"Group Buy" Interest: Q8 MCPCB for Luxeon V/SST40/XML/XHP50 Emitters
Interested in 1 or 2 depending on price
Thanks djozz. :+1:
Sunday bump.
Neal will contact Sundy tomorrow. I do not know what his threshold will be before he continues with the order but it would be nice if we can get to 100 boards in another few days.
Put me down for two please :+1:
Monday morning bump. Current quantity is 56 boards.
We seem to be a bit stuck with a little over 50 boards. I would have thought that interest in 100 boards would be met in a week.
I hope and at the same time do not hope that Neal goes on with the order, I like this board to come true, but I do not like to be the one that talked him into many many unsold boards.
I think its a good idea to share this in German, Italian and CPForums, maybe someone speaks Russian as well to share there
Maybe it is nice to add here or in OP for which specific LEDs this MCPCB board is suited and which components need to be added for the thermal measurement. Does it work without it, LEDS only?
I assume it needs a special driver?
The development thread is so huge, it might put off various buyers.
Maybe change the heading?
Would 1.6mm PCB thickness be ok, or it must be 2.0mm?
The stock board is 2mm and the reflector and bezel fit with no room to spare. The o-ring is not so much compressed that I expect it to get away with .4mm less compression.
But thermally, 1.6mm is no problem, the first prototype had a 1mm board and worked fine.
I was trying to figure out how what to change the heading to in order to make it more widely appealing and took a hard look at the board design in the first post.
I think the 12 and 6 o’clock LEDS would benefit from being reversed. Am I reading this wrong?
Good ideas on both points.
I know this isn't really a Group Buy situation, but that is the most common paradigm here for purchasing a newly developed product. Maybe change the subject to something like this:
The 6 oclock can’t be reversed without reducing the ground trace thickness, best to leave it like it is.
The 12 oclock LED could be switch around, although it seemed more confusing that way with the LED’s orientation switching so much, although it is still kinda confusing, so I doubt it would make a big difference. Just be sure to check the labels when installing the LED’s.
Which does point out one mistake, I forgot a - sign on one LED.
And besides, the gerber files are already at Kerui, I would not like to confuse them with different versions if changes are mostly cosmetic.
Yeah, it will not change the function at all, the - sign is not a real issue since the + is still there on that LED and basic common sense should tell people which way the LED goes lol.
interested in 1
I wrote it in the Q8 Thread of taschenlampen-forum.de: http://www.taschenlampen-forum.de/threads/blf-q8-skyray-king-groupbuy.48158/page-4#post-859253
TA, I am absolutely certain you have forgotten more about this than I even know. So please understand that I am confused rather than challenging you. Why would reversing the LEDs as shown in this MSPaint masterpiece shown below require a reduction in trace thickness? ( And are we talking thickness or width?)
Keep the 2 that have the ground trace to the middle
The 2 LEDs on the right add 2. ground trace outside
And I would rotate all other LEDs 90 degree so the negative side is outside, so you get max ground trace thickness around the board
Add a 3. wire hole so 2 positive leads can be going to the driver, also do 2 pads for positive one up one down
Add 4. wire hole so 2 negative leads can go to driver and 2. ground pad on rhe right
also add a solder point on the right to make a bridge to the other ground point, like 0.35mm2 lead should fit below the reflector
