Imalent DX80 32000 lumen monster
First they asked me a ridiculous question, whether the adapter was DC 19v & then no reply! I sent them another message if I don’t receive the answer I may file a case to paypal. They replied almost instantly & gave me an order # but it’s in back order & I don’t know how long do I have to wait. I totally sent them 4 messages plus 2 emails! Bad customer services.
I’m it as DC Power Supply it is possible to see the current value,This not smoke out it? :smiley:
The accessory of DX80 was 18V2A.
19V?? Is this an accessory?
Imalent barely know how to make flashlights, so I’m sure active cooling is even harder for them. Even top name flashlight companies have trouble with it.
About the fan size, even a tiny fan can make a huge impact. Just think of laptop fans.
I marked it spam
True, but then they tend to be noisy.
Better with a big fan at less rpm (if possible).
My AC/DC Adapter also failed after 2 hours during first charge attempt on DX80. I checked with DMM, dead just like the one in the previous post with pic. I contacted Banggood and they replied that I should send pic of packing slip, make video of problem and post to YouTube and send them link, and take other pics which will help them. I answered that is not going to happen. I already sent them 3 pics of the adapter and invoice slip that was included inside shipment showing exact item ID # and all the information they really should need to know I purchased this item and what I paid for it. I requested that they contact Imalent and have them send me a new replacement AC/DC Adapter for the DX80. In the meantime I am using a laptop charger that is also rated for 19V, the same as the Imalent defective charger was. The Imalent charger was rated for 2 amps, the laptop charger is rated 3.42 amps, should be no problem using higher amp charger, the light will only draw what it needs, and it needs at least 2 amps. Any 19V charger with at least 2 amp rating and a 5.5mm X 2.5mm charging plug will work.
But the charger I am temporarily using is for a Toshiba laptop. It has a big brick in the middle with charging cable coming out one side and power cable out the other. Too bulky. So I searched and found a “wall wart” style 19V style charger that is about the same size as the one that came with the light. It is a charger used to charge an Asus laptop. Also has 5.5mm X 2.5mm charging plug. Readily available at your usual online sources.
The light works fine so far and is pretty impressive. Charger on mine is the weak link and a relatively inexpensive item to replace. That is the challenge for Banggood. How much time and energy is a person going to put into getting just the AC/DC Adapter replaced. I think they are counting on most people giving up and not be willing jump through the long list of hoops they require you to jump through.
But I might be wrong. They might surprise me (and a few others) and take my word for the adapter being broken/defective and somehow send a replacement. Funny thing is I’m not interested in a $5 refund that I expect they will offer. I have money, I don’t have a working compact charger for my newly purchased Imalent DX80.
Maybe it was supposed to be in this thread
After confirming well, it was 19V2A :frowning:
For that reason, I could not find it much.
I decided to buy this.
Thank you.I was very saved :+1:
This should also work if you would prefer a smaller more compact adapter:
https://www.amazon.com/gp/product/B01IR1LY30/ref=od_aui_detailpages00?ie=UTF8&psc=1
My Dell laptop charger,writes 19.5V/2.5A.Is it good for the job?
Others might be better able to answer that question. I did research and discovered that Amp rating above the minimum that you need is no problem because the device only draws what it needs, the rest is left as unused potential, and the same is true for Watt rating. A higher Watt rating than the adapter you are replacing should not cause a problem for the same reason. But the Voltage should be the same unless the device (in this case DX80) has a range of acceptable input voltage and that different voltage falls within that range. I have no clue if the Imalent DX80 is set up to accept a range of charging voltage other than 19V.
My electronics knowledge is limited. Hopefully others might be better able to answer your question, and feel free to correct any bad advice I have given.
Voltage should be the same but since its 16,8V battery pack standard 19,5V laptop charger will be fine, and for Amperage bigger the better. Also its much better to find used original charger than those crappy replacement from BG, they will last as much as they cost :confounded:
I’ve got it just now.It seems OK, the charger is OK also.But it is now day hear,so I will play with it in the evening.I hope it will be OK after the try.
If I can open the charger,I try to make several holes through the plastic,for better cooling.
Are all dead chargers for US 110V plug-in, or we have some 220V also?
Thank you :+1: Because it sells to Japan, I will consider it.
I think that the chargers are capable for either 110V or 230V.We in Europe, have received a EU adaptor,so as,putting it on the US tips, it can adapt to European outlets.
Is it possible to open it,so as to drill holes through plastic?It could have better cooling I think, putting a small fan by it.
What is the tip size of this charger adapter? They are not universal I think!
Τhe outer diameter is 5,38mm.
