaries but thatâs just me. I know some folks are particular about knowing what circuit theyâre on.
Thatâs what I thought, but the scale and the short blink was throwing me off. I think I understand now that a short blink is a zero. One long, one short = 10 C?
Sounds good. Can it be disabled only by power cycling, like momentary?
Ok!
Thanks again for being open to feedback. As I said before, Iâm more than thrilled with AndĂșril as it is! :+1:
You seem to have omitted any mention of additional blinky modes. I *know* you mentioned âdefective light bulb modeâ somewhere but now I canât find it⊠^:)
Added reversing to Anduril. Made EV_tick always send 0 while in âholdâ state.
Rearranged some build options and made sure the build still works if some are turned off.
Fixed issue where double-click-from-off followed by double-click-to-true-turbo would overwrite memory with the ceiling level. (should make Agro happy)
Fleshed out build options to blink at floor, ceiling, and channel boundaries.
Adjusted bike flasher floor and ceiling: floor high enough to make sure it always blinks, ceiling can be higher than halfway up the ramp.
The reversing thing is slightly different than Narsil and Ferrero Rocher. I wanted to make it more predictable without having to remember anything, so if it has been more than a second since the last user input, a âholdâ will always go up. However, if the last âholdâ went up, there is a 1-second window where the next hold will go down instead. Also, âholdâ at the ceiling level always goes down.
So⊠it reverses, but it doesnât stay reversed long enough to confuse a goldfish.
Iâll probably leave it enabled by default, since it no longer has the issue with forgetting what direction itâll go.
As for muggle mode, Iâm thinking itâll be similar to momentary mode where it has no exits (even for âoffâ). Itâll be very very limited. The tricky part is figuring out where to put its config settings, if it has any.
OTOH, momentary mode makes a pretty decent muggle mode if set to a medium level.
I just reflashed a Q8 with this newest version of AndĂșril.
Sometimes a hold from off will remain at moon and not ramp. At first I thought this was only occurring shortly after powering off, but Iâve seen it happen after the light has been off for 30+ seconds. It seems intermittent. I canât replicate this with my D1 running the previous version of AndĂșril. Could this be caused by the new â1-secondâ ramping reverse rule, like itâs trying to ramp down from moon?
Other ramping functions seem normal.
Iâm also getting some faint flickering during the âsteadyâ phase of bike flasher mode. Itâs very faint, and seems to go away at some brightness levels along the ramp.
If turned off while reversed, it could then try to reverse a hold from off. The amount of time it was off doesnât matter for that, since it doesnât measure time while off.
About the bike flasher⊠it runs at ~4 kHz PWM now instead of 15.6 kHz, as a side effect of some power management changes I added a few days ago. Iâm not sure if itâs worth fixing or not, since the fix would cost a fair amount of space. Basically, all interruptible âdelayâ operations run at 1/4 CPU speed. This affects modes which use those, such as biking, battcheck, and beacon. It doesnât slow down PWM in other modes though, like ramping and goodnight, which have no need for explicit delays.
The upside of this is that things like beacon are now much more efficient for longer runtimes. The downside is that the PWM on a few blinky modes might be visible or audible in some circumstances.
Eh, probably not. I only noticed the faint flicker while ceiling bouncing the Q8 to check out the new brighter bike flasher levels. I doubt it would be visible on a bike.
I just reflashed the Q8 again. It sure is nice not needing to fire up the soldering iron!
How about clearing mode memory on lockout? You do this on physical lockout already and doing the same on software one seems logical.
After all if I lock it out, I will probably not use it in a moment.
Independently, time-related functions need to increase power consumption only when they are running. So when mode memory is cleared, you can go back to deep sleep.
You need to put these files in your projectâs folder.
When you create a new Amtel Studio project, it creates a directory structure based on the name of your project. Right click the tab at the top left of Amtel Studio and click âOpen Containing Folder.â Drop the .c and .h files into here and run the compiler again.
Another error you are probably encountering is, âHey, you need to specify ATTINYâ in the tk-attiny.h file. Double click the error, then scroll up a few lines and remove the // from one of the lines reading â#define ATTINYâ and change the number to the proper ATtiny model number (13, 25, 85 etc.).
Iâve got AndĂșril running on a Q8, D1, and D4 now. I love having several lights with the same awesome UI!
I have an EagleEye X6R with a TA driver running Narsil that Iâd like to reflash, too. It has a forward-clicky tailswitch and an e-switch on the head.
Iâd like it to light up at the memorized level when powered up, so I can use the tailswitch as momentary.
I found this piece of code but Iâm unsure what changes to make:
void setup() {
// blink at power-on to let user know power is connected
set_level(RAMP_SIZE/8);
delay_4ms(3);
set_level(0);
load_config();
push_state(off_state, 0);
Am I on the right track?
Also, how can I format code to read properly when posting here? It becomes a mess if I insert spaces at the start of a line.
For that, it will need to save the memorized level to eeprom so it can remember after power loss. And given how often that level changes, it should probably be wear-levelled. This means bringing in the EEPROM_WL code, which isnât otherwise used in Anduril, and making changes in a few places. Itâll cost more than a few bytes.
Yes, thatâs one of the places which will need changes. Itâll need âpush_state(steady_state, value_from_eeprom)â instead of going to the âoffâ state. And, um, get rid of the initial startup blink.
The other changes are larger though⊠I should probably add another compile-time option for it, because this is a request which will probably come up frequently.
As for posting code, BLF isnât very good at that. It can be done, by using a <pre> in the fancy post editor, but usually I donât bother.
Thanks, TK! Iâll wait for a possible compile-time option for âpower on at memory.â
In the meantime, would a âpower up on turboâ option be less complicated? Possibly something I could add/modify myself? Lexel enabled that in the previous install of Narsil when I ordered the TA driver.
