Yes, although you don’t have to get the clear version if you want those upgrades. The main upgrades are the XP-L HI emitter, Smooth Reflector, Biscotti Firmware, and AR Glass. There is a Black model with the XP-L HI and smooth reflector; you can add that to your cart and add a note requesting Biscotti and AR glass, then wait for Simon to adjust the price before submitting your payment. For the Gray model, you have to include the XP-L HI and smooth reflector in your note.
So the Clear model is the easiest to order, but you can get the other colors if you prefer.
My very first Convoy flashlight was an early Convoy C8 with an OP reflector. Love it. They’ve been around for a long time, most people just go for smooth reflectors. The OP reflector has a beautiful beam pattern. It’s a pretty light OP but it makes the transition from the hotspot out very smooth and eliminates any rings that might have been there. This ultra smooth beam transition does cost you a bit of throw though. I actually just got an OP C8 reflector from Simon but it’s for the older 7mm opening so it’s not a direct swap in a current model C8 unless you have the smaller centering rings. Old opening is 7mm. New opening is 9mm. The other upgrade that happened at the release of the clear C8 was a new DTP copper MCPCB.
I ordered another c8 with everything on it and asked Simon for other button and black body color. As before, he said no problem and gave me a discount Probably the best seller i have seen
I have “tested” the beam of my Klarus xt12gt, c8 and Fenix rc20. Fenix has the worst beamshot. Klarus is the best, but is getting hot on max output. C8 is not far away from Klarus beam distance.
hm the klarus says a bit over 600m throw, can the c8 with xpl hi really come close to that? its more around 300-350m throw at most no? either way the convoy wins any day if u look at the price and what u get, clear winner to me.
They need to be on a website, first. Then you take that pictures url and copy paste it into the pop up box when you click the orangish sunset looking button above the post window.
Yes it does, but after some time it also gets hotter than Convoy. For my needs (job) the Convoy is a great flashlight. If only i would find the Convoy before purchasing the Klarus
A friend of mine just got in some XM-L2 U4 0D emitters, found that de-doming with Coleman lantern fuel left the tint very nice and it came clean in about 20 minutes. He used it in an L2 and absolutely loves the result!
Jason, just looking at the wattage isn’t the whole picture. The efficiency of the emitter at a given output will change how much of the applied wattage is light and how much is heat. When overclocking the percentage of heat/light changes. So which one is overdriven will tell which one is making more heat. In the case of a 1600 lumen XHP-35 vs XP-L at 900 lumens, they are both in their comfort zones and shouldn’t be getting all that hot… the boost circuit in the Klarus is probably making the heat directly from the driver.
And to establish wattage, forward voltage at the applied current needs to be known, it changes as the current changes. The XHP-35 goes up to some 14.3V when pushed at 2.5A, gotta have actual emitter Voltage at the applied amperage to know the wattage.
An example is my 18V Cree COB in the small DQG Tiny 7x XP-G2 light. At 1A the COB is pulling 21V for 2004 lumens. That would be 21 watts. Yet the small light doesn’t really get hot until quite a bit of time has gone by, so the efficiency is high and most of the wattage is burned as light out the front.
