I think the same, everything indicates thin wires or a bad DMM; You can try with thick wires directly to the DMM (Digital Multi Meter). I used to have this problem, I and solved it that way with 5mm² (AWG10) wires.
I have to admit i didn't thing to change my multimeter.
I have 2 multimeter
1X25usd from dx and 1X5usd?!?!? from ebay. The results i have with the first dmm is 1250ma, with the second 1100ma but with both of them(in paraller) about 2000ma (first dmm 1100ma, second dmm 900ma).
First i connected the 25usd dmm and then I connected the second.... wow the output was awesome. Since i don't own a third dmm i left the 2 dmms connected in pareller and i added a 1mm 20mm long cable in parallel too.... and wow! even more output than the 2 dmms in paraller so the mystery solved. The strange thing is that the 2 dmms was still had indications when i connected the extra cable(800ma the first and 350ma the second)
So now i need a recommendation for a multimeter(not very expensive) and thick leads for my future explorations
If DD stands for direct drive the answer is yes but as you see the problem was the dmm.
Good news I just got a chance to take apart a Shiningbeam P-Rocket and it had one of these new drivers and I was able to reflash it with the standard setup I have been using on the old Nanjg drivers.
Are you sure it's the same board? It seems to have a quite different pin layout; others said so, too.
Or did you refer to the PIC version of the NANJG105(A)?
Can you take a photo of the driver?
Welcome! IMO you’d be better off with the 1.5A version of this driver if using a 16340, especially if you are using a non-IMR cell. (IMRs are more suited for high current than regular (LiCo) cells). I tend to be on the conservative side, so others may disagree.
Last night I put a 2280 into my Yezl Z1x (UF2100) and boy does that get warm quick. I don't know how you guys with DD drivers in those things handle it.
Thanks mitro! Aside the heat, are there any serious cons with my configuration? Guess battery time will suffer, but if I use aw imr battery and doesnt run it on hi mode all the time it shouldnt explode, or burn the led or something like that…? I think it could be a pretty powerful torch!
