GearBest's Entry into Flashlights, the zanflare f1! First Light from this manufacturer!
I have no idea what a $100, or even a $40, light is like. I suspect though that unless you have very specific specs/needs, the gap between a $100 light and a $40 light is pretty small, and mostly in accessories that are probably only worth $10/tops.
I’ve got them both at hand right now, and I’d say the BLF A6 and the Zanfare F1 (received ~1week ago) are pretty comparable.
F1 is, indeed, a bit larger than the A6, certainly enough to notice in a pocket. F1’s anodization is a little glossier, but it isn’t clear that it is any thicker or thinner. The F1’s anodization is definitely more consistent — under strong light, none of the pieces on my A6 quite match. The F1’s clip feels less substantial.
I agree the F1s tail switch is a little mooshy feeling, a compromise, I’d guess, to make the tailcap shorter. Given that the switch is only used to turn the light on or off, I think that was a reasonable tradeoff.
The F1’s tube definitely has a bit more clearance, but the A6 seems like it would have trouble fitting the diameter of a thicker double-wrapped protected 18650 (I don’t have one to check with). The walls of the F1s tube seem as thick as the A6. They did do something interesting though, they have increased the inner diameter of the tube in the middle section, under the knurling. I’d guess the wall thickness is about the same throughout though; the knurled section has a larger outer diameter. I suspect this was done to reduce the weight. It might also reduce heat transfer from the head to the 18650 cell. I think it does contribute to the battery feeling like it has more play.
The microUSB cover on my F1 was very hard to loosen the first couple of times, but now it turns while still remaining securely snug.
The beam of the A6 is probably better closer up, as well as being slightly “cleaner”
I think I’ll end up using the F1 more, for two reasons. First, I like having the side switch. Second, the USB charging makes it much more self contained, which makes it more useful in many situations.
The USB port also makes this more practical as a “muggle” If I given someone an F1+a battery, they can just use it.
Some of the descriptions sound a little like ‘quality fade’ to me actually…
“Tinny”, “flimsy” and “hollow” is not how i would describe mine which i got a couple of weeks (months?) ago.
Umm, yeah, it’s supposed to screw on, not push on. Think you got a borken one.
Dunno who said it was worth 100bux. I don’t think any light is worth 100bux unless it could light up Sputnik or something.
At this point, maybe I’m jaded or something, but I wouldn’t go out of my way to pay more’n 30bux for a light, and it’d have to be droolworthy for me to do it. Still kicking myself for paying 80bux for my Quarks way back when. I just didn’t know better, and thought it was a “premium” light. It is, but not 80bux worth.
So I’d put the F1 in the 20-25buk price-point. Still love the design, but, yeah, there’s a limit.
At 10bux if I can score another one, I will. I kinda sniff at the 12.99 coupons, though, like, “nah, I’ll wait for a 9.99 one before biting again”. :smiley:
’Though I gotta say, with the exception of the green beam, all the ones I’ve gotten so far were nearly perfect.
I’d hope not, as that’s a surefire (haha) way to permanently damage the Zanflare name.
After that happens, they can design pure gold and no one’ll buy ’em.
Hi Y’all
I bought one of the first batch of these and liked it so much that I bought another one at the recent special price. It was delivered yesterday.
I don’t see any difference between the two. After playing with them for a while, I’m not sure which is the old one and which is the new one. Switches are both solid with a firm click. Finish is the same….it’s all the same.
For almost any single cell pocket style light that uses a single cree emitter, there is a clearance sale at LiionWholesale on the LG M26. It’s a flat top 2600mAh cell with a 10A rating, on sale for $2.99 each. Cheapest decent cell I could find.
They also have a protected button top in this cell for $4.49 each. And a clearance on Samsung 30Q button top for $5.09 ea. Worth looking into, if you’re in the US and in the market for a cheap cell or 10. :wink:
Push the ring up and over the o-ring, and then you can screw it. No point push and screw at the same time. Make it two steps is better in my opinion.
Mine came very tight, after unscrewed, i don’t screw it so tight.
Well, it is not perfect, but it is as good as all my other lights. In my case, UT01 and SC02 have more minor quality glitches compared to F1.
And i bought it last month.
On checking it again, it does seem to work like that. Maybe if mine had come fastened I would have realised. After working it a bit it managed to ride up over the second o-ring and tighten quite securely. I have been too harsh on this light. Now that the ring works the only thing actually broken is the lanyard end stop, it is a good light otherwise, just oversized for what it is and with poor mode spacing.
Mine was very tight that i have to search around my house for clothes that’s grippy in order to twist that damned ring. And i even search BLF to confirm it’s closewise or counter clockwise. Looks like the operator who assemble F1 has used up all his grips strength, that’s why yours is not fastened. :person_facepalming:
I wonder why every single Zanflare product is so extremely over-sized. Flashlights F1, F3, F2 as well as charger C4 are all very nice quality and well designed products, but why make them so unnecessarily humongous. :person_facepalming:
An the tube light in question here, the built in charging takes up extra space. It would be quite close to the A6 or S2+ without the charging section.
My new Zanflare F2 2xAA light is very nice, the beam profile is much to my liking and I think they did a good job with this one. Sleek and stylish, firm clicky switch, nice design, with an indicator for low battery.
Received my CW F1, and I’m impressed. Finish is good, nice beam, and I had no problem accessing the USB port. I actually like the UI quite a bit. I would like to see a little more aggressive knurling as it feels a little slick, but not a big deal. It’s a keeper for me, and definitly worth the money I paid. The USB charging & port design are a plus for me. I’ll recommend this light to my friends.
I got one of these in today in good working order. Did not find anything “tinny” about it. In fact the tube is considerably thicker than my A6. It is larger than I care for but I intend to give it to a friend because of the USB charging ability. I am well pleased for the price
Is the head of the F1 still glued shut? Or have they stopped that? I’m thinking of getting a 6500K version, but I don’t like glued heads on my flashlights.
I have no problems with my F1 as well. I like the precise machining and really like the warm light tint on this one.
Definitely worth the money paid (USD 10).
I forgot to add that my F1 came with 2 spare o-rings included, along with the clip, USB cable, lanyard, and neoprene pouch. The zippered pouch, btw, is pretty funky and awkward to get the light in or out of it. Probably never use it because of this, but possibly if the light is being stored in one of our vehicles where it’s not used very often.
I had paid $15 for mine (lowest I’d seen), and will probably buy a few more at some point now that I know what they are like, especially if I can get them at the $10 price. Where are you guys seeing this price at?
I thought the pouch was funky at first too. However, I keep my F1 in my lunchbox (a small cooler) and the pouch keeps it from getting beat up. I actually like it very much now(the pouch). The F1 itself is awesome for the money. Just got my first Convoy S2+ today and I’ll have to think real hard about which one I like best. Both very nice lights.
Quality wise, the pouch is among highest quality pouch I have seen for flashlight for example 4Sevens X10 pouch. A bit hard to get F1 in and out of it though.
That’s why I consider it a storage pouch, rather’n a holster.
Fits nicely into a Jaxman holster now at FT. https://www.fasttech.com/p/7569100
(Also fits most tubelights like the S2+, as well as the Jax E2/E2L and the like.)
Nice! Is the holster bigger than the Banggood Astrolux holster below? I bought two of this but forget to try on F1.
