I had problems with my laptop compiling anything and I have to ask somebody a favor! I want to build an L6 with Texas avenger 30mm LDO 3 channel driver and with XHP70.2 led with 2S battery setup. I like to use indicator led in the side switch. For the indicator I sacrifice the middle output channel so remove the Nx7135-s from the battery side and use their MCU output pin as the indicator led. Can someone make a hex file for me for this setup from the newest AndĂșril firmware? I will be greatly appreciated!
Thank You!
TK:
An Idea for SMOOTH and DISCRETE
To switch between SMOOTH and DISCRETE you use 3 clicks.
I donât know if you indicate the state to the user.
To show the user what he is using the main LED does this:
SMOOTH:
It dims from low to a brighter level and back down to low. Within one second or quicker. Like a single dragon breath from Manker Lamps.
DISCRETE:
It goes through three brightnessâ steps within a second. Sth. like Low Mid High
wuuHOOuuu vs. TickTickTick
When you add a mogle mode you can use another 3 clicks and blink out eg. low high low high or another sequence.
So you can cycle through SMOOTH, DISCRETE and MOGLE MODE.
It blinks off and back on quickly to indicate that something happened⊠and if itâs going from smooth to discrete itâll also jump to the nearest stair step. But otherwise it doesnât attempt to indicate what happened.
Adding a detailed indication would require creating an asynchronous feedback system of some sort. Itâs not terribly difficult, but it does expose the code to an entire new class of bugs. For example, Narsil does async feedback to indicate which power channel is being used, and if the user clicks during the feedback it can have side effects like turning the indicator LED off. It happens because there are multiple different logic threads fighting simultaneously for control over a shared resource.
Originally this was considered a bug because it wasnât implemented on purpose, but Tom left it that way because he liked it. Not all interactions of this type are going to be beneficial though⊠and Iâve tried to avoid making it even possible. However, I think it should be reasonably safe, due to the way events and tasks are scheduled in FSM instead of running immediately. I havenât tested, but I think the worst effects would be to delay things like state changes until the feedback animation has completed. Or possibly to interrupt the animation, depending on how itâs implemented.
I donât think itâd be a good idea to include muggle mode in the cycle. Muggle mode is intended as a one-way trip, a state you can put a light in before handing it to someone who doesnât know much about it, and they hopefully wonât be able to exit muggle mode by accident.
So the safest way to end mogle mode would be disconnect from power?
I think a battery disconnect can happen in a muggle hand. But a click, click, click, hold or some combination not happen offten.
In a few years we need lamps with a projector LED so we can project a UI diagramm on the ground.
I was thinking power cycle to exit muggle mode, because itâs consistent with how one must exit momentary mode, and it also works for lockout mode.
With a D4 flashed in the right way, itâs actually harder to power cycle than it might seem at first. I got standby power down to 0.35 uA (0.00035 mA), so I can take off the tailcap, walk away to have a conversation, come back, put the tailcap back on, and the light doesnât know it was disconnected from power while it was asleep. So in practice a power cycle means âloosen tailcap, click button, tighten tailcapâ or âloosen tailcap while light is coming out the frontâ.
That depends⊠FSM can technically run on tiny25, but only just barely. It really needs tiny45 before it can do much at all, or tiny85 if you want something fancy like Anduril. And for that, things arenât looking good:
Older e-switch code had a smaller base footprint but used more space for each feature. It could be approximated with something like â500 bytes base + 500 bytes per featureâ. FSM has a bigger footprint but makes additions significantly smaller, like â3000 bytes base + 100 bytes per featureâ. Or something along those lines, anyway.
I guess, to add support, what it would take is a bigger version of the driver with a bigger MCU, preferably SOIC8 (though reflashing pogo pads or holes would work too). It could be tiny85 or tiny1634 like Mike C uses, or tiny841, for the easiest options. For tiny1616/1617 things get more difficult, and for non-AVR options things also get more difficult.
Actually now the design uses a 4x4 MCU and ATTiny85 should fit.
I wonder about the OTSM discussion that I donât understandâŠ
Oh, if it has tiny85 now, then I just need a driver with flashing pads/vias or SOIC8, and I could add support for it fairly easily â some way to reflash without soldering. Not necessarily for production use; just for development purposes.
As for code⊠I donât know what the pinouts are, but Iâd need to add a driver layout definition and probably adjust the ramp tables. Maybe change a bit of init code. And it may also need new code to measure voltage. I seem to recall some discussion about that, and I donât know if it was ever resolved. So battcheck and LVP might not work, depending on whether thereâs a way to measure the battery voltage.
