It is 3 mode, but you have to live with it :) If you want to use it, you should put it all in thermal compound, otherwise thermal protection will turn on quickly.
If you use the DX SST driver be sure to mod the tube on the end that changes modes with the old driver. Remove material at the end of the tube so the threads bottom out and tube end does not make contact with driver. Another solution might be an insulator washer. Not heeding this suggestion may result in a direct short. Don’t ask me how I know this information. YMMV
Yeah, thanks, I was wondering where this short is, because there is. Light is visibly brighter, on meter it is only 5-7klux, but it is visible :) I will try to make a washer today :)
I was running STL-V2 on 3x16340 yesterday - everything was ok at least for 10 minutes - and shall get also a 1x18650 length tube soon... Legoing is nice
My STL-V2 arrived and I took it out tonight to see how it measures up to my Trustfire TR-1200 (3x 18650). Well I was totally pleased with the output of the TR-1200 until tonight. The Sky Ray STL-V2 (2x 18650) is now my new stallion. It is a very impressive torch. I am very pleased with this purchase. Worth every cent!
Ok, I have given up with 3- mode only driver but I have a problem.
My friend probably fried the driver, are these original drivers available anywhere, strobes are accepted…
Tailcap would also be in need, at least the clicky mechanism.
I just recieved my STL-V2. I wasn’t impressed during the day with it. Comparing it with my X9 it seemed exactly the same only bigger. Taking it out and shining on some trees in the distance, the difference in throw is apparent. The beam goes way farther with about the same spill. Longer runtimes as well. Very happy.
I modded my fandyfire V6 with this driver and it's brighter, 4A is fine. Below are my instructions from an earlier post #136. You can use a belt sander or hand file to cut tube shorter as instructed below. Almost a drop in mod and very easy.
If you use the DX SST driver be sure to mod the tube on the end that changes modes with the old driver. Remove material at the end of the tube so the threads bottom out and tube end does not make contact with driver. Another solution might be an insulator washer. Not heeding this suggestion may result in a direct short. Don't ask me how I know this information. YMMV
If you remove the tube (the 18650 tube) and look at the driver there is an extra contact ring. This is what makes the dual 3/5 mode work. When tight the tube contacts this ring for 3 mode. When the SST50 driver is installed this will cause a direct short to the positive and a small amount of the end of the tube will need to be removed. On the one I modded to this driver the ”Straight” knurl part that holds the driver was NOT glued and was easy to unscrew from the finned reflector housing. This made it easy to remove the driver. The last two lights I have received were glued. HTH
