I don’t know if this has been discussed yet but I would love to see a D1S with 20700 battery tube, which makes sense for this light, and maybe 22mm driver room so we can mod it with XHP35 HI and 1.5A boost driver from KD.
It will be cool if we can mod d1s to xhp35 hi… however, you can purchase acebeam L16 for $60. ( online deal )… i got one back in december. I dont know if coupon still valid… L16 is little bit smaller than d1s, and longer…
I am thinking of getting one of these to supplement a floody headlamp. I’d like a holster to hold it on the shoulder strap of my rucksack so I can easily grab it.
A lot of holsters have webbing strips to thread your belt through. If your backpack strap has a webbing strip running along the strap, you can use a connecting clip to attach the holster:
These clips are only relevant if the webbing strips to be connected run parallel to each other. Webbing strips that run at 90° to each other need a different solution where one of the strips has a pop stud / velcro / somesuch, so that you can thread one strip through the other, then secure it with the pop stud. Caveat emptor - not all belt holsters can be threaded that way, some of them have their webbing strips permanently sewn down at both ends.
Wanted to say I just received the optional 18350 shorty tube in the green and 2 Windyfire 18350 IMR cells from mtnelectronics. I have to say and as always, their service is outstanding.
My green D1, (which I also received from mtn), has the smooth finish and the shorty 18350 tube has the rougher texture which some here don’t care for. I have to admit, I prefer the smooth finish but the rougher texture of the shorty tube is in the center of the light and adds a little more purchase to the now tiny light. Also, the rougher green 18350 tube matches the smooth green finish pretty darn good.
What I’m trying to say is the D1, (mine is CW which I favor and the D1’s CW beam is the best I’ve ever encountered), is already outstanding and with the addition of the shorty 18350 tube, I just love this thing!
Does anyone know why nichia 219c option is available only for D4 but not for the D1 or D1S? Seems the hotter 219C would be more fitting in the D1 and especially D1S with the much larger thermal mass.
Being throwers, the XPL-HI makes a much better job “throwing” the light. Maybe with the Nichia it would enlarge the hotspot, but it would not reach so much in distance probably!
I guess the heat is not a problem on those 2 lights, but the function of “throw” would probably suffer some decrease with that LED. Even if the tint would improve!
It will burn up with that DD ‘driver’.
With 4 in parallel they will survive better due to internal resistance of the battery and the consequential voltage sag.
Derisive quote marks not necessary, but yes, running a low-Vf emitter direct-drive from a high-amp cell will generally turn the LED into smoke.
Even without that though, the XP-L HI is better for throw purposes… and the reflector is optimized for a flat emitter so the focus would be off a little with a domed emitter.
My D1 does not agree with you since I put an STT40 in it :partying_face:
Still much cooler than my 219C D4 but it gets hot fast now !
Next step is to put a dedomed XP-L in the D1S to get full throw !
