Acebeam K30 NW review w/ measurements (XHP70.2, 3x18650)
12 posts / 0 new
maukka
maukka's picture
Last seen: 6 months 4 weeks ago
Disclaimer: The Acebeam K30 was provided for testing by manufacturer free of charge
The Acebeam K30 is one of the smallest, lightest and brightest 3×18650 single emitter lights on the market. It sports a powerful XHP70.2 LED with an output of 5200 lumens.
According to Acebeam the K30 is their most durable flashlight to date. Even if the K30 is not a diving light and shouldn’t be operated under water they give it a waterproof rating of 5 meters submerged or up to 10 meters momentarily. Impact resistance is typical at 1.2 meters though.
The K30 is available in neutral and cool white with either a black or sand finish. The version tested here is the NW one.
Manufacturer’s specifications
Battery: 3×18650 (accepts button and flat tops, protected and unprotected, batteries not included)
LED: Cree XHP70.2 in neutral 5000K or cool 6000K white
Waterproof: 5 meters
Impact resistance: 1.2 meters
Mode memory: yes (except moon, turbo and strobe)
Low voltage protection: side switch led indicator when battery voltage low, LVP cutoff at 8.5V (2.83V per cell)
Thermal regulation: yes
Lockout: electronic
Output specs
Maximum output: 5200 lumens (stepdown to 2000 lumens at 2 minutes)
Other output levels: 2500/1350/600/200/2 lumens
Light intensity: 35000 candela
Beam distance: 374 meters
Special modes: strobe, sos, beacon
Measured dimensions and weight
Length: 119mm
Head width: 48.2mm
Handle width: 43.1mm
Weight: 171g plus 140g for the batteries
Box and contents
Acebeam has really upped the game when it comes to presenting their products in retail boxes. Nice stylish container with magnets is a big step up from the brown box.
Bundled in the box with the light:
Lanyard
Holster
Two spare o-rings
User manual
Warranty card and a lithium ion battery warning
Physical appearance
The K30 is a bit slimmer than a soda can, so they call it energy drink sized. The head is just 5mm wider than the body, but visually the light is pretty much a cylinder. The design is restrained but stylish. The best thing is the size though. It fits your hand perfectly and is very light for a 3×18650 flashlight. Balancing is great too. I had no problem carrying it with me for extended periods.
User interface
The light is operated via an electronic side switch. There’s an indicator LED next to it to tell you that the batteries are running low.
Green: >10.5V
Red: 9.5-10.5V
Blinking red: 8.5-9.5V
Low voltage shut off: <8.5V (2.83V per battery)
From off:
Click side switch to turn on the light on the last mode used (low, mid, high)
Double click for turbo, two additional fast clicks for turbo max (light turns off briefly between clicks when activating turbo or turbo max)
Triple click for strobe
Long press for firefly mode
3 second press for lockout mode or unlock, light flashes twice to verify lockout mode, another 3 sec press to unlock
From on:
Click to turn off
Hold switch to advance to the next mode (low-mid-high-low…)
Double click for turbo, additional double click for turbo max
From firefly:
Click to turn off
Hold switch to return to normal mode cycle (next mode memory bug)
From turbo or turbo max:
Duble clicks alternate between turbo and turbo max
While the mode memory on the main modes works fine, there’s three next mode memory bugs in the UI:
1&2. When you return to turbo from turbo max with a double click, then hold the button down to return to the normal mode cycle the next double click will go straight back to turbo max, not to turbo first. But if you return to the normal mode cycle from the turbo max, then the next double click will activate turbo. Also, when returning to the normal mode cycle from turbo or turbo max, it selects the next mode from previously used:
It works like this:
Low (2x click) turbo (hold) mid (2x click) turbo max
When it should be:
Low (2x click) turbo (hold) low (2x click) turbo
Another example:
High (2x click) turbo (2x click) turbo max (hold) low (2x click) turbo
Should be:
High (2x click) turbo (2x click) turbo max (hold) high (2x click) turbo
3. If you start the light on firefly with a long press and the previously used normal mode was low, it jumps to mid after you hold the button from firefly. If the memorized mode is mid it advances to high. From high it goes to low:
Low (click) off (long click) firefly (long click) mid
Mid (click) off (long click) firefly (long click) high
High (click) off (long click) firefly (long click) low
Should remember the mode:
Low (click) off (long click) firefly (long click) low
Size and beamshot comparison
BLF Q8 (4×18650), Acebeam K30 (3×18650), Thorfire TK4A (4xAA), Convoy S2+ (18650)
The Acebeam has a bit more of a golden tone to it than the sand Convoy S2+.
