xP.1337
(xP.1337)
November 16, 2010, 1:26am
1
really, where the hell do i get an R2 or R3 on a 14mm board?
i just want to rebuild my XR-E Aurora V6.
my MC-E and XP-G R5 are finished, and I need to compare it to an older style (and i love the throw of them lol)
*edit* upgrading the MC-E to maybe an M bin. need one on a 16 or 17mm round board.
the one in there is like MAYBE J bin, and is on a 14mm star so it doesnt center well in the provided space.
agenthex
(agenthex)
November 17, 2010, 6:17am
2
The only place I know of to reliably get boarded emitters is cutter.com.au. Shipping is high-ish so you'll have to get a few to offset. You can get the emitters themselves from a few different electronics suppliers, but supply is sporatic.
xP.1337
(xP.1337)
November 18, 2010, 2:58am
3
i have no problem buying a few, but they seem to not have them on 14mm stars.
also im looking for an MC-E on a 16 or 17mm star (for my P60 host) thats an M bin or so
I need to up the efficiency because of the heat output from the Shiningbeam 2800ma regulator.
agenthex
(agenthex)
November 18, 2010, 3:58am
4
They have a 10mm square mcpcb which should be close to 14m diagnally.
agenthex
(agenthex)
November 19, 2010, 1:38am
6
Sorry, it's on the xp -e page.
xP.1337
(xP.1337)
November 19, 2010, 2:31am
7
yea i need an MC-E on a 16-17mm star of bin K or higher. I prefer bin M or N.
i wish i could even find the board seperate, cause i could get the bare emitter from cutter....
uhg why is this so hard!
shoot i have an MC-E on a 14mm star in a drop in!!!! but its a much lower bin, can tell by the massive amount of heat at the same amperage as a p7
agenthex
(agenthex)
November 19, 2010, 3:12am
8
Well, a xp-e might work out.
xP.1337
(xP.1337)
November 19, 2010, 3:21am
9
in what case?
i cant drive an XP-E at 2.8 amps lol
i already have a few XP-G R5's
I need an XR-E R2 or R3 AND an MC-E M or better.
The XR-E has to be on a 14mm, the MC-E has to be on a 16 or 17mm.
Also awaiting the XM-L on a 14mm as well, which should be soon from what ive read (cutter i guess is doing that one)
xP.1337
(xP.1337)
November 19, 2010, 3:25am
11
well the XR-E is wanted due to the optics, and the lenses i have are all perfect fit for XR-E and MC-E!
the XP-G looks funky on this reflector!
agenthex
(agenthex)
November 19, 2010, 3:30am
12
The reason it might is because the focal distance is slightly off. Might trying shimming or sanding if you're commited :).
xP.1337
(xP.1337)
November 19, 2010, 3:31am
13
tried it lol
but thank you for the comments. seems like ur the only one lately to read this stuff lol
ill settle with another q5 for the XR-E
as far as the MC-E.... i might get the 20mm star and shave it down. that should work right?
agenthex
(agenthex)
November 19, 2010, 3:36am
14
So what happened with changing focal length on that reflector?
Shaving should work.
xP.1337
(xP.1337)
November 19, 2010, 3:45am
15
i tried first with placement, i still has ugly rings.
the R5 also did have as nice of a hot spot.
reason is, the R5 has a very EVEN almost 180 degree light output.
I wanted the thing to throw, the q5 did ALOT better at that due to its already hot spot without a reflector!
like i said tho, i REALLY want an MC-E on a 16/17mm star!
