The intention for this is not to replace a normal tail switch, but external switches
with a spring bypass this will be the same as with a normal tail switch, so you can run your 3000 lumens light with a remote pressure switch without smoking the switch
the external remote switch becomes basically just an e-switch, with the FET replacing the tail switch
Can you make a part list for this? I mean what resistor valuse and diode and an example fet type. And then I will build some for me. Can you eliminate the button battery with a bleeder resistor or it doesn’t work without it anyway?
If you used a PFET you wouldn’t need any gate supply at-all.
And a couple of nand gates could give you a toggling on-off switch, it might need e.g. a cap. and maybe a little bleed resistor to hold up supply to the toggle, or not.
I think someone on CPF used to make these, with NFET and cell, a while ago.
But for e.g a gun torch, just direct drive through a FET in the tailcap works so well. Whether triggered by a button, or remote switch.
You mean a P-FET should work just connecting ground to it, this one needs a bleeder probably on the main driver
just unsure if this one would need a gate resistor to positive side, which would let the main LED glow very low
I have searched for a suitable source and I think I found a few with lower resistance and working voltage down to 2V
The gate resistor is necessary to keep the thing switched off, but it passes no current when off. It is just there to ensure the gate is discharged, any tiny leakage might mess things up. No power consumed. No LED glow.
It does work. There are good PFETS around these days, this is a standard arrangement for reverse protection or totally removing power (ignition switch) in automotive applications, and there are some great devices.
NFETs are what youngsters are trained about, and the modern logic-level ones are so impressive, compared with e.g the first IR HexFets that I helped design over 30 years ago. But PFETs have developed too, and are fit for purpose in this sort of thing. On and off. Maybe not fast PWM.
We used to worry about mobility of holes vs. electrons, but that is less of a problem these days (but electrons still move much better) .
I looked at good P-FETs and I found one Vishay, the thing is it costs more than the battery with holder for the N channel, also the battery increase the overall thickness of the board so it is more compatible to regular switch boards with the switch taking a few mm extra space
I have ordered 3 remote switches
9 boards
10batteries
not ordered the Mouser parts yet
if there is demand here to buy this board please respond if you want it with switch or just the board assembly
1. luminarium iaculator
one board?
or all parts to mod your tail cap?
size 17 or 16mm?
Well I can’t remember where I posted it years ago but I made my own FET remote switch with some air wiring and random parts I had laying around. Currently on my 12-gauge pump switching an XHP50 in a C8 fed from a couple 18350s. I’ve been meaning to teach myself Eagle so I could design a neater solution, but I haven’t. So I’ll be in for a few if these turn out well. I’m actually really interested in a PFET version if it saves space as the 2S 18350s are a bit of a squeeze. Plus I’m considering boring a C8 tube to take a 21700 and need the length there too. Additionally, I’d feel more comfortable not relying on the coin cell connections in a high recoil application. Though my hack job homemade setup has done surprisingly well…
Sure put me in a list for one with cable… If I will like it I will order more.
I thought that 20mm boards are more standard ones? 90% of Uniquefire flashlights, Brinyte, Mitkos Supwildfires etc….
Let the reference of Omten or Kan 28 switch guides you… Flashlight who has them installed must have at least 20 mm switch board because their size is 18mm(cube) and 19-19,5 at contacts below.
But of course I am still in cause it is no problem for me to piggy back it to 20mm board
Yes… Contacts must be solid and I think it wont be problems.
How to simulate recoil? Take flashlight in one hand while holding pressure switch turned on with other hand and then take your best and hardest twitch with a hand like you’r gonna throw it to floor. Do several of “simulating throws” in a row and if flashlight will not loose a contact you have good setup.
I have probably misled myself, and you, about the PFET implementation, It isn’t really any different from the N version, i.e. still needs gate drive, which isn’t available at the tail, once the FET is turned on.
Sorry about that. I was mis-remembering a design for a gun torch, where the “driver”, actually just a FET, was in the head, and the remote switch hardwired into it at the head, not the tail. A PFET was used to switch the positive, it was a modified incandescent torch being used, not LED, and this seemed the easier way at the time.
I found the old CPF article where a similar method was used to replace a mechanical clickie tail switch, which were not so robust at high current in those days.
The replaceable coin cell seems the best way, but if wanting something permanently soldered in, even potted, perhaps e.g. a Panasonic VL series, recharged through a bleed resistor and some simple method to maintain the correct 3.4V.
Another application for this switch is to allow the use of longer cells in some clicks lights or as a tool in many homebrew builds. I’ll be waiting for the final parts list as I’ve too been waiting for something like this:) it’s been talked about a number of times but nothing ever really came of it. Looks like you’re making it happen. Yay!
I’m running a boss head with 2x IMR 16340’s so probably well over 2,000 lumens. Using a stock SF tape switch and have had no issues. I would certainly be interested in looking at this for a different build I’m working on.
I’m still fairly new to BLF, hope a cut-down image of a rifle forend is allowed
