Setting up a P60 as a weapon light
7 posts / 0 new
old4570
Last seen: 1 week 1 day ago
Setting up a weapons light :
The first thing that comes to mind is recoil , and how one would go about countering such .
The one moving object , that could reek havoc internally is the battery . Contained by a spring at the front and rear , it hardly has enough force to stop the battery becoming a battering ram under recoil . And even if one were to stretch the springs , how long before they gave up from the pounding of say a shotgun ?
So the challenge is to stop the battery moving , to this end one would want to plug both ends of the flashlight so as to hold the battery in place , yet allow the flashlight to function .
If I had a lathe I would just turn up some plastic spacers , but since I dont , and most of you dont , we are going to do it the budget way . [ On the cheap and easy ]
Youl need a roll of tape , what I did was take a AAA battery , and wrap some tape around it sticky side out [ dont want to tape the battery ] and then continued sticky side in rolling up a slug that will fit inside the body of a flashlight .
I then measured the + spring on my pill and cut the slug to fit [ Button battery ] , make sure you cut to fit the battery you have or plan to use [ flat or button head ] ..
This plug will stop the forward movement of the battery yet allow contact .
Fit the pill + your new spacer to the body and test to make sure it works ok , if everything is ok , we then cut the rear spacer .
And Viola ! , if everything is cut to the correct length , you should now have a flashlight capable of handling recoil , and one that will function correctly .
Hope you enjoy !
Obviously with a lathe , one could do a much more professional job , ....
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
jacktheclipper
jacktheclipper's picture
Last seen: 8 hours 58 sec ago
I think you may have rolled out a good idea .
What I do
old4570
I have these ideas rolling around in my head , and sometimes I let them out .
Often I get ripped , or others take credit for my ideas [ Intel comes to mind &*%*%$#$#$&& , fkn ass wipes taking credit for stuff I came up with ] so I dont let them out often enough . Two CPU cooler companies have ripped me , and Intel is taking credit for something I came up with a long time ago ..
If I were a rich man , id have lawyers all over them .
Being some what poor , I just have to gripe about the low life scum ..
[ Ooops , did I just rant then = My bad ]
Been sitting on this one a good two years , thats a long time to keep something to myself ..
But I did hope to have a lathe by now , and be machining components for flashlights .
Oh geez , just remembered Solarforce has taken one of my ideas ...   Oh dear !
Such is life ...    [ The list is growing - which is why I tend to keep stuff to myself maybe too often ]
Anyhow , I thought for sure some one else would have done something similar by now , so I guess this one has cooked long enough .
edc
edc's picture
Last seen: 5 years 6 months ago
Good work Old. Sometimes the simplest ideas are often the best. It makes you wonder why no one else thought of this before.
http://i1193.photobucket.com/albums
Burro
Last seen: 8 years 9 months ago
Just a suggestion, instead of tape what about a piece of garden hose, it would need a couple of mm sliced out of the side to fit the battery tube, I think the the hose may be 20mm so wouldn't take much to get it to fit.
People demand freedom of speech to make up for the freedom of thought which they avoid.
old4570
Dia would need to be kept @ 18mm or a little less ..
As the bit at the pill goes into the flashlight body , and same at the tail ..
Make them too tight and removal will become a PITA
Also plugs that are too hard may hammer the battery , some sort of medium hard rubber would be ideal with just a little give [ absorption of energy ]
I used cloth tape , as it has a little give ..
Burro
Better quality hose is quite soft and pliable, not the cheaper stiff hose.