Individual beamshots
Beam and tint
I have a new setup for more accurate characterization of the beam. The beam properties were measured by controlling a small servo with a computer (Pololu Micro Maestro + Futaba S3151). The flashlight under test was attached to the servo with a rubber holder and a velcro strap. The servo was turned one degree at a time and a measurement was taken with the i1Pro spectrophotometer between the turns. The process takes about 15 minutes and it was repeated twice. The results are the average of these two cycles.
The floody beam profile has a distinct tint shift from the greenish hotspot to the even greener corona and purplish spill we have come to expect from Cree’s latest offerings. You either can’t stand it or you don’t mind. But it’s there. It’s much less noticeable in actual use, but very visible when shone on a flat surface, be it a white wall or ground – especially snow covered.
Tint within the beam:
Tint in different modes:
Spectral data and color rendering
For spectral information and CRI calculations I use an X-rite i1Pro spectrophotometer with HCFR, Babelcolor CT&A and ArgyllCMS spotread for the graphs and data. For runtime tests I use spotread with a custom script and an i1Display Pro because it doesn’t require calibration every 30 minutes like the i1Pro.
Explanation of abbreviations
CCT = correlated color temperature, higher temperature means cooler (bluish)
CRI (Ra) = color rendering index consisting of 8 different colors (R1-R8), max value 100
CRI (R9) = color rendering index with deep red, usually difficult for led based light sources, max value 100
TLCI = television lighting consistency index, max value 100
CQS (Qa) = Proposed replacement for CRI, RMS average of 15 color samples
CRI2012 (Ra,2012) = Another proposed replacement for CRI, consists of 17 color samples
MCRI = Color rendering index based on the memory of colors or 9 familiar objects
NEW Read more about the IES TM-30-15 method
TM-30 = The newest color rendering method using 99 samples. Preferred for comparing LEDs.
TM-30 (Rf) = Accuracy of colors, fidelity index. Replaces CRI.
TM-30 (Rg) = Gamut of colors, saturation index. Higher number means more saturated colors.
Tint dev. (“Duv” in the CTA screenshots) is the tint’s distance to the black body radiator line in the CIE graphs. The higher the number, the greener the tint. 0,0000 means absolutely neutral white and negative numbers mean rosy/magenta tint. Anything over 0,0100 can be described as visibly green.
If you have an hour to spare, I recommend watching this presentation on IES TM-30-15 which also shines light into color rendering in general.
CRI data on turbo max
CRI data on mid
Output and runtimes
All tests were done with a set of unprotected button top Sony VTC6s.
The actual output falls a bit short of the advertised values, but some of the difference can be accounted to the cool white vs. neutral white output.
The K30 is very efficient at 130lm/W at over 1000 lumens.
All the modes are fully regulated as long as the light doesn’t exceed 75°C. After thermal stepdown it will not fully bounce back to the original level even when cooled but has to be reset. Thanks to the 3S battery config and a 6V emitter, the maximum output is always available throughout the battery life.
Standby drain
There’s insignificant parasitic drain on the batteries when the light is switched off. It doesn’t change when the electronic lockout is enabled.
Normal standby: 65µA
Electronic lockout: 65µA
It will take about 5 years to drain three 3000mAh batteries in standby mode, which is slower than the self discharge rate of 18650s.
Flicker
I measure the flicker with a Thorlabs DET36A/M photodetector and an oscilloscope. I transfer the scope’s sample memory via LAN to the computer where a script parses, performs an fft and other calculations to spit out a bunch of metrics. Then another script draws a graph which represents the output of the light source relative to time. This graph also has the metrics calculated previously.
Here are the metrics:
Frequency – the rate of flicker in hertz. If this is over 10kHz, there’s usually no reason to worry about visible flickering
Modulation – also known as percent flicker which is calculated by (max level – min level) / (max level + min level). 100% modulation means that the light is turning completely off during the cycles like on PWM controlled output
Duty cycle: the relative time the light spends above the mid level during one cycle. 50% means that the light is above mid (“on”) 50% and below mid (“off”) 50% of the time. Lower duty cycle results in more visible flickering or strobe effect
Index: flicker index is calculated using the area under the curve (link is external). This integral is separated into area above and below the average output. The index is the area above that average divided by the total area. A pwm light with a duty cycle of 50% will have a flicker index of 0.5, but it is more useful with more complicated periodic waveforms, especially those whose modulation is less than 100%.
