^ wow, nice job Lexel, if it works as planned I guess you will have quite some customers for it. And the switch will be as good as silent too I presume.
Iām still stuck with the bezel of my X7Rā¦ it has been freezed in the freezer, then heated with the hairdryer but nothing seems to free it
I was frustrated so instead I put the 3*XHP70 in my X7 :
Thousands lumens of 80CRI 4500K goodness
4500K with CRI 80 is a really sweet light source
My R50 got the same flavour with an XHP50 yesterdayā¦ Kiriba-ru sure got some nice emitters, at a nice price
My first Smini. Emitter had to GO. Went with XM-L2 T6 4C on a 14mm Sinkpad. Was the Black with Cu bodyā¦ Now itās CRX inspired.
Very nice VW, very nice indeed!
That turned out awesome! Guess I need an other s1 now.
Thanks DB and Geuzz.
Just a heads up there is a silver plating under the Black (PVD?) I literayy had to hand file it off the entire light where the Copper is exposed. Sanded with 220 on up to get it to polish as seen. Was a lot of work but looks neat.
Cool
Very handsome, vwpieces! So the black in the grooves is still PVD-coating, this finish will last very well, should still look nice with a patina.
Nice spring bypass.
One thing I like to do with spring bypasses:
Cut a small piece of copper sheet into a disk and put that on the end of the spring facing the battery. Having a bit of copper there helps protect the solder from friction. The spring bypass tends to last longer.
CRX Approved, Thanks!
The Bezel and E-sw ring were the Blue. I tried the warm sodium hydroxide solution and no joy. They are Brass. To my suprise, it wasnāt till polishing it that the blue came off. The Lye may have actually helped a bit. The original emitter MCPCB is copper but super thin. To get the thicker Sinkpad in there I filed the bottom of the optic shorter and reamed out the bottom hole with a 60* reamer to fit over the XM and sit on the pad. Bad thing is that changed focus and the Smini now has a Square Spot. Like a zoomie but big. Mostly only seen on turbo.
This thing will be coming apart again. Change some things and mostly larger guage wires.
Thanks djozz.
Yes the black is the original coating, pretty hard stuff. The flats polished again after getting sanding scuffs.
Waiting for Patinaā¦.
Hereās my first LED project in a long time. Itās a 50W automotive light bar I purchased from Amazon that Iām modding into a UV inspection lamp.
Luckily when I opened the light up it used what I think are Cree emitters with the 3535 footprint. This made it easy since I was able to remove all of the LEDās and the 5 buck converters and reuse the MCPCB with the Lite-On 365nm emitters. Some jumper wires had to be soldered down to run the LEDās in series, but it wasnāt a big deal.
Here I was testing out the LEDās. My power supply maxes out at ~31V, so only 8 of them could be tested at a time.
The datasheet shows a Vf of 4.0 @ 500mA, but here it shows it to be closer to 3.45V.
9 of the LEDās have a consistent color, with one of them being noticeably āwhiterā. This whiter LED still appears to fluoresce objects as much as the others, so I wonāt bother to swap it out.
I mounted an aluminum project box to the top of the lamp for the dimming pot. It looks a bit ugly, but itās good enough for this project.
The heatsink is more than adequate. At roughly 17W for an hour the temperature only reaches 33Ā° C.
The only thing holding it back now is the window. The one that came with the light bar was made of polycarbonate and blocked nearly all of the UV. I have a piece of Starphire glass at a shop right now being cut to the appropriate size. I should have it back this week and the lamp will be complete.
Nice UV-bar! What kind of inspection would you use it for?
(One of those LiteOnās that I tested was 3.6V at 500mA, but there was a clear design change at some point, that may have affected the voltage too)
Nice UV bar can you link the LED bars seller?
Just thought if you go for sapphire glass why not a ZWB2 filter glass installed?
The SST 10 UV may be also promising with XPL footprint and low thermal resistance
just the important thing would be to see what kind of Wastelight the SST has, like the Lite-On or no like the Nichia
thatās a nice aluminium case! i like it
Good mod by the way
Thanks! This one will be fixed to a printing press. Often clear coatings must be applied to the labels which is difficult for the press operators to see and register to the images. A small amount of optical brightener is added to the coatings formulation (usually less than 0.5%) allowing it to glow when viewed under UV. This lamp will be an upgrade over the fluorescent blacklight lamps that weāve used in past. Those tube lamps donāt produce enough UV to make some colors of optical brighteners to fluoresce.
Thanks, sureā¦ Hereās the Amazon link.
The bandpass filter would be a nice addition. I looked at filters briefly a few weeks ago, but wasnāt able to find one with the correct dimensions or one that wasnāt outrageously expensive. Maybe thereās a ZWB2 film that can be applied to the glass window? I havenāt looked into that yet.
If this lamp does works well, Iāll have to assemble several more. Next time I can mix it up with the SST-10 LEDās and do a comparison. Iāve been wanting to play with the Luminus UV emitters since they starting releasing these less expensive variants.
Can you link the Luminos Emitter?
ZWB2 filters should be cheap availiable in rectangular sheets
Im home alone tonight so I decided to mod my H03 side LED because dont like red colour as itās not efficient.
Blue colour
Green colour
white colour without rubber boot
i also made AA vampire light from plumbing parts fits perfectly (just plug and play)
The light can run on dead AA bateries people throw in the bin and it will run about 2 weeks continuously
Forward clickie fit in perfectly.
no machining is needed
