Emisar D1 / D1S review
Thank you for the explanation!
I searched for petals on my lamps, it turned out I have only TIR or orange peel lamps. No smooth reflectors in da house.
:blush:
With the exception, Joe, of the Q8, right? :wink:
I was curious about the D1S runtime, so I’ve been playing around with zak’s ceiling bounce app in my NIST-certified integrating bedroom closet. Even set to a very high thermal limit, the D1S throttles down pretty hard after about 5-7 minutes and takes more than 20 minutes longer to settle at a stable output level. With a lower limit, or a higher drain cell like the VTC6 (“d1s test”), the “hump” is even more pronounced. I will repeat the tests with a proper shoebox setup soon, but I was surprised the D1S couldn’t handle a bit more since I almost exclusively use it outside where it’s cool enough the thermal throttling never engages.
In contrast, the D1 also drops down, but manages to stabilize fairly quickly.
For reference, Convoy C8 and Manker U21.
Guess I’ll have to build a copper helping hand for my D1S….
(if/when I see it, that is. 25 days and counting)
Can someone who has both a D1S and a decent pair of calipers give me an idea of the overall diameter of the head? I’ll see if I can get a chunk of Tellurium copper to beat my D1S home…
My cheap digital calipers are far from “decent,” but here’s what I got:
Bezel is 50.09mm diameter.
Switch area is 35.97mm diameter.
Bezel to start of taper is 35.47mm.
Bezel to end of taper is 41.14mm.
Bezel to end of head is 64.23mm.
Hope this helps! :smiley:
I always get ahead of myself… in the beginning of this thread the 35mm diameter is quoted… so I ordered a piece of TeCu 38.2mm in diameter by 76.3mm in length. Tonight was the last night of a nice discount, so I hurried. :frowning:
It’ll be all right though, I want to start the copper just above where the emitter shelf is so I can cut threads and inset the new emitter shelf. :wink:
Thanks for those numbers… know any mojo to get my D1S to arrive? :smiley:
Ah, I see what I did…. I got the 35mm bezel diameter of the D1… oh well, I’ll make it work, just need the diameter where the emitter shelf is and that should be around 36mm at best guess, 38.2 will have to do.
And no, I’m not planning on using the entire 3” on this light, I have some other things needing this copper. :wink:
I think it involves chanting “Emisar,” in a darkened room with a few lights running Andúril’s ‘Lightning Storm’ mode. :partying_face:
No problem, just order a D1 too. Problem solved! :smiley:
Yeah, we know! :wink:
Oh, I’ve got a D1, and a D4 (or two) and the grey D1S should be here someday. And then I’ll probably make it look something like this, albeit a bit less disjointed…
DB Custom
:slight_smile:
yup, but I assume the reason for the Q8 petals are the four LEDs.
Arrived now D1S gray, 3 minutes in my hands. :heart_eyes:
Wow, wow, nice!!
Joe, I was referring to the smooth mirror finished reflector cups in the Q8. :wink: The flat sides of the XP-L are due to the fact that the die is XM-L sized on an XP substrate, so the dome had to be flat sided to fit. These flat sides cause 4 “petals” in the beam profile of a mirror finished reflector. It’s a reflection of the emitter in the shiny coating.
My gray D1S just shipped from Mountain Electronics. I should have it in a couple of days :slight_smile:
Can we get some more D1 vs D1S beam shots?
Sure, you have to take a look in the German Flashlight Forum (TLF) :slight_smile:
A review from Wiestom with Beamshots from Underground
http://www.taschenlampen-forum.de/threads/emisar-d1s-pocketthrower-review.59797/
Or you can have a look at Bluzies Beamshot Series in his garden center (in alphabetical order) for comparison
http://www.taschenlampen-forum.de/threads/lampenliste.53366/
Go ahead…… twist the knife, will soon be a month since I ordered from Neal and shipping only says “has been processed through a facility in China” :disappointed:
I know its not Neal’s fault but it would be nice to have better updates from the shipping………… like “its on the boat” ……. surely they dont use air freight or it would already be here.
My overseas packages are almost always 13-15 days. My D1S was delivered in14 days. It was 9 days between “has been processed through a facility in China” to “Processed Through Facility
ISC LOS ANGELES CA”
Mine was shipped on the 15th.
When was your shipped/accepted?
My D1S from Neal was Nov6 first tracking in China and it took 20 days to show up with a Chicago entry to US and finally it should be in your neck of the woods (“Gulf Coast”) by tomorrow (via USPS). I know DB Custom is having a similarly long experience and also from TX. I think it’s just taking longer than usual right now.