Snob index: a rating, which tries to convey a single number of flicker visibility
1-5% - Probably not visible to the naked eye (high frequency PWM, >10kHz or low modulation at lower frequencies)
5-10% – Might be visible to the most sensitive people who know what to look for and try hard enough (incandescent)
10-20% – Sensitive people will see it at least on bright reflections, probably not a dealbreaker yet in general use
20-50% – YMMV area. If you can usually spot mid frequency PWM, you’ll easily see the flicker
>50% – Visible to most people at least on some occasions (low frequency PWM, <200 Hz)
There’s some ripple on all the modes, but nothing to worry about since it is high frequency and lod modulation. I couldn’t make it visible even with a cellphone camera held right down on the lens.
Low
Mid
High
Turbo
Turbo Max
Strobe operates at 12.5 hertz.
Temperature
There’s thermal regulation in the K30 and it isn’t very aggressive. The light gets hot, but protects itself from damage. It is up to the user to lower the level when they start feeling uncomfortable.
I measured 63°C from the handle and above 70°C from the head on turbo max. On turbo before the stepdown the light is even hotter, 65°C on the handle, before it starts to decrease output at about 45 minutes. In a cold environment the light may not step down at all on turbo.
On high the light reaches 51°C which is barely holdable.
Verdict
Everything about the K30 oozes attractiveness. It’s compact, light, very nicely machined and the sand finish is absolutely beautiful. The system as a whole is very efficient reaching 140 lumens per watt on the mid mode of 500 lumens.
The ingenious fixed battery carrier has long but hefty springs with the perfect sizing. It fits all types of 18650s from the short flattops to the longest protected button tops with no issues. For modding, there is some work to be done, since the screws have glue on the end.
The only thing that lets it down is the combination of smooth reflector and the XHP70.2. Together they produce an inconsistent tint with a greenish hotspot and purplish spill.
+ Very high output for a single emitter light
+ Excellent efficiency
+ Regulated output as long as the temperature stays within safe limits
+ Perfect form factor, light and compact
+ Beautiful finish and attractive color of the sand
+ Innovative battery carrier with minimal losses, accepts all kinds of 18650s
+ No visible flicker
- UI bugs related to mode memory
- Greenish tint
- Tint inconsistency within the beam
sp5it
sp5it's picture
Last seen: 4 hours 18 min ago
Thanks for the review. That convinced me to stay away from Acebeam since 40$ light outperforms it Smile
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
Box
Last seen: 1 year 8 months ago
Thanks for the great review like always.
As a person who only uses his torches on max. 4 clicks for turbo max is too much work
Klotski
Klotski's picture
Hey sp5it
I am going to buy this light today as it on sale right now, can you tell me which light outperforms it I would like to take a look at that one first.
Thanks Paul
mizjif
mizjif's picture
Last seen: 1 hour 44 min ago
I’d like to know where this light is on sale and which $40 light out performs it also
Klotski
Klotski's picture
Well my neighbor to the north
These guys http://www.andrew-amanda.com/catalog-promotion/ are having a X-mas sale thru midnight tonight I tried their Promotion code: xmasgift2017 last night and the price dropped by 30%.
Paul
Ronin42
Ronin42's picture
Last seen: 1 year 11 months ago
Wow now that is a review (and tint master class)
If only they put more work into the MT-G2 it always looked so nice.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
mizjif
mizjif's picture
Paul
My neighbor to the south, Thank you for the reply Paul!
maukka
maukka's picture
The BLF Q8 has more output during the first minutes. Especially if you bypass the tail springs, which was done on the light on the beamshots in the review. It is a larger and much more heavier light though.
sp5it
sp5it's picture
Just be aware, that several k30 had failures because of “budget” switch falling off the pcb. (Thanks Tashenlampen forum)
Mike
beam0
beam0's picture
Last seen: 3 hours 44 min ago
I wanted to love it…
Size Thumbs Up
5200lm Thumbs Up
Sand color Thumbs Up
But…
Faulty switches Flat Stare
4 clicks turbo max Flat Stare
Greenish purplish tint Flat Stare
3 minus 3 unfortunately = 0 Facepalm
SKV89
Last seen: 2 days 22 hours ago
Beautiful light compact yet powerful light. I was about to buy it until I read your review about the greenish tint. Thanks.