The OTSM stuff is irrelevant for FSM, and for e-switch lights in general.
FSM-based apps shouldnât need any changes, or should need only very small changes. Mostly they should âjust workâ after the base library gets support for the new driver. Change one line per app to select a different driver type, and maybe update anything driver-specific it does (if there is anything).
Overall, porting should be relatively easy. Thatâs half the point of abstacting out the hardware layer and separating it from the UI code.
Glad to read that.
I flashed my driver with anduril firmware and I really like it. I have some questions:
- Is there a way to turn off the thermal stepdown?
- Can you add brighter, dimmer option to the tactical strobe?
1. Disable USE_THERMAL_REGULATION at compile time. (should compile, but is untested)
2. Perhaps. It wouldnât be difficult. Not sure if itâs a thing many people want though; usually tactical strobes only go at the maximum brightness. On small high-powered lights this risks overheating though, so itâd probably be a good idea to lower it for those or make it configurable.
On my Q8 with AndĂșril sometimes in the momentary tactical mode it leave the main led on after a few presses. I didnât know the exact press combination but playing with it and somtimes it stays on. And once I got in ramping stuck in one level and no button presses helped just when I disconnected power.
I still need to tweak the debouncing and event detection a little more, to handle extra-noisy switches. It mostly works, but can run into some weirdness when the switch bounces for an unusually long time. Itâs a bit difficult to test though, since I havenât found any really-noisy switches to test with.
Maybe I can find a noisy switch somewhere in my drawers of parts.
A scope would help too, so I could measure this stuff instead of guessing. I usually do pretty well at programming blind, but it sure is helpful to have data to work with instead of just theories.
I installed Anduril on Q8 and on tactical mode I can get it stuck switched on with the switch released just like ZozzV6 mentioned earlier.
Also there is slight delay when switching the light off. Is it there because of ramp down UI (click, click&hold)? Is it waiting second click&hold? The delay is a bit too long for my liking.
I like lightning mode. Thank you ToyKeeper!
Now I am waiting impatiently for candle mode. Googling for âled candle flicker algorithmâ shows up some interesting results.
The delay is because itâs waiting to see if youâre going to click again for a double/triple click. The timing of that can be changed by re-defining RELEASE_TIMEOUT. The default value is 24 frames.
The delay can also be eliminated entirely by mapping the âoffâ action to EV_click1_release instead of EV_click1_complete (a.k.a. EV_1click), but this will interfere with detecting double clicks. So youâd need to have a âturn emitters offâ action on button release, followed by a âgo to âoffâ stateâ action after the timeout happens. This should be safe, but has the side effect of making it briefly blink off after the first click, even when âoffâ isnât the action you were intending.
Iâm not completely happy with candle mode yet, but hereâs an example graph of its output:
Mostly, it seems a bit too spastic when used at low levels, and perhaps a bit too spastic overall. Itâs like a candle in a breezy environment. Perhaps I should change it from free-running waves to fading waves triggered by random disturbances. Or maybe just decrease the amplitude on the mid-frequency oscillator. Or maybe make the mid oscillator fade and refresh at random. Itâll take some experimenting. It already does a random sample-and-hold modulation on the mid oscillator frequency, which helps, but it feels like it needs further adjustments.
In another thread, âstephenkâ mentioned that an adjustable strobe frequency is useful for light painting.
I suggested he look into AndĂșril, with its adjustable-frequency âParty Strobeâ and âTactical Strobeâ modes.
He then mentioned that a momentary strobe would also be useful.
Could AndĂșrilâs momentary mode also work with strobe modes? If not officially supported, could it be a compile-time option?
Momentary strobe? Thatâs not a thing Iâve considered.
I added it as a âTODOâ note in the code, but I donât have any plans to add it in upcoming production lights. I suspect that my rainbow saber thing may be more relevant for light painting anyway, since itâs specifically designed to make pretty patterns in the air while swinging a lighted sword. It does whatever patterns the user tells it to, and has a full color palette to work with. This includes a momentary âoverdriveâ function, which could potentially be configured in a manner similar to what he might want.
âŠ
Hmm, I just tried it by turning the brightness down all the way on a police flasher mode, hoping that itâd become momentary-only so it only lights up in overdrive. However, the brightness mod is additive instead of subtractive, so it still flashes while idle â just not as bright. Overdrive works fine, but the non-overdrive isnât dark like I had hoped. This could be fixed by making it subtractive, but Iâm not sure if thatâd be a good idea outside of this momentary thing.
