Plastic could have been done and it would have been cheaper but this was rejected during the initial specs for the light.
Mostly because plastic tends to warp and bend and this causes issues down the road and it also makes modding very difficult.
There are some other options for making reflectors like electroforming? that cost a lot to setup but then are cheap to make large quantities. They were not aware how many would sell when they started production so this was not considered, still not sure if it would be worth the start up cost even with 1500 being made.
So overall, the lathe made aluminum reflector was the best and simplest option.
I was doing some testing with the xhp70.2 a few weeks ago before I got sick. That put everything on hold.
Thanks to the donations of a few generous BLF’ers I was able to order some more parts to keep the testing going.
I just got in another xhp70.2 yesterday to continue the testing though. Hopefully I can find some time this weekend to put it on the sphere and try slicing the dome. Might even try some final focus adjustments as well.
Also got in some parts to beef up the stock driver and hopefully increase the power some more.
As well as some parts to mod the drive for 3V LED’s as well.
If only there was a good 3V LED that I could try that uses the 3535 footprint.
Not sure how much I will get to this weekend but should be able to knock out at least some of it.
Ummm, no, a silver reflector would weigh only slightly more than aluminum. Why? Because no person in their right mind would make the entire reflector out of silver (check the price of silver compared to aluminum). Instead it would be put there through vapor deposition over a reflector base and the layer would be quite thin since that’s all that’s required. Or do folks think that the silvered mirrors on the Hubble are solid silver? Or the mirrors in modern telescopes are? Again, all that’s required is a microscopically thin layer to get the benefits, and not solid silver.
For the questions about the registered mail shipping after DHL.
NO ONE knew this was going to happen nor wanted, desired or even approved of it happening.
Far as the team knew the orders would be shipping in the order they were paid and that was that.
Everything after that was sprung on us just like everyone else.
Now there is some logic to why they did what they did, so I can’t blame them too much. For example DHL shipments will have relatively few if any issues, they will arrive quickly and with minimal abuse on the trip compared to registered mail.
So it makes sense to send these out first and get the lights in peoples hands.
Registered mail on the other hand will have some issues, just the nature of the beast. You will not ship hundreds of registered mail packages of this size without some percentage of them having issues, it makes sense to have these inevitable negative experiences come after a bunch of positive ones and not vice versa.
First impressions are everything in a project like this.
There are even more factors as well and all things considered, I would have had a hard time not doing the DHL shipments first if I was in their shoes.
That said, the real mistake they made was not in shipping DHL first but in not letting us know this would happen ahead of time. There I 100% agree they messed up.
The language barrier makes communicating difficult and details like this tend to get left out as it ends up taking 3 emails to understand exactly what was said.
At this point they must be out of DHL orders to ship so by process of elimination registered mail must be going out soon.
Oh, and to the user that was missed and added to the list as 1762, know that when he asked, he was not on the list for the 3rd one. I updated the list after seeing the request posts from my phone. I don’t generally post from my phone though, just not worth the hassle.
Also, as he pointed out and is now added to the OP, the Team-Giggles account has had the PM’s disabled as no one actively monitors that account. So your message could just be lost for weeks on end before someone logs into it.
If you have a question or issue please send them to Neal or myself at this point.
Absolutely. That wouldn’t be hard to do Alux. Even if it’s a coating of aluminum it’ll oxidize so that should be coated also. Clear coat might be more of a problem with a telescope due to the absolute requirement for accuracy. But I’m out of my knowledge base when discussing clear coat. It would be far easier to clearcoat a flashlight reflector though since we aren’t discussing fractions of a wavelength of light. Maybe the same AR coating that is put on a lense would do it? I’ll leave it to the manufacturers to handle.
Would it be worth doing for the slight gain in output? There might be less expensive ways to get that gain then by silver and clear coat.
Just brain storming now… I was thinking platinum also, but I didn’t look up it’s reflectivity. That metal doesn’t oxidize. Of course we’re back to cost and I have no idea if it can be vapor deposited. Gold would also work. I know gold can be vapor deposited. Just look at a NASA astronauts face shield. Again, cost.
I would like to extend a special thanks to Lumintop for the great work they have done from the day we first contacted them right through today. The amount of work they are doing is unbelievable. Their expertise is immense. It is obvious Lumentop is an excellent manufacturer. We are very fortunate they are making these lights for us. They make it very clear they are willing and able to do the most possible.
I don’t know how everyone else feels, but if it took a year before my light came, because that was the time needed to make it as perfect as possible, I would be delighted they took all the time needed to do it they way know is best. It takes as long as it takes.
Y’all make the reflector plating process sound simple. It’s not. The final finish used won’t stick to the raw aluminum as machined, so what appears to be brass is applied first. This fills the machining marks, normally, and leaves a more perfect finish for the final reflective coating. (Yes, I’ve hand sanded the coatings off down to bare metal too many times) At any rate, the people who make reflectors specialize in it, pretty sure they know what they’re doing.
As a modder, I detest plastic reflectors. If I know up front that a light has a plastic reflector I choose not to buy it.
In case anyone missed it, I’ll probably repost this every now and then.
I have some news on emitter swaps.
I talked to Richard at Mountain Electronics (RMM on these forums and a sponsor here) and told him there might be more than a few guys with GT’S interested in swapping to a cooler tint. He says that if you send in your stock mcpcb to him and buy one of his new XHP35-HI emitters, he will reflow it for free! He has 2 choices right now, 5,000k and 5700k tint. They are both the same D4 brightness bin as the stock GT 4000k emitter.
The cost of both are under $8, plus the shipping cost there and back. I’m in Texas and shipping a small package from him is usually $2 to $3. So I would estimate the entire cost at under $15.
I always wonder about the shapes some plastic things have.
Why the shape of a cucumber?
Where they left with some free plastic molds that they used and turned into a flashlight?
Or did someone seriously say “Yes thats it we’ll put a flashlight into the shape of a cucumber”
“you know what throw on a life hammer”
“Roight jobs done well done lads”
