Attach xl4015 or lm2596 to heatsink? Xp-l lighting project
4 posts / 0 new
yclongthrow
Last seen: 4 weeks 1 day ago
Hello,
I’m working on a project which involves running a couple of xp-l leds from a xl4015 device. I am attaching the leds to a large heatsink which will also be actively cooled. I am using the following “drivers” https://m.ebay.com/itm/XL4015-buck-5A-DC-to-DC-CC-CV-Lithium-Battery-Ste... . How would I go about attaching these to the same large flat heatsink as the leds?
Thanks
Edited by: yclongthrow on 09/28/2017 - 13:18
Lexel
Lexel's picture
Last seen: 1 year 3 weeks ago
You can use silocone to attach it to a heatsink with the flat side
Just make sure the heatsink is anodised or use Kapton tape to insulate it
yclongthrow
Lexel wrote:
You can use silocone to attach it to a heatsink with the flat side Just make sure the heatsink is anodised or use Kapton tape to insulate it
Any way to dissipate heat by connecting some parts of the chip to heatsink. Also could it handle 3 XP-L @2.4 amps?
Lexel
Lexel's picture
Those are usually OK up to 3A
3 in series should work well
