LMAO sorry.... It is a laser ranger finder.. I have wanted one for a while but any that go out to a decent range get stupid expensive... This one was not cheap but reasonable... And just from goofing off with it today reasonably accurate.
A new camera; Panasonic ZS100!
1” sensor, 10X optical zoom, Program, aperture or shutter priority, manual… An electronic viewfinder as well as the 3” display.
The dial indicator i received a few days ago from aliexpress didn’t work, not surprising after opening it and having a look, i’ll see if i can make a bushing to fix it :person_facepalming:
As l posted earlier, l think OnePlus’ Dash charging is better for the battery than the usual lower rates. As l pointed out earlier, my battery gets more hot using the ‘normal’ rates than the Dash charging technology in my OnePlus.
l tried the lower, slower charging rates thinking it should be better but because the Dash charging technique has a special circuitry that routes back the heat to the psu, only the psu gets hot.
ln fact, l notice my battery’s performance is as good as when l first started using my phone, going into its 3rd year.
One more personal technique of mine to prolong my battery’s cycle life is to avoid having the battery fully charged the whole night and instead just charge it the next morning instead since it doesn’t take long to charge it 80% using the oem Dash charging anyway.
It’s a well-known fact that a high SOC (state-of-charge) is detrimental to lithium-ions.
…and more detrimental is high heat situations.
