Emisar D1 / D1S review
No, I am talking about all throwers that I owned. MT02, B158B, UT02, D1. They are all very suitable for walking. Though not for close work.
Though I get your point, at some intensity levels the hotpoint will overwhelm the spill so much that the latter will be useless.
Still, if a medium level throws far enough, a stronger one is counterproductive as it only destroys your night vision. When using a thrower to actually throw I also rarely use high modes.
D1S with the shorty tube might be one of the funniest things I’ve seen in a while.
Thanks for the review :slight_smile:
It’s really up to your preferences. In complete darkness, any type of flashlight is better than no light at all, but if I can choose, for walking I much prefer a floody flashlight with big hotspot and good spill (or a flashlight with a diffuser) than a thrower with a tight hospot and a weak spill.
On an irregular terrain/trail, a thrower at low brightness will tire your vision much more than a flooder, then to have a decent spill with a thrower you will have to go up in brightness and this will result to lower the runtime and ruin your night vision with a brighter hotspot than with a flooder. Where is your “counterproductivity” now ? :wink:
For me and my uses, thrower = long range.
LOL, I think you over-estimate the capabilities of my cheap little camera. :smiley:
I may get to carrying 2 lights, but for now I don’t. Double size, double weight, switching between them is burdensome. So I need some compromise. The best compromise is a zoomie, but I believe that there is not a single zoomie on the market that I would consider good, mostly because of UI. I like B158B even though the UI is something I despise. Still, I like walking with a reflector-based thrower. Most trails here are not too twisty, so I can position the hotspot far enough to be a no-problem. That said, setting up a tent with UT02 in the mouth was frustrating. I need a headlamp. A floody headlamp. Maybe then I’ll be walking with 2 lights.
Different people have different preferences. You’re both right, just for different sets of values.
On that note, I’ve got Anduril on my D1S, which allows a choice of smooth ramping or discrete levels, and I usually leave it in the discrete level mode. I asked Hank to try out an earlier version. He doesn’t want to change firmware every month, because that would be ridiculous, but he did at least pre-install it for me… and maybe if things go well he might be willing to use it at some point in the future (?).
There are some pretty legit reasons to use a thrower on low or medium modes. For example, let’s say you want to see something 50 meters away, and need it to be illuminated to about 4 candelas. All the Emisar lights so far can do it, but with very different power levels and runtimes:
  • D4 XP-G2: 16-17 A, 10-12 minutes
  • D4 XP-L HI: 9.5 A, 19 minutes
  • D1: 1.4 A, 2.1 hours
  • D1S: 0.46 A, 6.5 hours
I hope this helps?
I don’t have a way to measure that, but I’ll be happy to add the data if someone else measures it. :slight_smile:
I’m not sure, but it should be very soon. I think Neal already got some, so RMM should have them soon too, and Hank will probably put up the product page soon too. It sounds like it could be as early as this week, but I’m just guessing.
It’s funny you mention that, since Anduril has a mapping specifically for that purpose. From off, do a double click but hold the second click, and it’ll start at the ceiling then ramp down until you let go.
This works in both smooth ramping and discrete level UIs. They’re the same UI, really, except that one has a stair-step shaped ramp and the other is smooth… so there is no need to remember different actions for each.
I don’t think the D1S will ship with Anduril though. Maybe in the future sometime, but for now it’s still a work in progress.
Me too, but it’s surprisingly well-balanced like that. At least, if you hold it by the button section, which tends to happen naturally, the balance is pretty decent. The back section is small, and the front section is mostly air.
With an 18650 cell, it’s actually a little back-heavy. This is fine though, since with thumb and index finger on the button section, the battery tube rests comfortably on the other three fingers.
thanks for the nice review!
+1,000,000,000,000
Any talk of price yet?
I heard that D1S is a few $-s more then D1 price
Tom, a member of the German flashlight forum (Taschenlampen Forum) is in contact with Hank and will get a D1s for review
He was told that the D1s will be the same price as the D1
http://www.taschenlampen-forum.de/threads/emisar-d1s.59298/
40 ;) to 50 depending on the shop
Toykeeper, great review!. I’m loving my D1 so much that I’ll be buying the D1S as soon as it comes out. The best UI and excellent build quality says it all for me.
It’s good to know that the D1S does not have the quick stepdown of its brothers. I don’t see why I should buy the D1 instead of or in addition to the D1s other than the former being more compact or pocketable. TK have you done a full runtime test for the D1S at Turbo?
I’m pretty surprised to see you compare the D1s to the SR-90 Intimidator, as the Intimidator had a vastly different setup from the factory. If you configure the Intimidator in like kind, there simply is no comparison. With a de-domed XM-L2 and similar amperage as the FET driver, the big SR-90 made 665Kcd for right at a mile in throw.
I really do like the style of this light though and would like to get one as soon as possible, whenever that may be. :wink:
Great review. Can’t wait until it goes on sale!
